- Feb 15, 2001
- Harford, WI.
This is the second time I have hooked up my watercooling and have had some games begin to kick me back to the desktop while playing. This is with my 86w peltier installed yet.
The chipset HSF is very, very hot! Could that be the reason why I'm getting this problem? I tried aiming a fan at it to see if cooling it down a bit would take care of the problem. But it didnt. There is not enough room between the water block and the HSF to put a small fan right on it.
The water block gets so hot you cant even really touch it after a while. I'm only using a 1\2 gallon of water to cool and the water just gets warmer and warmer. It stays pretty steady around 15c @ idle though. and reaches as high as 27c under extreme full cpu load.
I will be taking my peltier out and trying the watercooling without to see if it does it or not. But when I have my alpha installed with the peltier this does not happen, it runs 100% stable all the time.
Anyone have any suggestions?
