Stock fans on a Lian Li PC-6x case
Illah
San Francisco
I was wondering what kind of stock fans this case uses, mainly their CFM rating.
I wanted to improve the cooling in my case but I don't want to chop any more holes or anything like that, and replacing these with higher CFM fans seemed like an easy and cheap way to do it.
--Illah
Randy
Sedro Woolley, WA.
My Lian LI PC60 came with 26 cfm 80mm Adda fans I replaced them with 40cfm 80 mm sunnons and added a blow hole on top with an 80 mm Sunnon 40cfm. It was a definite improvment.
Randy
Illah
Illah
San Francisco
Sounds good, I'll probably end up switching the fans. This may sound dumb but how did you check? Does it say on the fan? I wanna see if mine has different fans than yours (probably not, but what the hell). I know the sunons are 40, so if mine has say, 35's, then it's not worth it (unless I go delta).
--Illah
AntiHeiss
Senior Member
Texas
As far as I know Lian-Li has always used Adda fans. Those are the same mine has and several others I have seen also. But yes the fan will (should) say Adda on it. As for the specific CFM of your fans...I don't think that is written on there.
