SORRY 4 THE FREQUENT POSTS, dont know how to update bios
Subzer0
sydney / australia
hi i want to give it a try anyway ,but dont know how to update bios. i have all versions on floppy but dunno the procedure, can anybody shed some light .......thanks
How do I flash the BIOS?
1) In order to flash update the BIOS, you will need a floppy disk containing the the following:
a) DOS without any memory management drivers installed. I recommend you use the DrDOS 7.X boot disk designed specifically for BIOS flashing ( available from Here ).
b) The BIOS *.bin (or *.b00 or *.b01) file you wish to update to
c) The previous BIOS *.bin file (just in case you wish to flash back!)
d) The latest AWDFLASH.EXE utility from ABIT (available fromHere )
e) The ABITFAE.BAT file from ABIT (available from
Here
f) Optional: ABIT have started supplying a file called RUNME.BAT with their BIOS releases which calls ABITFAE with the BIOS filename. You can put this on the floppy disk if you wish, and then instead of Step 6 below, type "RUNME".
2) Note that ABIT often supply their BIOS files as executables (eg. KT7_WW.EXE). You will need to run this executable (which is a self extracting Zip file) to get the BIOS binary file and possibly also AWDFLASH.EXE, ABITFAE.BAT and the optional RUNME.BAT. You may also encounter BIOS distributions in *.zip files, in which case you must first extract the zip file using WinZip.
3) Shut down your computer properly, then turn it off.
4) Restart the computer with the DOS diskette in the floppy drive
5) At the A: prompt, type DIR to check the files on the floppy disk. Assuming all the files in Item 1 of this list are present, go to the next step
6) At the A: prompt type ABITFAE filename - where filename is the name of the *.bin or *.b00 file you are using. (If you installed RUNME.BAT, you can simply type RUNME instead)
7) The utility will ask you to confirm a number of things, and will then automatically flash the BIOS with the correct parameters. Once it has finished go to the next step.
8 ) Press F1 to reset, then immediately press DEL to go into BIOS, then please:
a) Go into CPU SoftMenuIII to adjust your CPU speed and voltage (please make sure the CPU voltage matches your CPU specs)
b) Set up any other BIOS parameters you required (remember you will need to redetect your hard disks!!)
c) Save and Exit
9) You're done.
Abit Also have a detailed instruction on there site which features pictures
( http://www.abit-usa.com/english/download/bios update/help.htm ) And there is aso information in the manual on this task.
Hope it helps
thanks man, i appreciate it. your the only 1 to respond to this so far without telling me not to do it [ in other threads] i got no choice,last straw for me b4 i return my cpu
