Star Map Help
jdoyle
Connecticut
i have Windows 2000 professional (NT) on my new pc and i was wondering if anyone else has StarMap for Windows by Tobias
http://home.snafu.de/tobias.w/seti/starmap.html I dont know how to get the pathway for a graphical client dosent work dose anyone know how to make the command line for it work or what the command line is jimHELP Oh ya how do you overclock a pent 4 1.6 gig
jdoyle- It looks like a lot of Star Map was incorporated into Seti Queue. Even if you only crunch one system Seti Queue can be used. It makes Seti easier and give you a lot of information like the attached history.
http://www.setiqueue.org/download.asp
edit: I've run Seti Queue on both Windows NT 4.0 and Windows XP Professional. Should run ok on Win 2000 also.
Re: fixed ip
jdoyle said:
I dont have a fixed IP i am on DSL it changes every time i log on
That does not matter if it is running on your system. The queue will be for you only. Are you running spy/driver/clc? If so go to Work Unit tab there is a sky map button there it is all set up for you.
