ST6 AGP speed and core voltage?
Rmcky
When does the ST6 switch to 1/2 on the AGP divisor. I was under the impression that it didn't switch until it reached 133mhz FSB, but I'm running my system at 129mhz (which nets slightly over 130mhz according to CPUID) and my AGP seems just fine. I get the feeling that the board has already switched to the 1/2 divisor, since I don't believe my AGP bus would be happy at 87mhz, but I could be wrong.
Also, what is the max voltage adjustment in the BIOS for Tualatin Celeron CPUs? Mine only allows up to 1.6v, but I could have sworn that it used to allow 1.65. I'm probably wrong about that, but figured it wouldn't hurt to ask. If so, is the wire trick the only way to acheive 1.65v with this board?
Thanks, Rick
