Speaker selection in control panel
ToiletDuck
In control panel it always shows under the speaker icon that I have 5.1 speaker system. So I go and select quadraphonic speakers. But then i hop in Desert Combat and all the sudden i must be in 5.1 again because i can't hear anything that should be center channel. So i check and sure enough it is abck at 5.1. If I play movies or whathave you it always goes back to 5.1 any idea why?
Duck
Th0r
England. Liverpool, Aintree
Maybe because your Soundblaster control panel is set to 5.1.... You have to select 4 speakers in the Soundblaster control panel....
Using the Standard windows one does not work if u have a second control panel doing what its told...
