- Jun 26, 2014
So I'm planning on purchasing an FX-8350(because my poor Q6600 can only clock up to 3gigs and even then can't keep up with my r9 270x), with upgrading to an 9590 sometime in the later future if I decide that I can't get my 8350 to 5gigs without blowing up my rig. And naturally with that heater being put in my computer, the stock fan just isn't going to do. So I surfed newegg and decided that I wanted to try watercooling. Just to stick my toe in the pool, I decided with this:
Enermax Liqtech 240 All-in-One Liquid Cooler 27MM.
A dual radiator supporting two High Pressure 120MM fans.
After locating that, I realized that fans all have different stats and those are pretty freakin' important. SO, I did some MORE research into the fans, and found some other ones that are highly advertised and recommended.
Obviously, the Noctua fan series:
And I also looked up the Corsair SP120's:
To my surprise, the fans that come with the radiator blow the Noc and Corsair fans out of the water. I was told the Noc and Corsair were the best around, but the stock fans that come with the radiator rivals them in noise level (with the noc coming out only 8dB lower than the fastest the stock fans can run while holding a stead 30dB sound volume and blowing hte Corsair out with a lower sound volume of 5dB AND destroying it in terms of airflow) and kills with CFM and static pressure rating.
Now my issue is, am I overlooking something? Are there of features that the non-stock fans have that are worth considering (besides the noc's being quiet. I don't mind a little hum coming from my rig)? Or is this exactly the case and I'm just weird?
http://www.newegg.com/Product/Product.aspx?Item=N82E16835214058
Fan Stats:
Twister Bearing
MTBF ≥160,000 hours
Speed 600 - 1300 / 2000 / 2500RPM
Rated Voltage 12V
Rated Current 0.13A / 0.27A / 0.45A
Air Flow 28.6 ~ 60.3 / 88.9 / 111.0 CFM
48.5 ~ 102.4 / 150.9 / 188.7m³/h
Static Pressure 0.8 ~ 1.7 / 4.7 / 7.4mm - H2O
Noise Level 15 ~ 21.5 / 27 / 30dBA
Connector 4-pin PWM
Fan Stats:
Twister Bearing
MTBF ≥160,000 hours
Rated Voltage 12V
Connector 4-pin PWM
http://www.noctua.at/main.php?show=productview&products_id=42&lng=en&set=1
Fan Stats:
Size 120x120x25 mm
Connector 4-pin PWM
Bearing SSO2
Blade Geometry Heptaperf™
Frame Technology Focused Flow™
Rotational Speed (+/- 10%) 1500 RPM
Rotational Speed with L.N.A. (+/- 10%) 1200 RPM
Min. Rotational Speed (PWM, +/-20%) 300 RPM
Airflow 93,4 m³/h
Airflow with L.N.A. 74,3 m³/h
Acoustical Noise 22,4 dB(A)
Acoustical Noise with L.N.A. 18,6 dB(A)
Static Pressure 2,61 mm H2O
Static Pressure with L.N.A. 1,83 mm H2O
Max. Input Power 0,6 W
Max. Input Current 0,05 A
Voltage 12 V
Fan Stats:
Size 120x120x25 mm
Connector 4-pin PWM
Bearing SSO2
Airflow 93,4 m³/h
Voltage 12 V
http://www.newegg.com/Product/Product.aspx?Item=35-181-040
Fan Stats:
Fan Size 120mm
Bearing Type Hydraulic
RPM 2350 RPM
Air Flow 62.74 CFM
Noise Level 35 dBA
Static Pressure 3.1
Fan Stats:
Fan Size 120mm
RPM 2350 RPM
Air Flow 62.74 CFM
Noise Level 35 dBA
Static Pressure 3.1
