- May 23, 2007
here is a screen of 30 minutes prime95.
the method was just to choose the 10% oc setting in the bios. its the asus m5a87 board. im wondering if 1.5 vcore on load is reasonable.
what about those high temps in speedfan ?
are those ram timings okay or should loosen/tighten them ?
do you think there is more headroom for higher clocks temperature-wise ?
system seems to be pretty stable, will check now how my 3dmark11 score compares to 3.0 ghz stock frequenzy..
any input is appreciated, since im not really experienced with overclocking, only did some light overclocking on unlocked amd's before..
edit: 3dmark 11
before / after
Graphics Score 3397 / 3411
Physics Score 2574 / 2858
edit: 3dmark 11
before / after
