SP97 too tight?
SilverJag
Chicago, IL
Hey all,
My friend bought the 947U on a A7N8X-E Deluxe and he said it was a bit to big for the board. Since the 97 is bigger, will it fit a A7N8X-E Deluxe, AMD 2500M?
archilochus said:
He means, Its the case clearence in this particular case..An interesting conundrum.:)
With my older case the power supply unit begins right at the edge of my mobo. I have been looking at buying an SP-97, but I noticed from pictures that the heatsink and fan clips rest beyond the edge of the mobo so if that is the case(no pun intended) then the SP-97 and the SLK heatsinks won't fit for me. I will probably buy a new case because I need better airflow anyway.
