First was my ATI 8500dv AIW card - completely stock, default settings in BIOS, & even tried locking PCI/AGP, yet card would get very hot - could burn your finger on back of card, behind GPU. This was on my Albatron PX845PEV Pro mobo. Originally just figured the card was going bad, so upped the cooling & hoped it lived.
Just recently got an Abit BH7 to replace the Albatron, 845PE as well, and temporarily put in a GeForce2 GTS, and it's doing the exact same thing. Takes about 5 min to get to burnage temps
Default settings here as well, also tried locking bus speeds. The ATI was never in this board, yet.
Cooling is not an issue at all. The stock HSFs have since been upgraded. Internal case temps aren't high at all, even with open side & a Comair Rotron blowing on the cards & ambient room temps ~70deg F.
Both cards worked fine in my 2 Abit KA7 Athlon boards without ANY heat problems.
They were hooked up to a KVM, but then tested with a few different monitors - no change in results.
Unless I'm just missing something, the only link I can currently see is both are now on 845PE chipset boards.
Any ideas?
Any ideas?
