Well I cant really run many programs since my mother board wont boot up half the time. I got it to run this morning and I had left it on until about 7:00 pm this evening. I have been doing homework and I let it sit for about 2 hours. It went into the crazy non responsive mode and I restart. nothing....black....so i left it of for .5 hours. came back still nothing. I booted up my dads cpu and here I am.
ARG I will deffinetly backup all my stuff once I get my baby booted up....if it will again. I need to reformat the thing anyways (I try to do that every 6-8 months) its been awhile since I last did that. I wonder if it is somthing to do with my water cooler but if condensation did get to it. Why after several hours be fine? I mean if water did get on the board would it just fry it after times? I also think it might have somthing to do with a scree nsaver I got from Nvidia ( Anark somthing it was called) because it seems when it turned on. but i uninstalled it (as best I could) and it happened again. And I wouldnt think it would totaly stop my mobo from booting up but.....you never know with windows. Anyways I will tinker with my hardware tonight but in the mean time here is my system specs: I have a mini fridge, in that is a gallon resivor and an underwater pump. I cut the freezer tray so it dips into my water. I use 20/10 for fluid. 2 tubes come out of my fridge. one for going one for coming. thoughs tubes are braided to stop kinking. they are insulated with ameraflex insualtion tape. they go all the way inside my computer to the Gold 200w Koolance water block ( I kinda got pushed into it ok, not the best but it proforms pretty well). My mobo is sealed with RTV sealent around the sides and the middle inside. Dielectric grease is used to seal the chip, ameraflex is used to all the way around the whole socket. there is RTV sealent also on te back pins and a square of Ameraflex is also on thoughs. My cpu systems specs are in my sig. So what should I do from here? Should I plug my HD into my dads cpu and make sure its not the problem? Should I check the connections of all my PCI cards?....replys are welcomed :d Thx for reading.
oh ya I dont have a wirless mouse or keyboard. my mouse is usb optical and my keyboard is usb too.
