cj_91
- Nov 5, 2012
- Perth, Australia
Hi, for anyone who may be knowledgeable on the subject of soundcards and more specifically uncommon problems resulting from defect/damage may be able to help me!
Last year I bought an asus xonar essence STX, about a month ago it developed a problem whereby the sound level coming from one channel (right, from memory) is very low, and increasing the volume via the sound card itself, the system, or the headphones (sennheiser pc360's) resulted in ONLY the already loud channel increasing in volume. With the headset's volume control slider on 100% I have to manually adjust sound output balance level on the soundcard to reduce the loud channel down to aprox 50% so that the sound is even.
However with the headphones volume slider on 0% (which is far from muted on these particular headphones) the sound balance is quite even and so I can leave the levels even on the soundcard itself.
The ONLY way to get the sound loud, and balanced, is to manually boost the dB output of the soundcard as if I was using high impedance headphones, but even then any adjustments made to the volume on the headset or even windows volume needs to be corrected on the soundcards' stereo balance to make it even in each ear.
The only thing I can suggest that may have caused damage to the soundcard was that it sat awfully close to a very hot HD6970 for the best part of 6 months and I am thinking that maybe there could be heat damage.. the PCB can reach temps of 60+ degrees C and can move that heat through the PCI slots as well as through convection and radiation.
Any help on how to further troubleshoot or diagnose the issue would be much appreciated!
Things I have tried: different headphones, using stereo speakers, moving the card to a different PCI-E slot, trying a different computer with fresh drivers altogether, reinstalling the drivers, reinstalling previous drivers, swapping the OP AMPS, googling every which way I could my problem.. so far no luck - I am convinced that it is a problem with the card itself! Maybe capacitor damage?
edit: To simplify. the left channel sound is permanently stuck low. we will give it an abstract value of 10. 10 is the lowest level the sound can go without being entirely muted. Raising the volume on the headset increases the right channel from 10 (0% volume) to 20 (100% volume) however the left channel stays fixed at 10. With the dB boost we can call our new abstract value 20. Now the volume on the right channel goes from 20-30 but the left stays fixed once again at 20. With a pair of earphones that do no have a volume slider it is essentially the same as if it were set at 100% volume and ratio of sound is 2:1, so there is a major issue at the heart of the soundcard i think..
