dustybyrd said:
that is an excellent review/guide cmcquistion...
the only comment I have would be that if you want higher than 2ghz overclocks with the AMD then I would get the Fortron/Sparkle 350 watt, 120 mm fan power supply that costs $45-55 at newegg.com and xpdirect.com
but for the budget minded and less than a 2ghz AMD, like you said, the 300 watt version can't be beat...
I'm testing a theory, right now, to see how good this 300 Watt Fortron is.
I took the 300 Watt Fortron and put it in my 2 GHz backup server/workstation.
It is running a XP2100 T-bred A, overclocked to 2 GHz @ 1.75 Vcore.
To stress out of the PSU and see how much it can take (since I don't have any CPU's capable of more than 2 GHz, here,) I put four CD-ROMs and four hard drives in the system. I actually ran out of four-pin molex connectors, so I had to use some splitters.
Even with four CD-ROMs, four Hard Drives, and an overclocked CPU, the system is running rock-solid. It has been running Prime95 for a while. I will let it run overnight, to guarantee stability. MBM's High/Low log shows that 3.3V line has been steady between 3.30 and 3.33V. The 5V line has been steady between 4.87 and 4.92V (normal for this board.) The 12V line is steady between 12.28 and 12.40V.
Although the 5V line may look a bit low, all of these voltages are the VERY CLOSE to the readings it was giving with the 525 Watt PSU I had in this system, previously. When I test the voltages, straight from a Molex, using my digital multimeter, I get 12.37 on the 12V line and 4.98 on the 5V line.
*EDIT* The Vcore, by the way, has only varied from 1.73 to 1.74V, according to MBM's High/Low log.
*EDIT AGAIN* Five and a half hours, so far, of Prime95, while also browsing, updating software, scanning pictures, and defragmenting hard drives. No problems, at all. I think this Fortron 300 is pretty powerful.
*EDIT 3* I ended up running all that gear in that machine for a few days. Never had a single problem. That PSU is a workhorse.
