NOTE: This will take quite some time (several hours or more) to finish depending on how large the disk is since it is writing over each and every sector on it to zero. Think of it as being like a full or low level format.
Try this:
Load the repair disk and get to CMD prompt
CMD > diskpart > list disk > select disk X (whatever your boot drive is) > clean all.
Sit back and wait. SSD's are pretty quick but large capacity HDD will take a while. "Clean all" does a pretty thorough job of resetting the drive. http://www.sevenforums.com/tutorials/52129-disk-clean-clean-all-diskpart-command.html
While this is going on check your install media for scratches/blemishes or just consider using different media. Sometimes the smallest scratch will be the end of an entire install, in my experience. After the clean all finishes , remove any OC and install Windows. Add in all the fun drivers (chipset etc) and then test. My thinking is that even though you have done the format option during an install there are some sort of leftovers on your boot drive that arent getting overwritten, or possibly damaged install media. If none of that works.... well Ill be curious to see what other answers this thread turns up as well because I dont know what to do after all that
Will that work in windows 10 setup? Don't SSD's overwrite with wear leaving?
In Order To 'Zero out' An SSD, you need to SECURE ERASE it.Well Im no expert but I think an SSD doesnt overwrite at all but removes some sort of header that alerts the OS about readable information. I.E the information is still there but invisible.... or something. HHD do the same thing in a different way .. maybe. Im not gonna look it up today Clean all does actually clean all though (if you believe the manual for diskpart).
All Im saying is that if you have already wiped the OS , you might as well get the most solid install possible so that the OS can be ruled out as the source of the issue. Of course there are other ways to narrow down the issue, but it never hurts to have a rock solid install to start with. Take a system image once you are comfortable that everything is copacetic. You will thank yourself later
You would also set up different (or even the same) OS in a VM and see if you can replicate in there? Good luck whatever you do though. Sound issues are one of my pet peeves with Windows.
I downloaded the windows 10 from Microsoft 3 times using there tool. I'm still waiting for something to go wrong with windows or Chrome after the last non clean install of windows, just trying something different I have not tried.Well ya, so what are you using then? A torrented copy? Ya updates suck but tho it still sounds kind of like a Driver issue, it does sound very weird overall. Good chance when you created your Media you didn't do something perfect. Not sure what you're using to create your Usb Media or your Disc Media but for sure doing it at the slowest settings is recommended and I've found Rufus to be pretty reliable for Usb Media. I forget the Complete name for the Windows whatever tool out there but I hate it, I don't use it. But it could be a corrupted Iso Image, or a corrupted Install Media. Despite the Update time if you are using the same Iso Image (assuming you've downloaded a copy somewhere) I'd either try a different copy or the Original Media you purchased.
How do you zero out SSD from a boot drive without destroying it using free software?In Order To 'Zero out' An SSD, you need to SECURE ERASE it.
