- Apr 21, 2001
- Augusta Twp, MI
http://www.newegg.com/app/ViewProductDesc.asp?description=13-139-133&depa=0
Newegg was the cheapest on pricewatch for this board at $59.00, but now you can use a $10 MIR and get it for $49.00. SOYO has never been the best overclocker, but they sure are known for stability. So if you need a cheap, stable board with lots of features- go with newegg.
Specifications:
Chipset Type
VIA KT600
Chipset Description
VIA KT600 / 8237 chipset
Supports 266/333/400 MHz FSB
Graphics Info
AGP slot supporting up to 8X AGP
Form Factor
ATX
Memory Type
DDR400/333/266 SDRAM
Memory Description
Three DDR 2.5V DIMM sockets support up to 3GB (with 266 memory setting)
184-pin PC3200/PC2700/PC2100/PC1600 non-ECC, unbuffered DDR SDRAM memory
Click here for memory speed/CPU FSB compatibility information
Expansion Slots
Five 32-bit Bus Mastering PCI slots (V2.2 compliant)
One Universal 8X AGP slot (supports 8x/4x modes)
Expansion Slot Types
IDE Type
UDMA 66/100/133
IDE Description
2 channels Parallel ATA IDE ports
2 channels Serial ATA IDE ports
Supports RAID 0, 1
Supports up to PIO mode 5 & Ultra DMA 100/133
Audio Description
On board VIA 1616 6 channel CODEC
IO Port Description
Two RS-232 serial ports (16550 UART compatible)
One parallel printer port (SPP/EPP/ECP mode)
One FDD port (supports 3 modes, 1.2/1.44/2.88MB FDD)
Provides IrDA with optional cable for transceiver
Provides 8 USB 2.0 ports (4* rear, 4 pin header)
IO Connection Description
PS/2 Mini-DIN mouse & keyboard ports
Two USB 2.0 ports
One embedded RJ45 LAN connector (10/100)
Two D-Sub 9-pin male serial ports
One D-Sub 25-pin female printer port
Audio I/O: LINE-OUT x 1, LINE-IN x 1, MIC JACK x 1
One game port (Pin Header)
BIOS Description
Award PCI BIOS with ACPI function
Supports multiple-boot from E-IDE / SCSI / CD-ROM / FDD / LS120 / ZIP
2 Mbyte Flash ROM
Health Monitoring Description
On board voltage monitors
CPU fan speed monitor
CPU temperature monitoring through thermal sensor
CPU overheating protection
Dimension Description
Four layers, 30.5 cm x 22 cm (12" x 8.7")
ATX form factor
Certification
FCC Class B & CE EMI Regulation Compliant. PC99 Compliant
Compatibilities
WinXP / Win2000 / WinNT / WinME / Win98SE / Linux / FreeBSD
Warranty
All SOYO products are designed to offer stability and flexibility, and are tested to ensure highest reliability. We offer a 1 year limited warranty on this SOYO product.
$59.00 - $10.00 MIR = $49.00 + FREE SHIPPING
I'm pretty sure this is the same as the Ultra series, except it doesn't include gigabit lan, nor is it a spiffy platinum color, and it doesn't come with a card reader and whatever else SOYO includes with it. I'm a fan of SOYO because they are stable, and I'm considering upgrading from my KT333 Dragon to this one.
Specifications:
Chipset Type
VIA KT600
Chipset Description
Graphics Info
Form Factor
ATX
Memory Type
Memory Description
Expansion Slots
IDE Type
UDMA 66/100/133
IDE Description
Supports RAID 0, 1
Audio Description
IO Port Description
Two USB 2.0 ports
BIOS Description
2 Mbyte Flash ROM
ATX form factor
Certification
Compatibilities
Warranty
