stability question
mumrah
after troubles with overheating and reboots, i upped my vcore to 1.72 and ran prime95 for 10 hours with no errors or warnings and temps stayed below 60*C. so everything should run fine now, right?
(adding water cooling and second cpu soon, then i'll be folding 24/7 :D)
Sounds like something only needed a bit of burn-in. Burn-in works really well as it will allow you to run stable using lower voltage than it would normally need.
Craig
