- Mar 1, 2013
Has anyone quantified how the performance of a radiator+fans varies depending on the spacing between the two? (There will be a duct between the two so there won't be any flow bypassing the radiator.) I think increasing the spacing will improve flow in the areas of the radiator that would otherwise be covered by the "dead zones" of the fans, but beyond how much spacing does it get into diminishing returns? The radiator I'm using has a 127mm x 225mm finned area with a 20mm thickness, matched up to two 120mm fans.
It's actually for power electronics cooling rather than PC cooling (main difference is that power electronics will tolerate higher temperatures, 100C die temperature is well within ratings) and it's nonconductive mineral oil instead of water (water doesn't go well with 520V DC), but the general idea is the same.
