Sooo Close now!! just a few questions....
Wildfire
Surrey
Ok
I am very close to buying a Ti 4400 at the moment but just a few questions:
I am buying in the US for the use in the UK. The card will work in my system won't it?
There isn't any voltage or resolution problems?
I am getting the GeForce on reccomendation of my tutor at college, because he said that the GeForce will run Softinmage XSI better than a Radeon. Anybody hear any differently?
The card is $300 plus $40 shipping, is this ok? Anybody know the release price on the UK? In the UK the Ti4600 goes for about $560.
It is the Visiontek Xtasy model Ti4400 I will be getting is this a good one?
Anybody know the features?
Thanks guys
slim_lim
I don't see why a ti4200 wouldn't work in your system, so I think you can buy one safely. However if you primarily need a graphics card for 3d modeling work not games, then I think you'll be better off holding on to your money and modding your existing MX into a Quadro.
Starfoxer
World's Biggest E-Thug
USA
Re: ti's
manny calavera said:
i own 2 ti4400's from vt and am very happy with both.one is running 325/618 and the second is still in the box.:D
WELCOME TO THE FORUMS
hey, can i have your other ti 4400???
Wildfire,
the card will work in your UK box. i too think you should try
to turn your MX into a quadro, if its gonna be for video stuff.
here is a post telling you how to do this.
http://discuss.madonion.com/forum/s...&Searchpage=0&Limit=100&Old=1week&Main=269029
hope this helps
Placid
Senior Member
Connecticut
I will work fine the motherboard will supply 1.5v to the agp card just like in the usa.
$300 u.s. is a fair price.
manny calavera very nice overclock, someone was putting me down before when I said I thought the 4400's would oc to 600/300.
Wildfire
Wildfire
Surrey
Thanks Guys that all cool advice. As to modding to a quadro. I have tried to do this but the drivers that I have are a .exe file and I couldn't get my computer to recognise the drivers that I downloaded when trying to patch them.
Also wouldn't a GeForce 4 run faster than a MX modded anyway? Just from higher clock speeds and the DDR memory? Besided my MX really struggles with the dual monitors in 3D even overclocked to 215/215 I do play some games as well and it's been a while since I've upgraded anyway. I went for the budget option before and it's lasted a year and a half so this time I want a top end card.
manny calavera
in my pc
thnx Placid,yes mine will i don't know about others though?.the second one won't be coming out of the box till i get my other parts.
