Ok..I got my artic silver and alpha heatsink in the mail today and was verry dissapointed to see that the alpha Pep66 font fit on the asus cusl2 mobo unless the fan is on top. The only problem with that is I have a mid-case, so the delta fan would be sitting flush with the psu (not good). So I was able to rig the power supply at the very top of the case giving me 1 and 1/4 inch breathing room for my fan (not a lot but best it could be). So I fired her up and at windows got an idle temp of 38C (i was gettin 41C w/ the chrome orb) and under load 49C (53C previosely). I tried switching the fan around to blow air instead of sucking....same results. My sistem is an 800EB @ 930 around w/ 1.9 voltage. My case runs cool its at 27C throught the ordeal.
So anyone have any idea why my temps are so high. I was hopping for a 10 degree drop w/ the alpha and artic silver but only got 3 degrees difference. My case is naked by the way for this so I can get in and out easy.
My possible ideas for problems.
1. Not enough clearence for the fan.
2. I have moved the heatsink a ton getting the fan and case on. Could I have spread the artic silver too thin?
3. It looks like I scratched the heatsink a tiny bit (who knows).
4. Those pads that it comes with are not allowing enough pressure between the heatsink and the processor.
Any help is MUCH appreciated.
I'll be messing around and sure to update soon.
