Sooo... Whats the best heatsink for the money now..
The Spyder
Oregon
Its been like 11 months since Ive even looked at computer hardware, 6 since I stoped using watercooling. Whats the best heatsink right now for the buck?
I have a Barton 2500 I just purchased if that helps...
What mobo? Most of us use or prefer the thermalright brand of HS.You can view them here. www.thermalright.com .If your mobo has the 4 mounting holes you'll want the SP-97 HS.This HS has not been out long and is available from several venders.I run the SP-94 the SP-97 brother. I run the Panaflo U1A 92mm fan on it.Its a hard fan to find now days. THE FANMAN:cool:
just read what i posted here if there's any doubt in your mind about whether you should go for Thermalright LINK
I like the Thermaltake Volcano 12. It knocked 15* C off of my temp,when combined with AS5.
OK just to tell you how good thermalright is, they could market an aluminium foil ball as the hs solution, and still make a quarter of a mill off of name recongniton alone.
But it would be VERY high quality foil! It would be super shinny and have perfect sphericalness.
arg get thermalright, for overclocking i would say at least slk-800. Otherwise sk-7 is alright. This is just a guess based off the performance i have seen out of the SP-94 and performance i have seen from the slk-700 modded for an 80mm fan.
SK-7 is the best for the money, but it's hard to find, as most stores stock the newer heatsinks. I've got an SLK800 with a TT smartfan 2 on my Barton 2500+ (overclocked to 3200+), and it's under 40C load :)
For the money I agree with everyone else in the Thermalright line is the best. I have the SLK-947U and love it. If you wanted to spend a little more go with Swiftech. They make some awsome HS's too. :)
Whacha know....
Thermalright Is still the best.... *Kicks self for selling 900u to Thunder7 :D*
Off to buy another thermalright, thanks guyz!
Oh yeah, how are these new heatpipe looking thermalrights doing?
