Alright so i just uninstalled my watercooling kit and i made quite a mess. I thought i wiped all the water off but apparantly i didn't. There was some left on the power cable (dont ask how it got there), and some other places inside of the case, there was a small amount on the video card and some on a power connector or two inside the case, most importantly though there was a bit on the female end that goes into the power supply and it made a small pop when i plugged it in. First my system wouldn't post, or beep, but everything would turn on (drives, fans, etc). I took the rig apart and got down to the basics and now the computer wont come on . Everything was working fine with the watercooling system however i uninstalled it because my resevoir is leaking. Is this a motherboard problem, a power supply issue, a cpu issue or worse a "My whole system is screwed" issue? I have a pentium 4, it's my first intel processor since the pentium 1 days. The motherboard doesn't come on now with or without the cpu in it; all motherboard fan connectors are connected and i have one stick of ram in the motherboard. I dont think it's the power supply because i can here the power to it cut sometimes when i turn it off. I'm trying to figure out this problem and i really can't. I'm thinking i'll run out to the store later after a friend comes over with his power supply so i can check if thats the problem and get a new motherboard, didn't like my gigabyte 8knxp that well anyway, i just hope the damage was contained .
