Gigabyte 9550 128
Was checking out ATI Tool for the first time .. and .. whenever the window with the floating furry box type thing is open something in my case starts to squeal!!!!!!!!!!!!!. Close the 3D box and noise goes away. Its pretty hard to tell if its the graphics card or the motherboard capacitors. The stock HSF is to bloody loud to let me hear exactly where the noise is coming from .. BUT .. it ONLY does it (so far) when that one box is open. I only have C&C Generals here to test so i installed it and played the first level (not very graphically intensive). It didn't make this noise while playing the game on high. *shrug*
.... any ideas? Let me guess .. this is normal and your comp does it to?!? *hopes* LOL
Edit: heres my specs if it helps
AMD Sempron 64BIT 2800+ Processor S754 Palermo 1.6GHZ 256K
GIGABYTE K8NS NFORCE3 250 ATHLON64 S754
OCZ Platinum EL PC3200 1GB DDR400 CL2-3-2-5
GIGABYTE GV-R955128D Radeon 9550 128MB 128BIT
2x MAXTOR DiamondMax 10 200GB IDE ATA133 7200RPM 16MB
Fortron FSP/SPI SAGA AX450-PN 450W
and my OC = Linky
Card is at stock speeds
Edit2: I UN-overclocked and tryed it ... it dosnt squeal *sigh*
and my OC = Linky
