Gilgamesh said:
What heatsink are you using? Aren't you the one mentioned in a recently post? (j/k)
The best thing you can do is to order a shim or cpu guard so you won't chip the cpu unless you apply 700lbs of preasure
I'm using a Thermo Engine 4210 (the cheapo one with the solid core) with a 80mm 3000 rpm fan. It does a decent job of cooling a XP
[email protected] 1.87v (150 fsb) 44c at idle/49 after an hour of playing Unreal Tournament..
It isn't the same HS that I chipped the cores with (a cheapo all copper job with a horrible clip that I picked up at the bargain bin at the local comp shop) so thats not too big of a deal.. I just don't want to take it off unless absolutely neccessary..
I was just curious if I had some kind of advantagious stepping that would allow me to reach 166 fsb with high quality memory (I have genric "elixir" branded DDR right now) and a good HSF..
Don't know what post you are talking about, but I doubt it was me...
