- Jan 24, 2006
- South Dakota
So I just upgraded to a new Sandy Bridge kit tonight and I am having some strange happenings.
I have run all the updates and did a fresh install of Mint 11 (but I also tested the problem with the live cd of Mint 10, and Mythbuntu 10.10)
Basically the computer boots and loads fine but 3 of the hard drives aren't being detected properly.
Fdisk sees them
But they arent being picked up by udev
If I hot plug them (unplug the sata and plug it back it) udev picks them up just fine
I have swapped the cables out and its obviously not a power issue
here is dmesg
anyone have any insight into this? I guess I could test this by throwing my sata card in there and take these guys off the motherboard to see if that helps... would suck to have to return th emobo already
Fdisk sees them
Code:
Disk /dev/sda: 2000.4 GB, 2000398934016 bytes
255 heads, 63 sectors/track, 243201 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x00082dea
Device Boot Start End Blocks Id System
/dev/sda1 1 243201 1953512001 83 Linux
Disk /dev/sdb: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x0003af64
/dev/sdb1 1 243201 1953512001 83 Linux
Disk /dev/sdc: 1500.3 GB, 1500301910016 bytes
255 heads, 63 sectors/track, 182401 cylinders
Disk identifier: 0x00006514
/dev/sdc1 1 182401 1465136001 83 Linux
Disk /dev/sdd: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0x000536fe
/dev/sdd1 1 182401 1465136001 83 Linux
Disk /dev/sde: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0x0003261d
/dev/sde1 1 182401 1465136001 83 Linux
Disk /dev/sdf: 1500.3 GB, 1500301910016 bytes
Disk identifier: 0x0009687a
/dev/sdf1 * 1 3040 24413184 83 Linux
/dev/sdf2 3040 182402 1440722945 5 Extended
/dev/sdf5 3040 21276 146483200 83 Linux
/dev/sdf6 21276 21519 1951744 82 Linux swap / Solaris
/dev/sdf7 21520 182402 1292285952 83 Linux
Disk /dev/sdg: 2000.4 GB, 2000398934016 bytes
Disk identifier: 0x0009d72a
/dev/sdg1 1 243201 1953512001 83 Linux
Code:
ls /dev/sd* |grep 1
/dev/sda1
/dev/sdb1
/dev/sdf1
/dev/sdg1
here is dmesg
Code:
[ 1.827663] ata1: SATA max UDMA/133 abar m2048@0xfb625000 port 0xfb625100 irq 48
[ 1.827665] ata2: SATA max UDMA/133 abar m2048@0xfb625000 port 0xfb625180 irq 48
[ 1.827667] ata3: SATA max UDMA/133 abar m2048@0xfb625000 port 0xfb625200 irq 48
[ 1.827669] ata4: SATA max UDMA/133 abar m2048@0xfb625000 port 0xfb625280 irq 48
[ 1.827670] ata5: SATA max UDMA/133 abar m2048@0xfb625000 port 0xfb625300 irq 48
[ 1.827672] ata6: SATA max UDMA/133 abar m2048@0xfb625000 port 0xfb625380 irq 48
[ 1.827694] ahci 0000:05:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 1.827839] ahci 0000:05:00.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 1.827848] ahci 0000:05:00.0: flags: 64bit ncq pm led clo pmp pio slum part
[ 1.827861] ahci 0000:05:00.0: setting latency timer to 64
[ 1.828099] scsi6 : ahci
[ 1.828236] scsi7 : ahci
[ 1.828274] ata7: SATA max UDMA/133 abar m512@0xfb410000 port 0xfb410100 irq 19
[ 1.828277] ata8: SATA max UDMA/133 abar m512@0xfb410000 port 0xfb410180 irq 19
[ 1.828289] ahci 0000:09:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 1.828371] ahci 0000:09:00.0: irq 49 for MSI/MSI-X
[ 1.828469] ahci 0000:09:00.0: AHCI 0001.0000 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[ 1.828470] ahci 0000:09:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[ 1.828475] ahci 0000:09:00.0: setting latency timer to 64
[ 1.828830] scsi8 : ahci
[ 1.828958] scsi9 : ahci
[ 1.829004] ata9: SATA max UDMA/133 abar m512@0xfb110000 port 0xfb110100 irq 49
[ 1.829008] ata10: SATA max UDMA/133 abar m512@0xfb110000 port 0xfb110180 irq 49
[ 1.882839] hub 1-1:1.0: USB hub found
[ 1.882935] hub 1-1:1.0: 6 ports detected
[ 1.962102] Refined TSC clocksource calibration: 3310.800 MHz.
[ 1.962107] Switching to clocksource tsc
[ 1.994071] usb 2-1: new high speed USB device using ehci_hcd and address 2
[ 2.078053] firewire_core: created device fw0: GUID 001fc60000108c2c, S400
[ 2.126610] hub 2-1:1.0: USB hub found
[ 2.126724] hub 2-1:1.0: 8 ports detected
[ 2.145956] ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 2.145961] ata8: SATA link down (SStatus 0 SControl 300)
[ 2.145996] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.146031] ata7: SATA link down (SStatus 0 SControl 300)
[ 2.146041] ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.146056] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.146094] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.149004] ata4.00: ATAPI: HL-DT-ST DVDRAM GH22NS50, TN01, max UDMA/100
[ 2.149387] ata1.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[ 2.149392] ata1.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.152825] ata4.00: configured for UDMA/100
[ 2.153127] ata1.00: configured for UDMA/133
[ 2.153354] scsi 0:0:0:0: Direct-Access ATA WDC WD20EARS-00M 51.0 PQ: 0 ANSI: 5
[ 2.153458] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.153533] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 2.153569] sd 0:0:0:0: [sda] Write Protect is off
[ 2.153571] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.153585] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.174666] ata3.00: ATA-8: ST31500341AS, CC1H, max UDMA/133
[ 2.174671] ata3.00: 2930277168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.174693] ata6.00: ATA-8: ST31500341AS, CC1H, max UDMA/133
[ 2.174696] ata6.00: 2930277168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.174801] ata5.00: ATA-8: ST31500341AS, CC1H, max UDMA/133
[ 2.174806] ata5.00: 2930277168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[ 2.216556] ata3.00: configured for UDMA/133
[ 2.216574] ata6.00: configured for UDMA/133
[ 2.216785] ata5.00: configured for UDMA/133
[ 2.257818] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.263173] ata2.00: ATA-8: WDC WD20EARS-00J2GB0, 80.00A80, max UDMA/133
[ 2.263178] ata2.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[ 2.269173] ata2.00: configured for UDMA/133
[ 2.269342] scsi 1:0:0:0: Direct-Access ATA WDC WD20EARS-00J 80.0 PQ: 0 ANSI: 5
[ 2.269427] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 2.269440] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 2.269520] scsi 2:0:0:0: Direct-Access ATA ST31500341AS CC1H PQ: 0 ANSI: 5
[ 2.269531] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.269533] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.269569] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.269599] sd 2:0:0:0: [sdc] 2930277168 512-byte logical blocks: (1.50 TB/1.36 TiB)
[ 2.269616] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 2.269631] sd 2:0:0:0: [sdc] Write Protect is off
[ 2.269633] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 2.269645] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.273019] scsi 3:0:0:0: CD-ROM HL-DT-ST DVDRAM GH22NS50 TN01 PQ: 0 ANSI: 5
[ 2.279783] sdc: sdc1
[ 2.280211] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 2.282142] sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
[ 2.282147] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.282257] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 2.282287] sr 3:0:0:0: Attached scsi generic sg3 type 5
[ 2.282418] scsi 4:0:0:0: Direct-Access ATA ST31500341AS CC1H PQ: 0 ANSI: 5
[ 2.282530] sd 4:0:0:0: Attached scsi generic sg4 type 0
[ 2.282642] sd 4:0:0:0: [sdd] 2930277168 512-byte logical blocks: (1.50 TB/1.36 TiB)
[ 2.282699] scsi 5:0:0:0: Direct-Access ATA ST31500341AS CC1H PQ: 0 ANSI: 5
[ 2.282789] sd 5:0:0:0: Attached scsi generic sg5 type 0
[ 2.282806] sd 5:0:0:0: [sde] 2930277168 512-byte logical blocks: (1.50 TB/1.36 TiB)
[ 2.282866] sd 4:0:0:0: [sdd] Write Protect is off
[ 2.282868] sd 4:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 2.282942] sd 4:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.282967] sd 5:0:0:0: [sde] Write Protect is off
[ 2.282970] sd 5:0:0:0: [sde] Mode Sense: 00 3a 00 00
[ 2.283021] sd 5:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.295459] sdd: sdd1
[ 2.295798] sd 4:0:0:0: [sdd] Attached SCSI disk
[ 2.297489] sde: sde1
[ 2.297682] sd 5:0:0:0: [sde] Attached SCSI disk
[ 2.297934] sdb: sdb1
[ 2.298350] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.317764] ata9: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.321146] ata9.00: ATA-8: WDC WD15EADS-00P8B0, 01.00A01, max UDMA/133
[ 2.321151] ata9.00: 2930277168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.325205] ata9.00: configured for UDMA/133
[ 2.325401] scsi 8:0:0:0: Direct-Access ATA WDC WD15EADS-00P 01.0 PQ: 0 ANSI: 5
[ 2.325489] sd 8:0:0:0: Attached scsi generic sg6 type 0
[ 2.325518] sd 8:0:0:0: [sdf] 2930277168 512-byte logical blocks: (1.50 TB/1.36 TiB)
[ 2.325557] sd 8:0:0:0: [sdf] Write Protect is off
[ 2.325558] sd 8:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[ 2.325573] sd 8:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.381855] sdf: sdf1 sdf2 < sdf5 sdf6 sdf7 >
[ 2.382425] sd 8:0:0:0: [sdf] Attached SCSI disk
[ 2.397869] usb 2-1.2: new low speed USB device using ehci_hcd and address 3
[ 2.429650] ata10: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.433779] ata10.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[ 2.433784] ata10.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 2.454931] ata10.00: configured for UDMA/133
[ 2.455143] scsi 9:0:0:0: Direct-Access ATA WDC WD20EARS-00M 51.0 PQ: 0 ANSI: 5
[ 2.455239] sd 9:0:0:0: Attached scsi generic sg7 type 0
[ 2.455275] sd 9:0:0:0: [sdg] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 2.455386] sd 9:0:0:0: [sdg] Write Protect is off
[ 2.455388] sd 9:0:0:0: [sdg] Mode Sense: 00 3a 00 00
[ 2.455460] sd 9:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.463882] sdg: sdg1
[ 2.464197] sd 9:0:0:0: [sdg] Attached SCSI disk
[ 2.565260] sda: sda1
[ 2.565582] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.565657] usb 2-1.7: new full speed USB device using ehci_hcd and address 4
[ 2.573244] input: Logitech Trackball as /devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1.2/2-1.2:1.0/input/input3
[ 2.573318] generic-usb 0003:046D:C404.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech Trackball] on usb-0000:00:1d.0-1.2/input0
[ 2.573327] usbcore: registered new interface driver usbhid
[ 2.573328] usbhid: USB HID core driver
[ 3.718244] xor: automatically using best checksumming function: pIII_sse
[ 3.736384] pIII_sse : 16695.000 MB/sec
[ 3.736387] xor: using function: pIII_sse (16695.000 MB/sec)
[ 3.737988] device-mapper: dm-raid45: initialized v0.2594b
[ 4.009356] Btrfs loaded
[ 4.494533] EXT4-fs (sdf1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.601237] <30>udev[506]: starting version 167
[ 11.626933] lp: driver loaded but no devices found
[ 11.633959] nvidia: module license 'NVIDIA' taints kernel.
[ 11.633962] Disabling lock debugging due to kernel taint
[ 11.666573] xhci_hcd 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
[ 11.666589] xhci_hcd 0000:03:00.0: setting latency timer to 64
[ 11.666593] xhci_hcd 0000:03:00.0: xHCI Host Controller
[ 11.666631] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 3
[ 11.694030] Adding 1951740k swap on /dev/sdf6. Priority:-1 extents:1 across:1951740k
[ 11.707939] Bluetooth: Core ver 2.15
[ 11.707953] NET: Registered protocol family 31
[ 11.707954] Bluetooth: HCI device and connection manager initialized
[ 11.707955] Bluetooth: HCI socket layer initialized
[ 11.711018] Bluetooth: Generic Bluetooth USB driver ver 0.6
[ 11.711177] usbcore: registered new interface driver btusb
[ 11.741563] HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
[ 11.741601] HDA Intel 0000:00:1b.0: irq 50 for MSI/MSI-X
[ 11.741619] HDA Intel 0000:00:1b.0: setting latency timer to 64
[ 11.759935] input: Eee PC WMI hotkeys as /devices/platform/eeepc-wmi/input/input4
[ 11.792207] hda_codec: ALC892: BIOS auto-probing.
[ 11.798316] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1b.0/sound/card0/input5
[ 11.996030] nvidia 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 11.996036] nvidia 0000:01:00.0: setting latency timer to 64
[ 11.996039] vgaarb: device changed decodes: PCI:0000:01:00.0,olddecodes=io+mem,decodes=none:owns=io+mem
[ 11.996092] NVRM: loading NVIDIA UNIX x86 Kernel Module 270.41.06 Mon Apr 18 14:54:25 PDT 2011
[ 12.008871] xhci_hcd 0000:03:00.0: irq 17, io mem 0xfb500000
[ 12.008930] xhci_hcd 0000:03:00.0: irq 51 for MSI/MSI-X
[ 12.008933] xhci_hcd 0000:03:00.0: irq 52 for MSI/MSI-X
[ 12.008935] xhci_hcd 0000:03:00.0: irq 53 for MSI/MSI-X
[ 12.008938] xhci_hcd 0000:03:00.0: irq 54 for MSI/MSI-X
[ 12.008940] xhci_hcd 0000:03:00.0: irq 55 for MSI/MSI-X
[ 12.012296] usb usb3: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
[ 12.012368] xHCI xhci_add_endpoint called for root hub
[ 12.012369] xHCI xhci_check_bandwidth called for root hub
[ 12.012388] hub 3-0:1.0: USB hub found
[ 12.012390] hub 3-0:1.0: 4 ports detected
[ 12.012457] xhci_hcd 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 12.012467] xhci_hcd 0000:06:00.0: setting latency timer to 64
[ 12.012469] xhci_hcd 0000:06:00.0: xHCI Host Controller
[ 12.012497] xhci_hcd 0000:06:00.0: new USB bus registered, assigned bus number 4
[ 12.028820] xhci_hcd 0000:06:00.0: irq 16, io mem 0xfb300000
[ 12.028878] xhci_hcd 0000:06:00.0: irq 56 for MSI/MSI-X
[ 12.028880] xhci_hcd 0000:06:00.0: irq 57 for MSI/MSI-X
[ 12.028883] xhci_hcd 0000:06:00.0: irq 58 for MSI/MSI-X
[ 12.028885] xhci_hcd 0000:06:00.0: irq 59 for MSI/MSI-X
[ 12.028887] xhci_hcd 0000:06:00.0: irq 60 for MSI/MSI-X
[ 12.032238] usb usb4: No SuperSpeed endpoint companion for config 1 interface 0 altsetting 0 ep 129: using minimum values
[ 12.032292] xHCI xhci_add_endpoint called for root hub
[ 12.032293] xHCI xhci_check_bandwidth called for root hub
[ 12.032309] hub 4-0:1.0: USB hub found
[ 12.032311] hub 4-0:1.0: 4 ports detected
[ 12.328843] vesafb: framebuffer at 0xf9000000, mapped to 0xfa100000, using 1216k, total 1216k
[ 12.328845] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 12.328846] vesafb: scrolling: redraw
[ 12.328848] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 12.328914] Console: switching to colour frame buffer device 80x30
[ 12.340907] fb0: VESA VGA frame buffer device
[ 12.346380] EXT4-fs (sdf1): re-mounted. Opts: errors=remount-ro
[ 12.483002] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.494294] EXT4-fs (sdf5): mounted filesystem with ordered data mode. Opts: (null)
[ 12.963623] EXT4-fs (sdf7): mounted filesystem with ordered data mode. Opts: (null)
[ 12.991976] EXT4-fs (sdg1): mounted filesystem with ordered data mode. Opts: (null)
