- Mar 1, 2013
As many know, I have always been a disbeliever of fancy Monster Cables and similar, making the statement that a fancy cable cannot possibly make a noticeable audio quality improvement over a generic but decent cable. Every once in a great while, there would be a sale on some fancy audio or video cable that makes it cost about the same as a more ordinary cable. I did buy some, but they merely worked just as well as generic cables, not better.
A few weeks ago, an intern arrived at work and it became my task to teach her how to solder. At the same time, I needed an audio wiring harness made for a personal project (compact gaming/media center PC) I was doing. So rather than try to cobble up some "practice" setup for her to solder, I brought the unfinished harness to work - it just needed a little soldering. I had no difficulty getting her started and after a few minutes, all the connections were soldered. I checked everything with a multimeter and gave her the thumbs up.
When I got home and continued working on my personal project, I of course had to install and test the harness. I played a random MP3 (which I later found out was a horrible 128kbps) and it sounded like garbage. I cleaned the connections with no change. Before concluding that she must have made a cold solder joint that was adding distortion, I decided to try a FLAC file. Then the most magical thing happened - despite the signal coming from a $45 motherboard, it sounded unusually clear and high quality. So good, in fact, that it rivaled the audio quality of my main PC. In both cases, I was using a pair of Klipsch S3 for testing.
At that point, I was a little confused. The intern still needed a little more practice, so I decided to have her make another audio harness for my main PC. I installed it and loaded up a few FLACs. To say that the sound was amazing would be an understatement! She must have some magic charm that extracts every bit of performance out of a piece of audio electronics. The best part is that she actually enjoys doing it! Now I have a new best friend and a new appreciation for HD audio. (Before anyone gets the wrong idea, she's just a friend. She and I are now known as the "audio Mythbusters" by friends.)
Later, she soldered up a S/PDIF cable and a few power cables for me to test, which thus far did not perform any different from regular cables. I guess the "fancy cable" myth is busted for digital and power cables, but (conditionally) confirmed for analog cables.
