static pressure
travenwatts
Southern Illinois
does the static pressure on a particular fan matter? I know the pressure goes up with increasing CFM, but does it have an affect on cooling? A fan with the same CFM might operate at a higher static pressure, so I was just wondering if it helped or hurt in any way.
T
travenwatts
Southern Illinois
i guess what i am wanting to know is, if i am looking for some case fans do i need to be concerned with static pressure?? i guess that would've been clearer if i said that the first time. :)
Since87
Indiana
If you are concerned with whether you have positive or negative case pressure, then yes you do need to be concerned with static pressure.
N
nerdlogic
Guest
Yes...Static pressure is important when you're planning on putting it atop a HS. You have to remember, though, that the bigger the fan, the less static pressure there is at an certain CFM. Say you get a 92mm fan and an 80mm fan and both put out 70 CFM of air...The 80mm fan will generate more static pressure than the 92mm fan.
