Soyo 6vba 133 OC'ing problem...
Omega Man
I'm trying to get my Soyo 6vba 133 motherboard to give me access to the 100 Mhz startup FSB (90-122 range).
I'm currently running a Celery 366 @ 445 with NO problems. I'd like to bump it up some more.
I've got one stick of good quality PC 133 ram (256 megs) in Dimm 4, like the Quick start guide says... it's running at 124 Mhz right now.
I've also got an AGP GeForce 2 MX running at factory specs.
When I remove Jumper 7 to ge access to the 100 Mhz FSB, my computer either won't post, or won't output display, I'm not sure which.
Anyone else run into this problem???
Odd, have you tried making it go up slowly, maybee try 85FSB, then 90FSB, then 100FSB. Maybee your chip just cant take it. I had a PII 300MHz that would boot up fine at 405MHz, But no way it would boot up at 450MHz. Good luck,. maybee try the voltages or something.
