- Sep 20, 2006
- Hawaii
I found a strange file on my secondary HDD that I know I didn't make.
It's called: 6b5965e623973149ce6c6a86
In it is a txt document that's titled: msxml4-KB927978-enu
In it is this text. It starts with Verbose, never found anything titled that online. I skimmed though it and there doesn't seem to be anything sensitive outside from my username and stuff which I've changed since then, so I'll post all of it. If you see something however...well crap.
=== Verbose logging started: 1/12/2007 3:00:16 Build type: SHIP UNICODE 3.01.4000.2435 Calling process: C:\WINDOWS\system32\msiexec.exe ===
MSI (c) (3C:B4) [03:00:16:781]: Resetting cached policy values
MSI (c) (3C:B4) [03:00:16:781]: Machine policy value 'Debug' is 0
MSI (c) (3C:B4) [03:00:16:781]: ******* RunEngine:
******* Product: e:\6b5965e623973149ce6c6a86\msxml.msi
******* Action:
******* CommandLine: **********
MSI (c) (3C:B4) [03:00:16:781]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (3C:B4) [03:00:16:781]: Grabbed execution mutex.
MSI (c) (3C:B4) [03:00:16:843]: Cloaking enabled.
MSI (c) (3C:B4) [03:00:16:843]: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (3C:B4) [03:00:16:843]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F0:98) [03:00:16:859]: Grabbed execution mutex.
MSI (s) (F0:00) [03:00:16:859]: Resetting cached policy values
MSI (s) (F0:00) [03:00:16:859]: Machine policy value 'Debug' is 0
MSI (s) (F0:00) [03:00:16:859]: ******* RunEngine:
******* Action:
MSI (s) (F0:00) [03:00:16:859]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (F0:00) [03:00:16:859]: File will have security applied from OpCode.
MSI (s) (F0:00) [03:00:16:906]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'e:\6b5965e623973149ce6c6a86\msxml.msi' against software restriction policy
MSI (s) (F0:00) [03:00:16:906]: SOFTWARE RESTRICTION POLICY: e:\6b5965e623973149ce6c6a86\msxml.msi has a digital signature
MSI (s) (F0:00) [03:00:32:359]: SOFTWARE RESTRICTION POLICY: e:\6b5965e623973149ce6c6a86\msxml.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (F0:00) [03:00:32:359]: End dialog not enabled
MSI (s) (F0:00) [03:00:32:359]: Original package ==> e:\6b5965e623973149ce6c6a86\msxml.msi
MSI (s) (F0:00) [03:00:32:359]: Package we're running from ==> C:\WINDOWS\Installer\4055dd2.msi
MSI (s) (F0:00) [03:00:32:390]: APPCOMPAT: looking for appcompat database entry with ProductCode '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'.
MSI (s) (F0:00) [03:00:32:390]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (F0:00) [03:00:32:390]: MSCOREE not loaded loading copy from system32
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'TransformsSecure' is 0
MSI (s) (F0:00) [03:00:32:390]: User policy value 'TransformsAtSource' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'DisablePatch' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (F0:00) [03:00:32:390]: Transforms are not secure.
MSI (s) (F0:00) [03:00:32:390]: Command Line: REBOOT=ReallySuppress CURRENTDIRECTORY=e:\6b5965e623973149ce6c6a86 CLIENTUILEVEL=3 CLIENTPROCESSID=1596
MSI (s) (F0:00) [03:00:32:390]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{2B27DCD9-53FA-4885-B6CD-698623819F4C}'.
MSI (s) (F0:00) [03:00:32:390]: Product Code passed to Engine.Initialize: ''
MSI (s) (F0:00) [03:00:32:390]: Product Code from property table before transforms: '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'
MSI (s) (F0:00) [03:00:32:390]: Product Code from property table after transforms: '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'
MSI (s) (F0:00) [03:00:32:390]: Product not registered: beginning first-time install
MSI (s) (F0:00) [03:00:32:390]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (F0:00) [03:00:32:390]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (F0:00) [03:00:32:390]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (F0:00) [03:00:32:390]: Adding new sources is allowed.
MSI (s) (F0:00) [03:00:32:390]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:390]: Package name extracted from package path: 'msxml.msi'
MSI (s) (F0:00) [03:00:32:390]: Package to be registered: 'msxml.msi'
MSI (s) (F0:00) [03:00:32:390]: Note: 1: 2729
MSI (s) (F0:00) [03:00:32:406]: Note: 1: 2729
MSI (s) (F0:00) [03:00:32:406]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (F0:00) [03:00:32:406]: Machine policy value 'DisableMsi' is 0
MSI (s) (F0:00) [03:00:32:406]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:406]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:406]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (F0:00) [03:00:32:406]: Running product '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}' with elevated privileges: Product is assigned.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'e:\6b5965e623973149ce6c6a86'.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '1596'.
MSI (s) (F0:00) [03:00:32:406]: TRANSFORMS property is now:
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Application Data
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Favorites
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\NetHood
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\My Documents
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\PrintHood
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Recent
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\SendTo
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Templates
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application Data
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Local Settings\Application Data
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\My Documents\My Pictures
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Desktop
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Start Menu\Programs\Administrative Tools
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Start Menu\Programs\Startup
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Desktop
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (F0:00) [03:00:32:453]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (F0:00) [03:00:32:453]: MSCOREE not loaded loading copy from system32
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:453]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'ArchangelGabe'.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Section 13'.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\WINDOWS\Installer\4055dd2.msi'.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'e:\6b5965e623973149ce6c6a86\msxml.msi'.
MSI (s) (F0:00) [03:00:32:453]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (F0:00) [03:00:32:453]: Machine policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:32:453]: User policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
=== Logging started: 1/12/2007 3:00:32 ===
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (F0:00) [03:00:32:453]: Doing action: INSTALL
MSI (s) (F0:00) [03:00:32:453]: Running ExecuteSequence
MSI (s) (F0:00) [03:00:32:453]: Doing action: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901
Action start 3:00:32: INSTALL.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Desktop\'.
Action start 3:00:32: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901.
MSI (s) (F0:00) [03:00:32:453]: Doing action: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901
Action ended 3:00:32: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901. Return value 1.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Start Menu\Programs\'.
Action start 3:00:32: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901.
MSI (s) (F0:00) [03:00:32:453]: Doing action: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537
Action ended 3:00:32: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901. Return value 1.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\'.
Action start 3:00:32: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:453]: Doing action: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537
Action ended 3:00:32: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537
Action ended 3:00:32: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\'.
Action start 3:00:32: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537
Action ended 3:00:32: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
Action ended 3:00:32: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\'.
Action start 3:00:32: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
Action ended 3:00:32: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB
Action ended 3:00:32: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1
Action ended 3:00:32: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7
Action ended 3:00:32: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7.
MSI (s) (F0:00) [03:00:32:468]: Doing action: LaunchConditions
Action ended 3:00:32: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7. Return value 1.
Action start 3:00:32: LaunchConditions.
MSI (s) (F0:00) [03:00:32:468]: Doing action: FindRelatedProducts
Action ended 3:00:32: LaunchConditions. Return value 1.
Action start 3:00:32: FindRelatedProducts.
MSI (s) (F0:00) [03:00:32:468]: Doing action: AppSearch
Action ended 3:00:32: FindRelatedProducts. Return value 1.
Action start 3:00:32: AppSearch.
MSI (s) (F0:00) [03:00:32:468]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding WINHTTP_51 property. Its value is 'WinHttpRequest Component version 5.1'.
MSI (s) (F0:00) [03:00:32:468]: Skipping action: CCPSearch (condition is false)
MSI (s) (F0:00) [03:00:32:468]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (F0:00) [03:00:32:468]: Doing action: ValidateProductID
Action ended 3:00:32: AppSearch. Return value 1.
Action start 3:00:32: ValidateProductID.
MSI (s) (F0:00) [03:00:32:468]: Doing action: CostInitialize
Action ended 3:00:32: ValidateProductID. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: Machine policy value 'MaxPatchCacheSize' is 10
Action start 3:00:32: CostInitialize.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'e:\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: Patch
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: __MsiPatchFileList
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2228 2: 3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
MSI (s) (F0:00) [03:00:32:484]: Doing action: FileCost
Action ended 3:00:32: CostInitialize. Return value 1.
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: FileCost.
MSI (s) (F0:00) [03:00:32:484]: Doing action: CostFinalize
Action ended 3:00:32: FileCost. Return value 1.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'e:\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 property. Its value is 'C:\Program Files\Common Files\Microsoft Shared\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 property. Its value is 'C:\Program Files\Common Files\Microsoft Shared\MSDN\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Manifests\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_policy.4.20.microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_a6dfa6920e9f98fc\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Manifests\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_microsoft.msxml2r_6bd6b9abf345378f_4.1.0.0_none_3658456fda6654f6\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Manifests\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_b7e10f227b2fceff\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MSXML property. Its value is 'C:\Program Files\MSXML 4.0\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding INC.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Program Files\MSXML 4.0\inc\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding LIB.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Program Files\MSXML 4.0\lib\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding DOC.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Program Files\MSXML 4.0\doc\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\'.
MSI (s) (F0:00) [03:00:32:484]: Target path resolution complete. Dumping Directory table...
MSI (s) (F0:00) [03:00:32:484]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: TARGETDIR , Object: e:\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files\Common Files\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: C:\Program Files\Common Files\Microsoft Shared\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: C:\Program Files\Common Files\Microsoft Shared\MSDN\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Manifests\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_policy.4.20.microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_a6dfa6920e9f98fc\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Manifests\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_microsoft.msxml2r_6bd6b9abf345378f_4.1.0.0_none_3658456fda6654f6\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Manifests\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_b7e10f227b2fceff\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: DesktopFolder , Object: C:\Documents and Settings\All Users\Desktop\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MSXML , Object: C:\Program Files\MSXML 4.0\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: INC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Program Files\MSXML 4.0\inc\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: LIB.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Program Files\MSXML 4.0\lib\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: DOC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Program Files\MSXML 4.0\doc\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Documents and Settings\All Users\Start Menu\Programs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Documents and Settings\All Users\Desktop\
Action start 3:00:32: CostFinalize.
MSI (s) (F0:00) [03:00:32:593]: Doing action: SetODBCFolders
Action ended 3:00:32: CostFinalize. Return value 1.
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action start 3:00:32: SetODBCFolders.
MSI (s) (F0:00) [03:00:32:593]: Doing action: MigrateFeatureStates
Action ended 3:00:32: SetODBCFolders. Return value 0.
Action start 3:00:32: MigrateFeatureStates.
MSI (s) (F0:00) [03:00:32:593]: Doing action: InstallValidate
Action ended 3:00:32: MigrateFeatureStates. Return value 0.
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXML; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSYS; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSUPP; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSUPP2; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSXS; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: XMLSDK; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: RememberInstallFolder; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: QKBKEY; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: MSXML4_System.246EB7AD_459A_4FA8_83D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: MSXML4_SystemRes.246EB7AD_459A_4FA8_83D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: MSXML4_ANSI.246EB7AD_459A_4FA8_83D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: WINHTTP50_COMPONENT.781A0624_31FF_4712_BFFD_31C829FFDBF1; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: PROXYCFG_COMPONENT.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: uplevel.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: uplevel.DA6654F6_456F_3658_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: uplevel.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: XMLSDK_Docs.4576A2F1_959E_4BCA_94A9_596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: XMLSDK_LIB.4576A2F1_959E_4BCA_94A9_596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: XMLSDK_INC.4576A2F1_959E_4BCA_94A9_596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: CookDoc_dll.3FB7DAB3_19E7_40A0_8730_4482CE77AC59; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __uplevel.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __uplevel.DA6654F6_456F_3658_FF6B_D6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __uplevel.0E9F98FC_A692_A6DF_FF6B_D6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __QKBKEY65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __MSXML4_System.246EB7AD_459A_4FA8_83D1_4165; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_payload.7B2FCEFF_0F22_B7E1_FF665; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_manifest.7B2FCEFF_0F22_B7E1_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_payload.DA6654F6_456F_3658_FF665; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_manifest.DA6654F6_456F_3658_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_manifest.0E9F98FC_A692_A6DF_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __CookDoc_dll.3FB7DAB3_19E7_40A0_8730_448265; Installed: Null; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __XMLSDK_Docs.4576A2F1_959E_4BCA_94A9_596565; Installed: Null; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: BindImage
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: Font
Action start 3:00:32: InstallValidate.
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (s) (F0:00) [03:00:32:593]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2727 2:
MSI (s) (F0:00) [03:00:32:609]: Note: 1: 2727 2:
MSI (s) (F0:00) [03:00:32:609]: Doing action: InstallInitialize
Action ended 3:00:32: InstallValidate. Return value 1.
MSI (s) (F0:00) [03:00:32:609]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:609]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:609]: BeginTransaction: Locking Server
MSI (s) (F0:00) [03:00:32:609]: SRSetRestorePoint skipped for this transaction.
MSI (s) (F0:00) [03:00:32:609]: Server not locked: locking for product {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Action start 3:00:32: InstallInitialize.
MSI (s) (F0:00) [03:00:32:625]: Doing action: SxsInstallCA
Action ended 3:00:32: InstallInitialize. Return value 1.
MSI (s) (F0:0C) [03:00:32:640]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI42.tmp, Entrypoint: CustomAction_SxsMsmInstall
MSI (s) (F0:E0) [03:00:32:640]: Generating random cookie.
MSI (s) (F0:E0) [03:00:32:640]: Created Custom Action Server with PID 2896 (0xB50).
MSI (s) (F0:08) [03:00:32:671]: Running as a service.
MSI (s) (F0:08) [03:00:32:671]: Hello, I'm your 32bit Elevated custom action server.
Action start 3:00:32: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1306 4: 0
1: sxsdelca 2: traceop 3: 1307 4: 0
1: sxsdelca 2: traceop 3: 796 4: 0
1: sxsdelca 2: traceop 3: 801 4: 0
1: sxsdelca 2: traceop 3: 802 4: 0
1: sxsdelca 2: traceop 3: 803 4: 0
1: sxsdelca 2: traceop 3: 805 4: 0
1: sxsdelca 2: traceop 3: 812 4: 0
1: sxsdelca 2: traceop 3: 813 4: 0
1: sxsdelca 2: traceop 3: 814 4: 0
1: sxsdelca 2: traceop 3: 819 4: 0
1: sxsdelca 2: traceop 3: 820 4: 0
1: sxsdelca 2: traceop 3: 821 4: 0
1: sxsdelca 2: traceop 3: 827 4: 0
1: sxsdelca 2: traceop 3: 831 4: 0
1: sxsdelca 2: traceop 3: 827 4: 259
1: sxsdelca 2: traceop 3: 1311 4: 0
1: sxsdelca 2: traceop 3: 1312 4: 0
1: sxsdelca 2: traceop 3: 1077 4: 0
1: sxsdelca 2: traceop 3: 1081 4: 0
1: sxsdelca 2: traceop 3: 1083 4: 0
1: sxsdelca 2: traceop 3: 1087 4: 0
1: sxsdelca 2: traceop 3: 1093 4: 0
1: sxsdelca 2: traceop 3: 1097 4: 0
1: sxsdelca 2: traceop 3: 1101 4: 0
1: sxsdelca 2: traceop 3: 1105 4: 0
1: sxsdelca 2: traceop 3: 1109 4: 0
1: sxsdelca 2: traceop 3: 1113 4: 0
1: sxsdelca 2: traceop 3: 1117 4: 0
1: sxsdelca 2: traceop 3: 1121 4: 0
1: sxsdelca 2: traceop 3: 1313 4: 0
1: sxsdelca 2: traceop 3: 1314 4: 0
1: sxsdelca: Added reg value for 2: downlevel_manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
MSI (s) (F0:00) [03:00:32:812]: Doing action: AllocateRegistrySpace
Action ended 3:00:32: SxsInstallCA. Return value 1.
Action start 3:00:32: AllocateRegistrySpace.
MSI (s) (F0:00) [03:00:32:812]: Doing action: ProcessComponents
Action ended 3:00:32: AllocateRegistrySpace. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2205 2: 3: MsiPatchCertificate
MSI (s) (F0:00) [03:00:32:812]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (F0:00) [03:00:32:812]: Resolving source.
MSI (s) (F0:00) [03:00:32:812]: Resolving source to launched-from source.
MSI (s) (F0:00) [03:00:32:812]: Setting launched-from source as last-used.
MSI (s) (F0:00) [03:00:32:812]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'e:\6b5965e623973149ce6c6a86\'.
MSI (s) (F0:00) [03:00:32:812]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'e:\6b5965e623973149ce6c6a86\'.
MSI (s) (F0:00) [03:00:32:812]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'.
MSI (s) (F0:00) [03:00:32:812]: SOURCEDIR ==> e:\6b5965e623973149ce6c6a86\
MSI (s) (F0:00) [03:00:32:812]: SOURCEDIR product ==> {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
MSI (s) (F0:00) [03:00:32:812]: Determining source type
MSI (s) (F0:00) [03:00:32:812]: Source type from package 'msxml.msi': 2
Action start 3:00:32: ProcessComponents.
MSI (s) (F0:00) [03:00:32:812]: Source path resolution complete. Dumping Directory table...
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: TARGETDIR , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: CommonFilesFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Microsoft Shared\ , ShortSubPath: MICROS~1\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Microsoft Shared\MSDN\ , ShortSubPath: MICROS~1\MSDN\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\k0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\h0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\i0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\j0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\8n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\6n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\5n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\7n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\wl34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ul34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\tl34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\vl34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: System\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: DesktopFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: ProgramFilesFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MSXML , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: INC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\inc\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: LIB.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\lib\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: DOC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\doc\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\MSXML 4.0\ , ShortSubPath: redist\MSXML4\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnpublishComponents
Action ended 3:00:32: ProcessComponents. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action start 3:00:32: UnpublishComponents.
MSI (s) (F0:00) [03:00:32:812]: Doing action: MsiUnpublishAssemblies
Action ended 3:00:32: UnpublishComponents. Return value 1.
Action start 3:00:32: MsiUnpublishAssemblies.
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnpublishFeatures
Action ended 3:00:32: MsiUnpublishAssemblies. Return value 1.
Action start 3:00:32: UnpublishFeatures.
MSI (s) (F0:00) [03:00:32:812]: Doing action: StopServices
Action ended 3:00:32: UnpublishFeatures. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2205 2: 3: ServiceControl
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2228 2: 3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 3:00:32: StopServices.
MSI (s) (F0:00) [03:00:32:812]: Doing action: DeleteServices
Action ended 3:00:32: StopServices. Return value 1.
Action start 3:00:32: DeleteServices.
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnregisterComPlus
Action ended 3:00:32: DeleteServices. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2205 2: 3: Complus
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2228 2: 3: Complus 4: SELECT `ComponentId`, `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed` FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action start 3:00:32: UnregisterComPlus.
MSI (s) (F0:00) [03:00:32:812]: Doing action: SelfUnregModules
Action ended 3:00:32: UnregisterComPlus. Return value 0.
Action start 3:00:32: SelfUnregModules.
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnregisterTypeLibraries
Action ended 3:00:32: SelfUnregModules. Return value 1.
Action start 3:00:32: UnregisterTypeLibraries.
MSI (s) (F0:00) [03:00:32:812]: Doing action: RemoveODBC
Action ended 3:00:32: UnregisterTypeLibraries. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: ODBCDataSource
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `Translator`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2711 2: ODBCDriverManager
Action start 3:00:32: RemoveODBC.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterFonts
Action ended 3:00:32: RemoveODBC. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: Font
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action start 3:00:32: UnregisterFonts.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveRegistryValues
Action ended 3:00:32: UnregisterFonts. Return value 1.
Action start 3:00:32: RemoveRegistryValues.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterClassInfo
Action ended 3:00:32: RemoveRegistryValues. Return value 1.
Action start 3:00:32: UnregisterClassInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterExtensionInfo
Action ended 3:00:32: UnregisterClassInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: UnregisterExtensionInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterProgIdInfo
Action ended 3:00:32: UnregisterExtensionInfo. Return value 1.
Action start 3:00:32: UnregisterProgIdInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterMIMEInfo
Action ended 3:00:32: UnregisterProgIdInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2262 2: MIME 3: -2147287038
Action start 3:00:32: UnregisterMIMEInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveIniValues
Action ended 3:00:32: UnregisterMIMEInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: IniFile
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action start 3:00:32: RemoveIniValues.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveShortcuts
Action ended 3:00:32: RemoveIniValues. Return value 1.
Action start 3:00:32: RemoveShortcuts.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveEnvironmentStrings
Action ended 3:00:32: RemoveShortcuts. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: Environment
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action start 3:00:32: RemoveEnvironmentStrings.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveDuplicateFiles
Action ended 3:00:32: RemoveEnvironmentStrings. Return value 1.
Action start 3:00:32: RemoveDuplicateFiles.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveFiles
Action ended 3:00:32: RemoveDuplicateFiles. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: RemoveFile
Action start 3:00:32: RemoveFiles.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveFolders
Action ended 3:00:32: RemoveFiles. Return value 0.
Action start 3:00:32: RemoveFolders.
MSI (s) (F0:00) [03:00:32:828]: Doing action: CreateFolders
Action ended 3:00:32: RemoveFolders. Return value 1.
Action start 3:00:32: CreateFolders.
MSI (s) (F0:00) [03:00:32:828]: Doing action: MoveFiles
Action ended 3:00:32: CreateFolders. Return value 1.
Action start 3:00:32: MoveFiles.
MSI (s) (F0:00) [03:00:32:828]: Doing action: InstallFiles
Action ended 3:00:32: MoveFiles. Return value 1.
Action start 3:00:32: InstallFiles.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: Patch
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: Patch 4: SELECT `Patch`.`File_`, `Patch`.`Header`, `Patch`.`Attributes`, `Patch`.`Sequence`, `Patch`.`StreamRef_` FROM `Patch` WHERE `Patch`.`File_` = ? AND `Patch`.`#_MsiActive`=? ORDER BY `Patch`.`Sequence`
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (F0:00) [03:00:32:843]: Doing action: PatchFiles
Action ended 3:00:32: InstallFiles. Return value 1.
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2205 2: 3: Patch
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2228 2: 3: Patch 4: SELECT `File`,`FileName`,`FileSize`,`Directory_`,`PatchSize`,`File`.`Attributes`,`Patch`.`Attributes`,`Patch`.`Sequence`,`Component`.`Component`,`Component`.`ComponentId` FROM `File`,`Component`,`Patch` WHERE `Patch`.`#_MsiActive`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
Action start 3:00:32: PatchFiles.
MSI (s) (F0:00) [03:00:32:843]: Doing action: DuplicateFiles
Action ended 3:00:32: PatchFiles. Return value 0.
Action start 3:00:32: DuplicateFiles.
MSI (s) (F0:00) [03:00:32:843]: Doing action: BindImage
Action ended 3:00:32: DuplicateFiles. Return value 1.
Action start 3:00:32: BindImage.
MSI (s) (F0:00) [03:00:32:843]: Doing action: CreateShortcuts
Action ended 3:00:32: BindImage. Return value 1.
Action start 3:00:32: CreateShortcuts.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterClassInfo
Action ended 3:00:32: CreateShortcuts. Return value 1.
Action start 3:00:32: RegisterClassInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterExtensionInfo
Action ended 3:00:32: RegisterClassInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: RegisterExtensionInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterProgIdInfo
Action ended 3:00:32: RegisterExtensionInfo. Return value 1.
Action start 3:00:32: RegisterProgIdInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterMIMEInfo
Action ended 3:00:32: RegisterProgIdInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2262 2: MIME 3: -2147287038
Action start 3:00:32: RegisterMIMEInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: WriteRegistryValues
Action ended 3:00:32: RegisterMIMEInfo. Return value 1.
Action start 3:00:32: WriteRegistryValues.
MSI (s) (F0:00) [03:00:32:859]: Doing action: WriteIniValues
Action ended 3:00:32: WriteRegistryValues. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: IniFile
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action start 3:00:32: WriteIniValues.
MSI (s) (F0:00) [03:00:32:859]: Doing action: WriteEnvironmentStrings
Action ended 3:00:32: WriteIniValues. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: Environment
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action start 3:00:32: WriteEnvironmentStrings.
MSI (s) (F0:00) [03:00:32:859]: Doing action: RegisterFonts
Action ended 3:00:32: WriteEnvironmentStrings. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: Font
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action start 3:00:32: RegisterFonts.
MSI (s) (F0:00) [03:00:32:859]: Doing action: InstallODBC
Action ended 3:00:32: RegisterFonts. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `Translator`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: ODBCDataSource
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action start 3:00:32: InstallODBC.
MSI (s) (F0:00) [03:00:32:859]: Doing action: RegisterTypeLibraries
Action ended 3:00:32: InstallODBC. Return value 0.
Action start 3:00:32: RegisterTypeLibraries.
MSI (s) (F0:00) [03:00:32:875]: Doing action: SelfRegModules
Action ended 3:00:32: RegisterTypeLibraries. Return value 1.
Action start 3:00:32: SelfRegModules.
MSI (s) (F0:00) [03:00:32:875]: Doing action: RegisterComPlus
Action ended 3:00:32: SelfRegModules. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2205 2: 3: Complus
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2228 2: 3: Complus 4: SELECT `ComponentId`, `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed` FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action start 3:00:32: RegisterComPlus.
MSI (s) (F0:00) [03:00:32:875]: Doing action: InstallServices
Action ended 3:00:32: RegisterComPlus. Return value 0.
MSI (s) (F0:00) [03:00:32:875]: Detected older ServiceInstall table schema
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2205 2: 3: ServiceInstall
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2228 2: 3: ServiceInstall 4: SELECT `Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action start 3:00:32: InstallServices.
MSI (s) (F0:00) [03:00:32:875]: Doing action: StartServices
Action ended 3:00:32: InstallServices. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2205 2: 3: ServiceControl
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2228 2: 3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 3:00:32: StartServices.
MSI (s) (F0:00) [03:00:32:875]: Doing action: RegisterUser
Action ended 3:00:32: StartServices. Return value 1.
Action start 3:00:32: RegisterUser.
MSI (s) (F0:00) [03:00:32:875]: Doing action: RegisterProduct
Action ended 3:00:32: RegisterUser. Return value 1.
Action start 3:00:32: RegisterProduct.
MSI (s) (F0:00) [03:00:32:875]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:875]: Doing action: PublishComponents
Action ended 3:00:32: RegisterProduct. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action start 3:00:32: PublishComponents.
MSI (s) (F0:00) [03:00:32:875]: Doing action: MsiPublishAssemblies
Action ended 3:00:32: PublishComponents. Return value 1.
Action start 3:00:32: MsiPublishAssemblies.
MSI (s) (F0:00) [03:00:32:875]: Doing action: PublishFeatures
Action ended 3:00:32: MsiPublishAssemblies. Return value 1.
Action start 3:00:32: PublishFeatures.
MSI (s) (F0:00) [03:00:32:875]: Doing action: PublishProduct
Action ended 3:00:32: PublishFeatures. Return value 1.
Action start 3:00:32: PublishProduct.
MSI (s) (F0:00) [03:00:32:875]: Doing action: InstallFinalize
Action ended 3:00:32: PublishProduct. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Running Script: C:\WINDOWS\Installer\MSI43.tmp
MSI (s) (F0:00) [03:00:32:875]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:875]: Machine policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:32:890]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F0:00) [03:00:32:890]: Executing op: Header(Signature=1397708873,Version=301,Timestamp=908859409,LangId=1033,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
Action start 3:00:32: InstallFinalize.
MSI (s) (F0:00) [03:00:32:890]: Executing op: ProductInfo(ProductKey={37477865-A3F1-4772-AD43-AAFC6BCFF99F},ProductName=MSXML 4.0 SP2 (KB927978),PackageName=msxml.msi,Language=1033,Version=68429425,Assignment=1,ObsoleteArg=0,,,PackageCode={2B27DCD9-53FA-4885-B6CD-698623819F4C},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0)
MSI (s) (F0:00) [03:00:32:890]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (F0:00) [03:00:32:890]: Executing op: DialogInfo(Type=1,Argument=MSXML 4.0 SP2 (KB927978))
MSI (s) (F0:00) [03:00:32:890]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (F0:00) [03:00:32:890]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (F0:00) [03:00:32:890]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (F0:00) [03:00:32:890]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (F0:00) [03:00:32:890]: Executing op: ProgressTotal(Total=5,Type=1,ByteEquivalent=24000)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={E9BC82F6-AC0E-407C-8666-619D6D60DF2B},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\6F28CB9EE0CAC704686616D9D606FDB2 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={81754FFD-DA2B-49C6-9447-E1C1E1733BB6},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\DFF45718B2AD6C9449741E1C1E37B36B 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={5E6714E1-EA46-4B0F-B479-06D87058DC74},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\1E4176E564AEF0B44B97608D0785CD47 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={57E0F99D-E884-4BD0-B8CB-803CF9EA2066},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\D99F0E75488E0DB48BBC08C39FAE0266 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={C763CD13-6E1E-4166-8C78-D274B266E9B6},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\31DC367CE1E66614C8872D472B669E6B 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ProgressTotal(Total=14,Type=1,ByteEquivalent=24000)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={4075CDF6-D88F-4F57-AF1A-29A124755695},KeyPath=C:\Program Files\MSXML 4.0\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={D21D9CCD-C3FA-4D72-982F-C29A2DE361EC},KeyPath=02:\Software\Microsoft\Updates\MSXML4SP2\Q927978\Description,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={4B1F71A7-50C6-44B7-A3AD-B6C3574BB896},KeyPath=C:\WINDOWS\system32\msxml4.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={62846705-2671-4547-AB45-854DCC93B3C7},KeyPath=C:\WINDOWS\system32\msxml4r.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={3AAE95CD-F592-46E7-89A1-9B56717C4413},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={CCF8B6EF-5FB9-4DE1-A276-683008BA3485},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={7B2FCEFF-0F22-B7E1-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_manifest\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_payload\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={DA6654F6-456F-3658-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={DA6654F6-456F-3658-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_manifest\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={DA6654F6-456F-3658-B06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_payload\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={0E9F98FC-A692-A6DF-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\downlevel_manifest\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200)
MSI (s) (F0:00) [03:00:32:906]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ProgressTick()
MSI (s) (F0:00) [03:00:32:906]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
MSI (s) (F0:00) [03:00:32:921]: Executing op: FolderCreate(Folder=C:\Program Files\MSXML 4.0\,Foreign=0,)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1], Directory: [9], Size: [6])
MSI (s) (F0:00) [03:00:32:921]: Executing op: ProgressTotal(Total=2604004,Type=0,ByteEquivalent=1)
MSI (s) (F0:00) [03:00:32:921]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\system32\)
MSI (s) (F0:00) [03:00:32:921]: Executing op: SetSourceFolder(Folder=1\System\)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_Core.cab,BytesPerTick=32768,CopierType=2,ModuleFileName=C:\WINDOWS\Installer\4055dd2.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (F0:00) [03:00:32:921]: Executing op: FileCopy(SourceName=msxml4.dll,SourceCabKey=msxml4.dll.246EB7AD_459A_4FA8_83D1_41A46D7634B7,DestName=msxml4.dll,Attributes=512,FileSize=1245696,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=4.20.9841.0,Language=0,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:32:953]: File: C:\WINDOWS\system32\msxml4.dll; Overwrite; Won't patch; Existing file is a lower version
MSI (s) (F0:00) [03:00:32:953]: Source for file 'msxml4.dll.246EB7AD_459A_4FA8_83D1_41A46D7634B7' is compressed
MSI (s) (F0:00) [03:00:32:953]: Re-applying security from existing file.
MSI (s) (F0:00) [03:00:32:953]: Verifying accessibility of file: msxml4.dll
MSI (s) (F0:00) [03:00:32:953]: SOFTWARE RESTRICTION POLICY: Verifying object --> 'C:\WINDOWS\Installer\4055dd2.msi' against software restriction policy
MSI (s) (F0:00) [03:00:32:953]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\4055dd2.msi has a digital signature
MSI (s) (F0:00) [03:00:33:000]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\4055dd2.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (F0:00) [03:00:33:000]: Note: 1: 2318 2: C:\WINDOWS\system32\msxml4.dll
MSI (s) (F0:00) [03:00:33:015]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:031]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:062]: Executing op: FileCopy(SourceName=msxml4r.dll,SourceCabKey=msxml4r.dll.246EB7AD_459A_4FA8_83D1_41A46D7634B7,DestName=msxml4r.dll,Attributes=512,FileSize=82432,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=4.10.9404.0,Language=1033,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\system32\msxml4r.dll; Won't Overwrite; Won't patch; Existing file is of an equal version
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\manifest\|Windows\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: FileCopy(SourceName=xl34x2va.rt8|x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest,SourceCabKey=manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest,,FileSize=3973,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-85909274,HashPart2=-393638470,HashPart3=495071453,HashPart4=945762879,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:078]: Source for file 'manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:078]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest
MSI (s) (F0:00) [03:00:33:078]: Executing op: FileCopy(SourceName=yl34x2va.rt8|x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat,SourceCabKey=catalog.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat,,FileSize=8347,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-1679697816,HashPart2=1808584787,HashPart3=1425912084,HashPart4=629236904,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:078]: Source for file 'catalog.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:078]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\tl34x2va.rt8\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: FileCopy(SourceName=1m34x2va.rt8|msxml4.dll,SourceCabKey=msxml4.dll.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537,DestName=msxml4.dll,,FileSize=1245696,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,Version=4.20.9841.0,Language=0,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\msxml4.dll; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:078]: Source for file 'msxml4.dll.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:093]: Note: 1: 2318 2: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\msxml4.dll
MSI (s) (F0:00) [03:00:33:093]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:109]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:125]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:156]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:156]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\manifest\|Windows\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:156]: Executing op: FileCopy(SourceName=9n0mtfut.k85|x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest,SourceCabKey=manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest,,FileSize=500,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-707213148,HashPart2=1938794768,HashPart3=-933075776,HashPart4=-843550219,,)
MSI (s) (F0:00) [03:00:33:156]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:156]: Source for file 'manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:156]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest
MSI (s) (F0:00) [03:00:33:171]: Executing op: FileCopy(SourceName=an0mtfut.k85|x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat,SourceCabKey=catalog.DA6654F6_456F_3658_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat,,FileSize=8349,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-1336197992,HashPart2=-627824155,HashPart3=82633343,HashPart4=1105156543,,)
MSI (s) (F0:00) [03:00:33:171]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:171]: Source for file 'catalog.DA6654F6_456F_3658_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:171]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\5n0mtfut.k85\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: FileCopy(SourceName=dn0mtfut.k85|msxml4r.dll,SourceCabKey=msxml4r.dll.DA6654F6_456F_3658_FF6B_D6B9ABF34537,DestName=msxml4r.dll,,FileSize=82432,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,Version=4.10.9404.0,Language=1033,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:33:187]: File: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\msxml4r.dll; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:187]: Source for file 'msxml4r.dll.DA6654F6_456F_3658_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:187]: Note: 1: 2318 2: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\msxml4r.dll
MSI (s) (F0:00) [03:00:33:187]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\Policies\i0r1wg7y.dqe\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: FileCopy(SourceName=l0r1wg7y.dqe|4.20.9841.0.policy,SourceCabKey=manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537,DestName=4.20.9841.0.policy,,FileSize=652,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=49613189,HashPart2=1139053242,HashPart3=-1699064514,HashPart4=-854272932,,)
MSI (s) (F0:00) [03:00:33:187]: File: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.policy; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:187]: Source for file 'manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:187]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.policy
MSI (s) (F0:00) [03:00:33:203]: Executing op: FileCopy(SourceName=m0r1wg7y.dqe|4.20.9841.0.cat,SourceCabKey=catalog.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537,DestName=4.20.9841.0.cat,,FileSize=8359,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-861819424,HashPart2=1423527147,HashPart3=-1146259424,HashPart4=2040409349,,)
MSI (s) (F0:00) [03:00:33:203]: File: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.cat; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:203]: Source for file 'catalog.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:203]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.cat
MSI (s) (F0:00) [03:00:33:203]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_SDK.cab,BytesPerTick=32768,CopierType=2,ModuleFileName=C:\WINDOWS\Installer\4055dd2.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (F0:00) [03:00:33:203]: Executing op: CacheSizeFlush(,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: InstallProtectedFiles(AllowUI=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: ActionStart(Name=WriteRegistryValues,Description=Writing system registry values,Template=Key: [1], Name: [2], Value: [3])
MSI (s) (F0:00) [03:00:33:203]: Executing op: ProgressTotal(Total=112,Type=1,ByteEquivalent=13200)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=XML DOM Document 4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=Msxml2.DOMDocument.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=Msxml2.DOMDocument.4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value={F5078F18-C551-11D3-89B9-0000F81FE221},)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=Msxml2.DOMDocument.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value={88D969C0-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=Free Threaded XML DOM Document 4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=Msxml2.FreeThreadedDOMDocument.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=Msxml2.FreeThreadedDOMDocument.4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.FreeThreadedDOMDocument.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={88D969C1-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=XML Data Source Object 4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.DSOControl.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.DSOControl.4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={F5078F18-C551-11D3-89B9-0000F81FE221},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.DSOControl.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={88D969C4-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=XML HTTP 4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.XMLHTTP.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.XMLHTTP.4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.XMLHTTP.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={88D969C5-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Server XML HTTP 4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.ServerXMLHTTP.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.ServerXMLHTTP.4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.ServerXMLHTTP.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={88D969C6-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=XML Schema Cache 4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XMLSchemaCache.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=Msxml2.XMLSchemaCache.4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XMLSchemaCache.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={88D969C2-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=XSL Template 4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XSLTemplate.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=Msxml2.XSLTemplate.4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XSLTemplate.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={88D969C3-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=SAX XML Reader 4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.SAXXMLReader.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=Msxml2.SAXXMLReader.4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.SAXXMLReader.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{00B7E0AB-817A-44AD-A04B-D1148D524136},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=MX XML Reader 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{00B7E0AB-817A-44AD-A04B-D1148D524136}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=MXXMLWriter 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXXMLWriter.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=Msxml2.MXXMLWriter.4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXXMLWriter.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value={88D969C8-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=MXHTMLWriter 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXHTMLWriter.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=Msxml2.MXHTMLWriter.4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXHTMLWriter.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value={88D969C9-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=SAXAttributes 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.SAXAttributes.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=Msxml2.SAXAttributes.4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.SAXAttributes.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value={88D969CA-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=MXNamespaceManager 4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=Msxml2.MXNamespaceManager.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=MXNamespaceManager 4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=Msxml2.MXNamespaceManager.4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=Msxml2.MXNamespaceManager.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value={88D969D6-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Updates\MSXML4SP2\Q927978,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=Description,Value=FIX: ASP stops responding when calling Response.Redirect to another server using msxml4 sp2,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=InstalledDate,Value=1/12/2007,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=InstalledBy,Value=ArchangelGabe,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=IsInstalled,Value=#1,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=ServicePack,Value=#1,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=Microsoft XML, v4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\0\win32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\FLAGS,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\HELPDIR,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_payload,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_manifest,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_payload,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_manifest,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\downlevel_manifest,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Windows\CurrentVersion\SideBySide\PatchedComponents,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name={7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name={7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\\msxml4.dll[~]{7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\[~]{7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name={DA6654F6-456F-3658-C06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:281]: Executing op: RegAddValue(Name={DA6654F6-456F-3658-B06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\\msxml4r.dll[~]{DA6654F6-456F-3658-B06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\[~]{DA6654F6-456F-3658-B06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:281]: Executing op: RegAddValue(Name={0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\\4.20.9841.0.policy[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\\4.20.9841.0.cat[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:281]: Executing op: ActionStart(Name=RegisterTypeLibraries,Description=Registering type libraries,Template=LibID: [1])
MSI (s) (F0:00) [03:00:33:281]: Executing op: TypeLibraryRegister(,,FilePath=C:\WINDOWS\system32\msxml4.dll,LibID={F5078F18-C551-11D3-89B9-0000F81FE221},Version=1024,,Language=0,,BinaryType=0,IgnoreRegistrationFailure=0)
MSI (s) (F0:00) [03:00:33:281]: QueryPathOfRegTypeLib returned 0 in local context. Path is 'C:\WINDOWS\system32\msxml4.dll'
MSI (s) (F0:00) [03:00:33:281]: Note: 1: 1402 2: UNKNOWN\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\400.0\0\win32 3: 2
MSI (s) (F0:00) [03:00:33:281]: CMsiServices:
rocessTypeLibrary runs in local context, not impersonated.
MSI (s) (F0:00) [03:00:33:343]: ProcessTypeLibraryCore returns: 0. (0 means OK)
MSI (s) (F0:00) [03:00:33:343]: CMsiServices:
MSI (s) (F0:00) [03:00:33:343]: Executing op: ActionStart(Name=RegisterUser,Description=Registering user,Template=[1])
MSI (s) (F0:00) [03:00:33:343]: Executing op: UserRegister(Owner=ArchangelGabe,Company=Section 13,ProductId=none)
MSI (s) (F0:00) [03:00:33:343]: Executing op: ActionStart(Name=RegisterProduct,Description=Registering product,Template=[1])
MSI (s) (F0:00) [03:00:33:343]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_Core.cab,BytesPerTick=0,CopierType=2,ModuleFileName=C:\WINDOWS\Installer\4055dd2.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (F0:00) [03:00:33:343]: Executing op: DatabaseCopy(DatabasePath=C:\WINDOWS\Installer\4055dd2.msi,ProductCode={37477865-A3F1-4772-AD43-AAFC6BCFF99F},CabinetStreams=XML_Core.cab;XML_SDK.cab,,)
MSI (s) (F0:00) [03:00:33:375]: Executing op: ProductRegister(UpgradeCode={7CE723E3-E56B-432C-9F24-78C0606045A5},VersionString=4.20.9841.0,HelpLink=http://support.microsoft.com/kb/927...6b5965e623973149ce6c6a86\,Publisher=Microsoft Corporation,,,,,,,,,,,,EstimatedSize=2625)
MSI (s) (F0:00) [03:00:33:375]: Executing op: ProductCPDisplayInfoRegister()
MSI (s) (F0:00) [03:00:33:375]: Executing op: ActionStart(Name=PublishFeatures,Description=Publishing Product Features,Template=Feature: [1])
MSI (s) (F0:00) [03:00:33:375]: Executing op: FeaturePublish(Feature=MSXML,,Absent=2,Component=MF}e835XRAhvfl[X%h~W(s-UlQ2mt@MgogY-xd{t)
MSI (s) (F0:00) [03:00:33:375]: Executing op: FeaturePublish(Feature=MSXMLSYS,Parent=MSXML,Absent=2,Component=V2?0@7$9*=IdbugpYRMX}GHaGLdZ==A&kv@Y~]3iui-r60O)l=Em%pCn7G4))
MSI (s) (F0:00) [03:00:33:390]: Executing op: FeaturePublish(Feature=MSXMLSUPP2,Parent=MSXML,Absent=2,Component=?`ZsjqO[%A*`NW3OG&nR)
MSI (s) (F0:00) [03:00:33:390]: Executing op: FeaturePublish(Feature=MSXMLSXS,Parent=MSXML,Absent=2,Component=LdCZOHqG+dpWsfdDE!j5LdCZOHqG+d6XsfdDE!j5LdCZOHqG+d%XsfdDE!j5`DM4olJ_O5pWsfdDE!j5`DM4olJ_O56XsfdDE!j5`DM4olJ_O5%XsfdDE!j5l0Rd'9?m^^pWsfdDE!j5l0Rd'9?m^^6XsfdDE!j5)
MSI (s) (F0:00) [03:00:33:390]: Executing op: FeaturePublish(Feature=XMLSDK,,Absent=3,Component=mk`[Q=PRe?RvYBgpXHXc5~{DF_B]-@1_XLnB~RWMMvh8D]u5G@j^sM7=J&oH0G,*i]!a$9uKNVM3Kykc)
MSI (s) (F0:00) [03:00:33:390]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
MSI (s) (F0:00) [03:00:33:390]: Executing op: IconCreate(Icon=icon.exe,Data=BinaryData)
MSI (s) (F0:00) [03:00:33:406]: Executing op: CleanupConfigData()
MSI (s) (F0:00) [03:00:33:406]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\568774731F3A2774DA34AACFB6FC9FF9\Patches 3: 2
MSI (s) (F0:00) [03:00:33:406]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=0)
MSI (s) (F0:00) [03:00:33:406]: Note: 1: 1402 2: UNKNOWN\Products\568774731F3A2774DA34AACFB6FC9FF9\Patches 3: 2
MSI (s) (F0:00) [03:00:33:406]: Executing op: ProductPublish(PackageKey={2B27DCD9-53FA-4885-B6CD-698623819F4C})
MSI (s) (F0:00) [03:00:33:406]: Note: 1: 1402 2: UNKNOWN\Installer\Products\568774731F3A2774DA34AACFB6FC9FF9 3: 2
MSI (s) (F0:00) [03:00:33:421]: Note: 1: 1402 2: UNKNOWN\Installer\Products\568774731F3A2774DA34AACFB6FC9FF9 3: 2
MSI (s) (F0:00) [03:00:33:421]: Executing op: UpgradeCodePublish(UpgradeCode={7CE723E3-E56B-432C-9F24-78C0606045A5})
MSI (s) (F0:00) [03:00:33:421]: Executing op: SourceListPublish(,,,,NumberOfDisks=2)
MSI (s) (F0:00) [03:00:33:421]: Note: 1: 1402 2: UNKNOWN\Installer\Products\568774731F3A2774DA34AACFB6FC9FF9\SourceList 3: 2
MSI (s) (F0:00) [03:00:33:421]: Executing op: ProductPublishClient(,,)
MSI (s) (F0:00) [03:00:33:421]: Executing op: SourceListRegisterLastUsed(SourceProduct={37477865-A3F1-4772-AD43-AAFC6BCFF99F},LastUsedSource=e:\6b5965e623973149ce6c6a86\)
MSI (s) (F0:00) [03:00:33:421]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (F0:00) [03:00:33:421]: Specifed source is already in a list.
MSI (s) (F0:00) [03:00:33:421]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (F0:00) [03:00:33:421]: Machine policy value 'DisableBrowse' is 0
MSI (s) (F0:00) [03:00:33:421]: Machine policy value 'AllowLockdownBrowse' is 0
MSI (s) (F0:00) [03:00:33:421]: Adding new sources is allowed.
MSI (s) (F0:00) [03:00:33:421]: Set LastUsedSource to: e:\6b5965e623973149ce6c6a86\.
MSI (s) (F0:00) [03:00:33:421]: Set LastUsedType to: n.
MSI (s) (F0:00) [03:00:33:421]: Set LastUsedIndex to: 1.
MSI (s) (F0:00) [03:00:33:421]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=4564804)
MSI (s) (F0:00) [03:00:33:421]: User policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:33:421]: Machine policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:33:437]: No System Restore sequence number for this installation.
MSI (s) (F0:00) [03:00:33:437]: Unlocking Server
MSI (s) (F0:00) [03:00:33:437]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
MSI (s) (F0:00) [03:00:33:437]: Skipping action: SxsUninstallCA (condition is false)
MSI (s) (F0:00) [03:00:33:437]: Doing action: RemoveExistingProducts
Action ended 3:00:33: InstallFinalize. Return value 1.
Action start 3:00:33: RemoveExistingProducts.
Action ended 3:00:33: RemoveExistingProducts. Return value 1.
Action ended 3:00:33: INSTALL. Return value 1.
Property(S): ProductName = MSXML 4.0 SP2 (KB927978)
Property(S): ProductCode = {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Property(S): Manufacturer = Microsoft Corporation
Property(S): ProductVersion = 4.20.9841.0
Property(S): ProductLanguage = 1033
Property(S): BannerBitmap = bannrbmp
Property(S): IAgree = No
Property(S): ProductID = none
Property(S): ARPHELPLINK = http://support.microsoft.com/kb/927978
Property(S): ButtonText_Back = < &Back
Property(S): ButtonText_Browse = Br&owse
Property(S): ButtonText_Cancel = Cancel
Property(S): ButtonText_Exit = &Exit
Property(S): ButtonText_Finish = &Finish
Property(S): ButtonText_Ignore = &Ignore
Property(S): ButtonText_Install = &Install
Property(S): ButtonText_InstallNow = &Install Now
Property(S): ButtonText_Next = &Next >
Property(S): ButtonText_No = &No
Property(S): ButtonText_OK = OK
Property(S): ButtonText_Remove = &Remove
Property(S): ButtonText_Reset = &Reset
Property(S): ButtonText_Resume = &Resume
Property(S): ButtonText_Retry = &Retry
Property(S): ButtonText_Return = &Return
Property(S): ButtonText_Yes = &Yes
Property(S): CompleteSetupIcon = completi
Property(S): CustomSetupIcon = custicon
Property(S): DialogBitmap = dlgbmp
Property(S): DlgTitleFont = {&DlgFontBold8}
Property(S): ExclamationIcon = exclamic
Property(S): InfoIcon = info
Property(S): InstallerIcon = insticon
Property(S): INSTALLLEVEL = 3
Property(S): InstallModeTxt_1 = Custom
Property(S): InstallModeVal = InstallModeTxt_1
Property(S): InstallModeTxt_2 = Complete
Property(S): InstallModeTxt_3 = Server Image
Property(S): InstallModeTxt_4 = Change
Property(S): InstallModeTxt_5 = Repair
Property(S): InstallModeTxt_6 = Remove
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): Progress1Txt_1 = Installing
Property(S): Progress1 = Progress1Txt_1
Property(S): Progress2Txt_1 = installs
Property(S): Progress2 = Progress2Txt_1
Property(S): Progress1Txt_2 = Changing
Property(S): Progress2Txt_2 = changes
Property(S): Progress1Txt_3 = Repairing
Property(S): Progress2Txt_3 = repairs
Property(S): Progress1Txt_4 = Removing
Property(S): Progress2Txt_4 = removes
Property(S): PROMPTROLLBACKCOST = P
Property(S): RemoveIcon = removico
Property(S): RepairIcon = repairic
Property(S): Setup = Setup
Property(S): Wizard = Setup Wizard
Property(S): DefaultUIFont = DlgFont8
Property(S): ErrorDialog = ErrorDlg
Property(S): TARGETDIR = e:\
Property(S): COMPANYNAME = Section 13
Property(S): USERNAME = ArchangelGabe
Property(S): APPS_TEST = 1
Property(S): VersionNT = 501
Property(S): SecureCustomProperties = MSXML4SP2
Property(S): UpgradeCode = {7CE723E3-E56B-432C-9F24-78C0606045A5}
Property(S): ALLUSERS = 1
Property(S): WINHTTP_51 = WinHttpRequest Component version 5.1
Property(S): MSXML = C:\Program Files\MSXML 4.0\
Property(S): SourceDir = e:\6b5965e623973149ce6c6a86\
Property(S): DesktopFolder = C:\Documents and Settings\All Users\Desktop\
Property(S): ProgramFilesFolder = C:\Program Files\
Property(S): ProductState = -1
Property(S): PackageCode = {2B27DCD9-53FA-4885-B6CD-698623819F4C}
Property(S): SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 = C:\WINDOWS\system32\
Property(S): SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 = C:\WINDOWS\system32\
Property(S): SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB = C:\WINDOWS\system32\
Property(S): WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\
Property(S): payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_b7e10f227b2fceff\
Property(S): payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
Property(S): WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Manifests\
Property(S): WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\
Property(S): SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\system32\
Property(S): WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\
Property(S): policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\
Property(S): policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
Property(S): WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\
Property(S): payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_microsoft.msxml2r_6bd6b9abf345378f_4.1.0.0_none_3658456fda6654f6\
Property(S): payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
Property(S): WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Manifests\
Property(S): WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\
Property(S): SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\system32\
Property(S): WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\
Property(S): policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\
Property(S): policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
Property(S): WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\
Property(S): payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_policy.4.20.microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_a6dfa6920e9f98fc\
Property(S): WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\
Property(S): policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\
Property(S): WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\
Property(S): SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\system32\
Property(S): WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Manifests\
Property(S): payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
Property(S): policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
Property(S): DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Documents and Settings\All Users\Desktop\
Property(S): ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\
Property(S): DOC.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Program Files\MSXML 4.0\doc\
Property(S): LIB.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Program Files\MSXML 4.0\lib\
Property(S): INC.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Program Files\MSXML 4.0\inc\
Property(S): CommonFilesFolder = C:\Program Files\Common Files\
Property(S): MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 = C:\Program Files\Common Files\Microsoft Shared\
Property(S): MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 = C:\Program Files\Common Files\Microsoft Shared\MSDN\
Property(S): Date = 1/12/2007
Property(S): PackagecodeChanging = 1
Property(S): REBOOT = ReallySuppress
Property(S): CURRENTDIRECTORY = e:\6b5965e623973149ce6c6a86
Property(S): CLIENTUILEVEL = 3
Property(S): CLIENTPROCESSID = 1596
Property(S): VersionDatabase = 200
Property(S): VersionMsi = 3.01
Property(S): WindowsBuild = 2600
Property(S): ServicePackLevel = 2
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): WindowsVolume = C:\
Property(S): SystemFolder = C:\WINDOWS\system32\
Property(S): System16Folder = C:\WINDOWS\system\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\WINDOWS\TEMP\
Property(S): AppDataFolder = C:\WINDOWS\system32\config\systemprofile\Application Data\
Property(S): FavoritesFolder = C:\WINDOWS\system32\config\systemprofile\Favorites\
Property(S): NetHoodFolder = C:\WINDOWS\system32\config\systemprofile\NetHood\
Property(S): PersonalFolder = C:\WINDOWS\system32\config\systemprofile\My Documents\
Property(S): PrintHoodFolder = C:\WINDOWS\system32\config\systemprofile\PrintHood\
Property(S): RecentFolder = C:\WINDOWS\system32\config\systemprofile\Recent\
Property(S): SendToFolder = C:\WINDOWS\system32\config\systemprofile\SendTo\
Property(S): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(S): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(S): LocalAppDataFolder = C:\WINDOWS\system32\config\systemprofile\Local Settings\Application Data\
Property(S): MyPicturesFolder = C:\WINDOWS\system32\config\systemprofile\My Documents\My Pictures\
Property(S): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(S): ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): Intel = 15
Property(S): PhysicalMemory = 2047
Property(S): VirtualMemory = 3431
Property(S): AdminUser = 1
Property(S): LogonUser = SYSTEM
Property(S): UserSID = S-1-5-18
Property(S): UserLanguageID = 1033
Property(S): ComputerName = TASSADAR
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1280
Property(S): ScreenY = 1024
Property(S): CaptionHeight = 26
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 3:00:33
Property(S): MsiWin32AssemblySupport = 5.1.2600.3019
Property(S): RedirectedDllSupport = 2
Property(S): Privileged = 1
Property(S): DATABASE = C:\WINDOWS\Installer\4055dd2.msi
Property(S): OriginalDatabase = e:\6b5965e623973149ce6c6a86\msxml.msi
Property(S): UILevel = 2
Property(S): ACTION = INSTALL
Property(S): ROOTDRIVE = e:\
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = e:\6b5965e623973149ce6c6a86\
Property(S): SourcedirProduct = {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Property(S): ProductToBeRegistered = 1
MSI (s) (F0:00) [03:00:33:468]: Note: 1: 1707
MSI (s) (F0:00) [03:00:33:468]: Product: MSXML 4.0 SP2 (KB927978) -- Installation completed successfully.
MSI (s) (F0:00) [03:00:33:468]: Cleaning up uninstalled install packages, if any exist
MSI (s) (F0:00) [03:00:33:468]: MainEngineThread is returning 0
MSI (s) (F0:98) [03:00:33:578]: Destroying RemoteAPI object.
MSI (s) (F0:E0) [03:00:33:578]: Custom Action Manager thread ending.
=== Logging stopped: 1/12/2007 3:00:33 ===
MSI (c) (3C:B4) [03:00:33:578]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (3C:B4) [03:00:33:578]: MainEngineThread is returning 0
=== Verbose logging stopped: 1/12/2007 3:00:33 ===
It's called: 6b5965e623973149ce6c6a86
In it is a txt document that's titled: msxml4-KB927978-enu
In it is this text. It starts with Verbose, never found anything titled that online. I skimmed though it and there doesn't seem to be anything sensitive outside from my username and stuff which I've changed since then, so I'll post all of it. If you see something however...well crap.
=== Verbose logging started: 1/12/2007 3:00:16 Build type: SHIP UNICODE 3.01.4000.2435 Calling process: C:\WINDOWS\system32\msiexec.exe ===
MSI (c) (3C:B4) [03:00:16:781]: Resetting cached policy values
MSI (c) (3C:B4) [03:00:16:781]: Machine policy value 'Debug' is 0
MSI (c) (3C:B4) [03:00:16:781]: ******* RunEngine:
******* Product: e:\6b5965e623973149ce6c6a86\msxml.msi
******* Action:
******* CommandLine: **********
MSI (c) (3C:B4) [03:00:16:781]: Client-side and UI is none or basic: Running entire install on the server.
MSI (c) (3C:B4) [03:00:16:781]: Grabbed execution mutex.
MSI (c) (3C:B4) [03:00:16:843]: Cloaking enabled.
MSI (c) (3C:B4) [03:00:16:843]: Attempting to enable all disabled priveleges before calling Install on Server
MSI (c) (3C:B4) [03:00:16:843]: Incrementing counter to disable shutdown. Counter after increment: 0
MSI (s) (F0:98) [03:00:16:859]: Grabbed execution mutex.
MSI (s) (F0:00) [03:00:16:859]: Resetting cached policy values
MSI (s) (F0:00) [03:00:16:859]: Machine policy value 'Debug' is 0
MSI (s) (F0:00) [03:00:16:859]: ******* RunEngine:
******* Action:
MSI (s) (F0:00) [03:00:16:859]: Machine policy value 'DisableUserInstalls' is 0
MSI (s) (F0:00) [03:00:16:859]: File will have security applied from OpCode.
MSI (s) (F0:00) [03:00:16:906]: SOFTWARE RESTRICTION POLICY: Verifying package --> 'e:\6b5965e623973149ce6c6a86\msxml.msi' against software restriction policy
MSI (s) (F0:00) [03:00:16:906]: SOFTWARE RESTRICTION POLICY: e:\6b5965e623973149ce6c6a86\msxml.msi has a digital signature
MSI (s) (F0:00) [03:00:32:359]: SOFTWARE RESTRICTION POLICY: e:\6b5965e623973149ce6c6a86\msxml.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (F0:00) [03:00:32:359]: End dialog not enabled
MSI (s) (F0:00) [03:00:32:359]: Original package ==> e:\6b5965e623973149ce6c6a86\msxml.msi
MSI (s) (F0:00) [03:00:32:359]: Package we're running from ==> C:\WINDOWS\Installer\4055dd2.msi
MSI (s) (F0:00) [03:00:32:390]: APPCOMPAT: looking for appcompat database entry with ProductCode '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'.
MSI (s) (F0:00) [03:00:32:390]: APPCOMPAT: no matching ProductCode found in database.
MSI (s) (F0:00) [03:00:32:390]: MSCOREE not loaded loading copy from system32
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'TransformsSecure' is 0
MSI (s) (F0:00) [03:00:32:390]: User policy value 'TransformsAtSource' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'DisablePatch' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'AllowLockdownPatch' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'DisableLUAPatching' is 0
MSI (s) (F0:00) [03:00:32:390]: Machine policy value 'DisableFlyWeightPatching' is 0
MSI (s) (F0:00) [03:00:32:390]: Transforms are not secure.
MSI (s) (F0:00) [03:00:32:390]: Command Line: REBOOT=ReallySuppress CURRENTDIRECTORY=e:\6b5965e623973149ce6c6a86 CLIENTUILEVEL=3 CLIENTPROCESSID=1596
MSI (s) (F0:00) [03:00:32:390]: PROPERTY CHANGE: Adding PackageCode property. Its value is '{2B27DCD9-53FA-4885-B6CD-698623819F4C}'.
MSI (s) (F0:00) [03:00:32:390]: Product Code passed to Engine.Initialize: ''
MSI (s) (F0:00) [03:00:32:390]: Product Code from property table before transforms: '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'
MSI (s) (F0:00) [03:00:32:390]: Product Code from property table after transforms: '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'
MSI (s) (F0:00) [03:00:32:390]: Product not registered: beginning first-time install
MSI (s) (F0:00) [03:00:32:390]: PROPERTY CHANGE: Adding ProductState property. Its value is '-1'.
MSI (s) (F0:00) [03:00:32:390]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (F0:00) [03:00:32:390]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (F0:00) [03:00:32:390]: Adding new sources is allowed.
MSI (s) (F0:00) [03:00:32:390]: PROPERTY CHANGE: Adding PackagecodeChanging property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:390]: Package name extracted from package path: 'msxml.msi'
MSI (s) (F0:00) [03:00:32:390]: Package to be registered: 'msxml.msi'
MSI (s) (F0:00) [03:00:32:390]: Note: 1: 2729
MSI (s) (F0:00) [03:00:32:406]: Note: 1: 2729
MSI (s) (F0:00) [03:00:32:406]: Note: 1: 2262 2: AdminProperties 3: -2147287038
MSI (s) (F0:00) [03:00:32:406]: Machine policy value 'DisableMsi' is 0
MSI (s) (F0:00) [03:00:32:406]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:406]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:406]: Product installation will be elevated because user is admin and product is being installed per-machine.
MSI (s) (F0:00) [03:00:32:406]: Running product '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}' with elevated privileges: Product is assigned.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding REBOOT property. Its value is 'ReallySuppress'.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding CURRENTDIRECTORY property. Its value is 'e:\6b5965e623973149ce6c6a86'.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding CLIENTUILEVEL property. Its value is '3'.
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding CLIENTPROCESSID property. Its value is '1596'.
MSI (s) (F0:00) [03:00:32:406]: TRANSFORMS property is now:
MSI (s) (F0:00) [03:00:32:406]: PROPERTY CHANGE: Adding VersionDatabase property. Its value is '200'.
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Application Data
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Favorites
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\NetHood
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\My Documents
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\PrintHood
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Recent
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\SendTo
MSI (s) (F0:00) [03:00:32:406]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Templates
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Application Data
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Local Settings\Application Data
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\My Documents\My Pictures
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Desktop
MSI (s) (F0:00) [03:00:32:421]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Start Menu\Programs\Administrative Tools
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Start Menu\Programs\Startup
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\system32\config\systemprofile\Desktop
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\Documents and Settings\All Users\Templates
MSI (s) (F0:00) [03:00:32:453]: SHELL32::SHGetFolderPath returned: C:\WINDOWS\Fonts
MSI (s) (F0:00) [03:00:32:453]: Note: 1: 2898 2: MS Sans Serif 3: MS Sans Serif 4: 0 5: 16
MSI (s) (F0:00) [03:00:32:453]: MSCOREE not loaded loading copy from system32
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding Privileged property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:453]: Note: 1: 1402 2: HKEY_CURRENT_USER\Software\Microsoft\MS Setup (ACME)\User Info 3: 2
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding USERNAME property. Its value is 'ArchangelGabe'.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding COMPANYNAME property. Its value is 'Section 13'.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding DATABASE property. Its value is 'C:\WINDOWS\Installer\4055dd2.msi'.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding OriginalDatabase property. Its value is 'e:\6b5965e623973149ce6c6a86\msxml.msi'.
MSI (s) (F0:00) [03:00:32:453]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (F0:00) [03:00:32:453]: Machine policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:32:453]: User policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding UILevel property. Its value is '2'.
=== Logging started: 1/12/2007 3:00:32 ===
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding ACTION property. Its value is 'INSTALL'.
MSI (s) (F0:00) [03:00:32:453]: Doing action: INSTALL
MSI (s) (F0:00) [03:00:32:453]: Running ExecuteSequence
MSI (s) (F0:00) [03:00:32:453]: Doing action: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901
Action start 3:00:32: INSTALL.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Desktop\'.
Action start 3:00:32: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901.
MSI (s) (F0:00) [03:00:32:453]: Doing action: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901
Action ended 3:00:32: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901. Return value 1.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Start Menu\Programs\'.
Action start 3:00:32: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901.
MSI (s) (F0:00) [03:00:32:453]: Doing action: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537
Action ended 3:00:32: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901. Return value 1.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\'.
Action start 3:00:32: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:453]: Doing action: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537
Action ended 3:00:32: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:453]: PROPERTY CHANGE: Adding SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537
Action ended 3:00:32: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\'.
Action start 3:00:32: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537
Action ended 3:00:32: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
Action ended 3:00:32: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\'.
Action start 3:00:32: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
Action ended 3:00:32: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB
Action ended 3:00:32: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1
Action ended 3:00:32: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1.
MSI (s) (F0:00) [03:00:32:468]: Doing action: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7
Action ended 3:00:32: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 property. Its value is 'C:\WINDOWS\system32\'.
Action start 3:00:32: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7.
MSI (s) (F0:00) [03:00:32:468]: Doing action: LaunchConditions
Action ended 3:00:32: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7. Return value 1.
Action start 3:00:32: LaunchConditions.
MSI (s) (F0:00) [03:00:32:468]: Doing action: FindRelatedProducts
Action ended 3:00:32: LaunchConditions. Return value 1.
Action start 3:00:32: FindRelatedProducts.
MSI (s) (F0:00) [03:00:32:468]: Doing action: AppSearch
Action ended 3:00:32: FindRelatedProducts. Return value 1.
Action start 3:00:32: AppSearch.
MSI (s) (F0:00) [03:00:32:468]: Note: 1: 2262 2: Signature 3: -2147287038
MSI (s) (F0:00) [03:00:32:468]: PROPERTY CHANGE: Adding WINHTTP_51 property. Its value is 'WinHttpRequest Component version 5.1'.
MSI (s) (F0:00) [03:00:32:468]: Skipping action: CCPSearch (condition is false)
MSI (s) (F0:00) [03:00:32:468]: Skipping action: RMCCPSearch (condition is false)
MSI (s) (F0:00) [03:00:32:468]: Doing action: ValidateProductID
Action ended 3:00:32: AppSearch. Return value 1.
Action start 3:00:32: ValidateProductID.
MSI (s) (F0:00) [03:00:32:468]: Doing action: CostInitialize
Action ended 3:00:32: ValidateProductID. Return value 1.
MSI (s) (F0:00) [03:00:32:468]: Machine policy value 'MaxPatchCacheSize' is 10
Action start 3:00:32: CostInitialize.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding ROOTDRIVE property. Its value is 'e:\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding CostingComplete property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: Patch
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2205 2: 3: __MsiPatchFileList
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2228 2: 3: PatchPackage 4: SELECT `DiskId`, `PatchId`, `LastSequence` FROM `Media`, `PatchPackage` WHERE `Media`.`DiskId`=`PatchPackage`.`Media_` ORDER BY `DiskId`
MSI (s) (F0:00) [03:00:32:484]: Doing action: FileCost
Action ended 3:00:32: CostInitialize. Return value 1.
MSI (s) (F0:00) [03:00:32:484]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: FileCost.
MSI (s) (F0:00) [03:00:32:484]: Doing action: CostFinalize
Action ended 3:00:32: FileCost. Return value 1.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding OutOfDiskSpace property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding OutOfNoRbDiskSpace property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceAvailable property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRequired property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding PrimaryVolumeSpaceRemaining property. Its value is '0'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding TARGETDIR property. Its value is 'e:\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 property. Its value is 'C:\Program Files\Common Files\Microsoft Shared\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 property. Its value is 'C:\Program Files\Common Files\Microsoft Shared\MSDN\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Manifests\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_policy.4.20.microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_a6dfa6920e9f98fc\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Manifests\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_microsoft.msxml2r_6bd6b9abf345378f_4.1.0.0_none_3658456fda6654f6\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\Manifests\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 property. Its value is 'C:\WINDOWS\winsxs\x86_microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_b7e10f227b2fceff\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MSXML property. Its value is 'C:\Program Files\MSXML 4.0\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding INC.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Program Files\MSXML 4.0\inc\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding LIB.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Program Files\MSXML 4.0\lib\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding DOC.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Program Files\MSXML 4.0\doc\'.
MSI (s) (F0:00) [03:00:32:484]: PROPERTY CHANGE: Adding MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 property. Its value is 'C:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\'.
MSI (s) (F0:00) [03:00:32:484]: Target path resolution complete. Dumping Directory table...
MSI (s) (F0:00) [03:00:32:484]: Note: target paths subject to change (via custom actions or browsing)
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: TARGETDIR , Object: e:\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: CommonFilesFolder , Object: C:\Program Files\Common Files\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: C:\Program Files\Common Files\Microsoft Shared\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: C:\Program Files\Common Files\Microsoft Shared\MSDN\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Manifests\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_policy.4.20.microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_a6dfa6920e9f98fc\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Manifests\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_microsoft.msxml2r_6bd6b9abf345378f_4.1.0.0_none_3658456fda6654f6\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\Manifests\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: C:\WINDOWS\winsxs\x86_microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_b7e10f227b2fceff\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 , Object: C:\WINDOWS\system32\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: DesktopFolder , Object: C:\Documents and Settings\All Users\Desktop\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: ProgramFilesFolder , Object: C:\Program Files\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MSXML , Object: C:\Program Files\MSXML 4.0\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: INC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Program Files\MSXML 4.0\inc\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: LIB.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Program Files\MSXML 4.0\lib\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: DOC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Program Files\MSXML 4.0\doc\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Documents and Settings\All Users\Start Menu\Programs\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\
MSI (s) (F0:00) [03:00:32:484]: Dir (target): Key: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: C:\Documents and Settings\All Users\Desktop\
Action start 3:00:32: CostFinalize.
MSI (s) (F0:00) [03:00:32:593]: Doing action: SetODBCFolders
Action ended 3:00:32: CostFinalize. Return value 1.
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCDriver`, `Component` WHERE `ODBCDriver`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `ComponentId`,`Description`,`Directory_`, `ActionRequest`, `Installed`, `Attributes` FROM `ODBCTranslator`, `Component` WHERE `ODBCTranslator`.`Component_` = `Component` AND (`ActionRequest` = 1 OR `ActionRequest` = 2)
Action start 3:00:32: SetODBCFolders.
MSI (s) (F0:00) [03:00:32:593]: Doing action: MigrateFeatureStates
Action ended 3:00:32: SetODBCFolders. Return value 0.
Action start 3:00:32: MigrateFeatureStates.
MSI (s) (F0:00) [03:00:32:593]: Doing action: InstallValidate
Action ended 3:00:32: MigrateFeatureStates. Return value 0.
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXML; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSYS; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSUPP; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSUPP2; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: MSXMLSXS; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Feature: XMLSDK; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: RememberInstallFolder; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: QKBKEY; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: MSXML4_System.246EB7AD_459A_4FA8_83D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: MSXML4_SystemRes.246EB7AD_459A_4FA8_83D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: MSXML4_ANSI.246EB7AD_459A_4FA8_83D1_41A46D7634B7; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: WINHTTP50_COMPONENT.781A0624_31FF_4712_BFFD_31C829FFDBF1; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: PROXYCFG_COMPONENT.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: uplevel.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: uplevel.DA6654F6_456F_3658_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: uplevel.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: downlevel_manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537; Installed: Absent; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: XMLSDK_Docs.4576A2F1_959E_4BCA_94A9_596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: XMLSDK_LIB.4576A2F1_959E_4BCA_94A9_596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: XMLSDK_INC.4576A2F1_959E_4BCA_94A9_596523761901; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: CookDoc_dll.3FB7DAB3_19E7_40A0_8730_4482CE77AC59; Installed: Absent; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __uplevel.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __uplevel.DA6654F6_456F_3658_FF6B_D6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __uplevel.0E9F98FC_A692_A6DF_FF6B_D6B9ABF365; Installed: Null; Request: Local; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __QKBKEY65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __MSXML4_System.246EB7AD_459A_4FA8_83D1_4165; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_payload.7B2FCEFF_0F22_B7E1_FF665; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_manifest.7B2FCEFF_0F22_B7E1_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_payload.DA6654F6_456F_3658_FF665; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_manifest.DA6654F6_456F_3658_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __downlevel_manifest.0E9F98FC_A692_A6DF_FF65; Installed: Null; Request: Local; Action: Local
MSI (s) (F0:00) [03:00:32:593]: Component: __CookDoc_dll.3FB7DAB3_19E7_40A0_8730_448265; Installed: Null; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Component: __XMLSDK_Docs.4576A2F1_959E_4BCA_94A9_596565; Installed: Null; Request: Null; Action: Null
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: BindImage
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2262 2: PublishComponent 3: -2147287038
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2262 2: Extension 3: -2147287038
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: Font
Action start 3:00:32: InstallValidate.
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2205 2: 3: _RemoveFilePath
MSI (s) (F0:00) [03:00:32:593]: PROPERTY CHANGE: Modifying CostingComplete property. Its current value is '0'. Its new value: '1'.
MSI (s) (F0:00) [03:00:32:593]: Note: 1: 2727 2:
MSI (s) (F0:00) [03:00:32:609]: Note: 1: 2727 2:
MSI (s) (F0:00) [03:00:32:609]: Doing action: InstallInitialize
Action ended 3:00:32: InstallValidate. Return value 1.
MSI (s) (F0:00) [03:00:32:609]: Machine policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:609]: User policy value 'AlwaysInstallElevated' is 0
MSI (s) (F0:00) [03:00:32:609]: BeginTransaction: Locking Server
MSI (s) (F0:00) [03:00:32:609]: SRSetRestorePoint skipped for this transaction.
MSI (s) (F0:00) [03:00:32:609]: Server not locked: locking for product {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Action start 3:00:32: InstallInitialize.
MSI (s) (F0:00) [03:00:32:625]: Doing action: SxsInstallCA
Action ended 3:00:32: InstallInitialize. Return value 1.
MSI (s) (F0:0C) [03:00:32:640]: Invoking remote custom action. DLL: C:\WINDOWS\Installer\MSI42.tmp, Entrypoint: CustomAction_SxsMsmInstall
MSI (s) (F0:E0) [03:00:32:640]: Generating random cookie.
MSI (s) (F0:E0) [03:00:32:640]: Created Custom Action Server with PID 2896 (0xB50).
MSI (s) (F0:08) [03:00:32:671]: Running as a service.
MSI (s) (F0:08) [03:00:32:671]: Hello, I'm your 32bit Elevated custom action server.
Action start 3:00:32: SxsInstallCA.
1: sxsdelca 2: traceop 3: 1256 4: 0
1: sxsdelca 2: traceop 3: 1257 4: 0
1: sxsdelca 2: traceop 3: 1258 4: 0
1: sxsdelca 2: traceop 3: 1284 4: 0
1: sxsdelca 2: traceop 3: 1288 4: 0
1: sxsdelca 2: traceop 3: 1289 4: 0
1: sxsdelca 2: traceop 3: 1290 4: 0
1: sxsdelca 2: traceop 3: 1292 4: 0
1: sxsdelca 2: traceop 3: 1306 4: 0
1: sxsdelca 2: traceop 3: 1307 4: 0
1: sxsdelca 2: traceop 3: 796 4: 0
1: sxsdelca 2: traceop 3: 801 4: 0
1: sxsdelca 2: traceop 3: 802 4: 0
1: sxsdelca 2: traceop 3: 803 4: 0
1: sxsdelca 2: traceop 3: 805 4: 0
1: sxsdelca 2: traceop 3: 812 4: 0
1: sxsdelca 2: traceop 3: 813 4: 0
1: sxsdelca 2: traceop 3: 814 4: 0
1: sxsdelca 2: traceop 3: 819 4: 0
1: sxsdelca 2: traceop 3: 820 4: 0
1: sxsdelca 2: traceop 3: 821 4: 0
1: sxsdelca 2: traceop 3: 827 4: 0
1: sxsdelca 2: traceop 3: 831 4: 0
1: sxsdelca 2: traceop 3: 827 4: 259
1: sxsdelca 2: traceop 3: 1311 4: 0
1: sxsdelca 2: traceop 3: 1312 4: 0
1: sxsdelca 2: traceop 3: 1077 4: 0
1: sxsdelca 2: traceop 3: 1081 4: 0
1: sxsdelca 2: traceop 3: 1083 4: 0
1: sxsdelca 2: traceop 3: 1087 4: 0
1: sxsdelca 2: traceop 3: 1093 4: 0
1: sxsdelca 2: traceop 3: 1097 4: 0
1: sxsdelca 2: traceop 3: 1101 4: 0
1: sxsdelca 2: traceop 3: 1105 4: 0
1: sxsdelca 2: traceop 3: 1109 4: 0
1: sxsdelca 2: traceop 3: 1113 4: 0
1: sxsdelca 2: traceop 3: 1117 4: 0
1: sxsdelca 2: traceop 3: 1121 4: 0
1: sxsdelca 2: traceop 3: 1313 4: 0
1: sxsdelca 2: traceop 3: 1314 4: 0
1: sxsdelca: Added reg value for 2: downlevel_manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537
1: sxsdelca: Added reg value for 2: downlevel_manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537
1: sxsdelca 2: traceop 3: 1284 4: 259
1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
MSI (s) (F0:00) [03:00:32:812]: Doing action: AllocateRegistrySpace
Action ended 3:00:32: SxsInstallCA. Return value 1.
Action start 3:00:32: AllocateRegistrySpace.
MSI (s) (F0:00) [03:00:32:812]: Doing action: ProcessComponents
Action ended 3:00:32: AllocateRegistrySpace. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2205 2: 3: MsiPatchCertificate
MSI (s) (F0:00) [03:00:32:812]: LUA patching is disabled: missing MsiPatchCertificate table
MSI (s) (F0:00) [03:00:32:812]: Resolving source.
MSI (s) (F0:00) [03:00:32:812]: Resolving source to launched-from source.
MSI (s) (F0:00) [03:00:32:812]: Setting launched-from source as last-used.
MSI (s) (F0:00) [03:00:32:812]: PROPERTY CHANGE: Adding SourceDir property. Its value is 'e:\6b5965e623973149ce6c6a86\'.
MSI (s) (F0:00) [03:00:32:812]: PROPERTY CHANGE: Adding SOURCEDIR property. Its value is 'e:\6b5965e623973149ce6c6a86\'.
MSI (s) (F0:00) [03:00:32:812]: PROPERTY CHANGE: Adding SourcedirProduct property. Its value is '{37477865-A3F1-4772-AD43-AAFC6BCFF99F}'.
MSI (s) (F0:00) [03:00:32:812]: SOURCEDIR ==> e:\6b5965e623973149ce6c6a86\
MSI (s) (F0:00) [03:00:32:812]: SOURCEDIR product ==> {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
MSI (s) (F0:00) [03:00:32:812]: Determining source type
MSI (s) (F0:00) [03:00:32:812]: Source type from package 'msxml.msi': 2
Action start 3:00:32: ProcessComponents.
MSI (s) (F0:00) [03:00:32:812]: Source path resolution complete. Dumping Directory table...
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: TARGETDIR , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: CommonFilesFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Microsoft Shared\ , ShortSubPath: MICROS~1\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Microsoft Shared\MSDN\ , ShortSubPath: MICROS~1\MSDN\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\k0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\h0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\i0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\j0r1wg7y.dqe\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\8n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\6n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\5n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\7n0mtfut.k85\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\system32\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\wl34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Policies\ul34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\Manifests\ , ShortSubPath: Windows\winsxs\manifest\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\tl34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: Windows\winsxs\vl34x2va.rt8\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: System\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: DesktopFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: ProgramFilesFolder , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MSXML , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: INC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\inc\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: LIB.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\lib\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: DOC.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\doc\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\MSXML 4.0\ , ShortSubPath: redist\MSXML4\
MSI (s) (F0:00) [03:00:32:812]: Dir (source): Key: DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 , Object: e:\6b5965e623973149ce6c6a86\ , LongSubPath: redist\ , ShortSubPath:
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnpublishComponents
Action ended 3:00:32: ProcessComponents. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action start 3:00:32: UnpublishComponents.
MSI (s) (F0:00) [03:00:32:812]: Doing action: MsiUnpublishAssemblies
Action ended 3:00:32: UnpublishComponents. Return value 1.
Action start 3:00:32: MsiUnpublishAssemblies.
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnpublishFeatures
Action ended 3:00:32: MsiUnpublishAssemblies. Return value 1.
Action start 3:00:32: UnpublishFeatures.
MSI (s) (F0:00) [03:00:32:812]: Doing action: StopServices
Action ended 3:00:32: UnpublishFeatures. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2205 2: 3: ServiceControl
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2228 2: 3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 3:00:32: StopServices.
MSI (s) (F0:00) [03:00:32:812]: Doing action: DeleteServices
Action ended 3:00:32: StopServices. Return value 1.
Action start 3:00:32: DeleteServices.
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnregisterComPlus
Action ended 3:00:32: DeleteServices. Return value 1.
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2205 2: 3: Complus
MSI (s) (F0:00) [03:00:32:812]: Note: 1: 2228 2: 3: Complus 4: SELECT `ComponentId`, `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed` FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND `Action` = 0
Action start 3:00:32: UnregisterComPlus.
MSI (s) (F0:00) [03:00:32:812]: Doing action: SelfUnregModules
Action ended 3:00:32: UnregisterComPlus. Return value 0.
Action start 3:00:32: SelfUnregModules.
MSI (s) (F0:00) [03:00:32:812]: Doing action: UnregisterTypeLibraries
Action ended 3:00:32: SelfUnregModules. Return value 1.
Action start 3:00:32: UnregisterTypeLibraries.
MSI (s) (F0:00) [03:00:32:812]: Doing action: RemoveODBC
Action ended 3:00:32: UnregisterTypeLibraries. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: ODBCDataSource
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND `Component`.`Action` = 0 AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `Translator`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCTranslator`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`, `RuntimeFlags`, `Component`.`Attributes` FROM `ODBCDriver`, `Component` WHERE `Component_` = `Component` AND `Component`.`ActionRequest` = 0 AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2711 2: ODBCDriverManager
Action start 3:00:32: RemoveODBC.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterFonts
Action ended 3:00:32: RemoveODBC. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: Font
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Installed`From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And `FileAction`.`Action` = 0 ORDER BY `FileAction`.`Directory_`
Action start 3:00:32: UnregisterFonts.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveRegistryValues
Action ended 3:00:32: UnregisterFonts. Return value 1.
Action start 3:00:32: RemoveRegistryValues.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterClassInfo
Action ended 3:00:32: RemoveRegistryValues. Return value 1.
Action start 3:00:32: UnregisterClassInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterExtensionInfo
Action ended 3:00:32: UnregisterClassInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: UnregisterExtensionInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterProgIdInfo
Action ended 3:00:32: UnregisterExtensionInfo. Return value 1.
Action start 3:00:32: UnregisterProgIdInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: UnregisterMIMEInfo
Action ended 3:00:32: UnregisterProgIdInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2262 2: MIME 3: -2147287038
Action start 3:00:32: UnregisterMIMEInfo.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveIniValues
Action ended 3:00:32: UnregisterMIMEInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: IniFile
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND `Component`.`Action`=0 ORDER BY `FileName`,`Section`
Action start 3:00:32: RemoveIniValues.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveShortcuts
Action ended 3:00:32: RemoveIniValues. Return value 1.
Action start 3:00:32: RemoveShortcuts.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveEnvironmentStrings
Action ended 3:00:32: RemoveShortcuts. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: Environment
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 0)
Action start 3:00:32: RemoveEnvironmentStrings.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveDuplicateFiles
Action ended 3:00:32: RemoveEnvironmentStrings. Return value 1.
Action start 3:00:32: RemoveDuplicateFiles.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveFiles
Action ended 3:00:32: RemoveDuplicateFiles. Return value 1.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: RemoveFile
Action start 3:00:32: RemoveFiles.
MSI (s) (F0:00) [03:00:32:828]: Doing action: RemoveFolders
Action ended 3:00:32: RemoveFiles. Return value 0.
Action start 3:00:32: RemoveFolders.
MSI (s) (F0:00) [03:00:32:828]: Doing action: CreateFolders
Action ended 3:00:32: RemoveFolders. Return value 1.
Action start 3:00:32: CreateFolders.
MSI (s) (F0:00) [03:00:32:828]: Doing action: MoveFiles
Action ended 3:00:32: CreateFolders. Return value 1.
Action start 3:00:32: MoveFiles.
MSI (s) (F0:00) [03:00:32:828]: Doing action: InstallFiles
Action ended 3:00:32: MoveFiles. Return value 1.
Action start 3:00:32: InstallFiles.
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: Patch
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: Patch 4: SELECT `Patch`.`File_`, `Patch`.`Header`, `Patch`.`Attributes`, `Patch`.`Sequence`, `Patch`.`StreamRef_` FROM `Patch` WHERE `Patch`.`File_` = ? AND `Patch`.`#_MsiActive`=? ORDER BY `Patch`.`Sequence`
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: MsiPatchHeaders
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2228 2: 3: MsiPatchHeaders 4: SELECT `Header` FROM `MsiPatchHeaders` WHERE `StreamRef` = ?
MSI (s) (F0:00) [03:00:32:828]: Note: 1: 2205 2: 3: PatchPackage
MSI (s) (F0:00) [03:00:32:843]: Doing action: PatchFiles
Action ended 3:00:32: InstallFiles. Return value 1.
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2205 2: 3: Patch
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2228 2: 3: Patch 4: SELECT `File`,`FileName`,`FileSize`,`Directory_`,`PatchSize`,`File`.`Attributes`,`Patch`.`Attributes`,`Patch`.`Sequence`,`Component`.`Component`,`Component`.`ComponentId` FROM `File`,`Component`,`Patch` WHERE `Patch`.`#_MsiActive`=? AND `File`=`File_` AND `Component`=`Component_` ORDER BY `Patch`.`Sequence`
Action start 3:00:32: PatchFiles.
MSI (s) (F0:00) [03:00:32:843]: Doing action: DuplicateFiles
Action ended 3:00:32: PatchFiles. Return value 0.
Action start 3:00:32: DuplicateFiles.
MSI (s) (F0:00) [03:00:32:843]: Doing action: BindImage
Action ended 3:00:32: DuplicateFiles. Return value 1.
Action start 3:00:32: BindImage.
MSI (s) (F0:00) [03:00:32:843]: Doing action: CreateShortcuts
Action ended 3:00:32: BindImage. Return value 1.
Action start 3:00:32: CreateShortcuts.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterClassInfo
Action ended 3:00:32: CreateShortcuts. Return value 1.
Action start 3:00:32: RegisterClassInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterExtensionInfo
Action ended 3:00:32: RegisterClassInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2262 2: Extension 3: -2147287038
Action start 3:00:32: RegisterExtensionInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterProgIdInfo
Action ended 3:00:32: RegisterExtensionInfo. Return value 1.
Action start 3:00:32: RegisterProgIdInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: RegisterMIMEInfo
Action ended 3:00:32: RegisterProgIdInfo. Return value 1.
MSI (s) (F0:00) [03:00:32:843]: Note: 1: 2262 2: MIME 3: -2147287038
Action start 3:00:32: RegisterMIMEInfo.
MSI (s) (F0:00) [03:00:32:843]: Doing action: WriteRegistryValues
Action ended 3:00:32: RegisterMIMEInfo. Return value 1.
Action start 3:00:32: WriteRegistryValues.
MSI (s) (F0:00) [03:00:32:859]: Doing action: WriteIniValues
Action ended 3:00:32: WriteRegistryValues. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: IniFile
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: IniFile 4: SELECT `FileName`,`IniFile`.`DirProperty`,`Section`,`IniFile`.`Key`,`IniFile`.`Value`,`IniFile`.`Action` FROM `IniFile`, `Component` WHERE `Component`=`Component_` AND (`Component`.`Action`=1 OR `Component`.`Action`=2) ORDER BY `FileName`,`Section`
Action start 3:00:32: WriteIniValues.
MSI (s) (F0:00) [03:00:32:859]: Doing action: WriteEnvironmentStrings
Action ended 3:00:32: WriteIniValues. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: Environment
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: Environment 4: SELECT `Name`,`Value` FROM `Environment`,`Component` WHERE `Component_`=`Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2)
Action start 3:00:32: WriteEnvironmentStrings.
MSI (s) (F0:00) [03:00:32:859]: Doing action: RegisterFonts
Action ended 3:00:32: WriteEnvironmentStrings. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: Font
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: Font 4: SELECT `FontTitle`, `FileName`, `Directory_`, `Action` From `Font`, `FileAction` Where `Font`.`File_` = `FileAction`.`File` And (`FileAction`.`Action` = 1 Or `FileAction`.`Action` = 2) ORDER BY `FileAction`.`Directory_`
Action start 3:00:32: RegisterFonts.
MSI (s) (F0:00) [03:00:32:859]: Doing action: InstallODBC
Action ended 3:00:32: RegisterFonts. Return value 1.
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2711 2: ODBCDriverManager
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2711 2: ODBCDriverManager64
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: ODBCDriver
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: ODBCDriver 4: SELECT `Driver`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCDriver`, `File`, `Component` WHERE `File_` = `File` AND `ODBCDriver`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: ODBCTranslator
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: ODBCTranslator 4: SELECT `Translator`,`ComponentId`,`Description`,`RuntimeFlags`,`Directory_`,`FileName`,`File_Setup`,`Action` FROM `ODBCTranslator`, `File`, `Component` WHERE `File_` = `File` AND `ODBCTranslator`.`Component_` = `Component` AND (`Component`.`ActionRequest` = 1 OR `Component`.`ActionRequest` = 2) AND `BinaryType` = ?
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2205 2: 3: ODBCDataSource
MSI (s) (F0:00) [03:00:32:859]: Note: 1: 2228 2: 3: ODBCDataSource 4: SELECT `DataSource`,`ComponentId`,`DriverDescription`,`Description`,`Registration` FROM `ODBCDataSource`, `Component` WHERE `Component_` = `Component` AND (`Component`.`Action` = 1 OR `Component`.`Action` = 2) AND `BinaryType` = ?
Action start 3:00:32: InstallODBC.
MSI (s) (F0:00) [03:00:32:859]: Doing action: RegisterTypeLibraries
Action ended 3:00:32: InstallODBC. Return value 0.
Action start 3:00:32: RegisterTypeLibraries.
MSI (s) (F0:00) [03:00:32:875]: Doing action: SelfRegModules
Action ended 3:00:32: RegisterTypeLibraries. Return value 1.
Action start 3:00:32: SelfRegModules.
MSI (s) (F0:00) [03:00:32:875]: Doing action: RegisterComPlus
Action ended 3:00:32: SelfRegModules. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2205 2: 3: Complus
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2228 2: 3: Complus 4: SELECT `ComponentId`, `FileName`, `Component`.`Directory_`, `ExpType`, `Component`.`Action`, `Component`.`Installed` FROM `Complus`, `Component`, `File` WHERE `Complus`.`Component_` = `Component` AND `Component`.`KeyPath` = `File`.`File` AND (`Action` = 1 OR `Action` = 2)
Action start 3:00:32: RegisterComPlus.
MSI (s) (F0:00) [03:00:32:875]: Doing action: InstallServices
Action ended 3:00:32: RegisterComPlus. Return value 0.
MSI (s) (F0:00) [03:00:32:875]: Detected older ServiceInstall table schema
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2205 2: 3: ServiceInstall
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2228 2: 3: ServiceInstall 4: SELECT `Name`,`DisplayName`,`ServiceType`,`StartType`,`ErrorControl`,`LoadOrderGroup`,`Dependencies`,`StartName`,`Password`,`ComponentId`,`Directory_`,`FileName`,`Arguments` FROM `ServiceInstall`, `Component`, `File` WHERE `ServiceInstall`.`Component_` = `Component`.`Component` AND (`Component`.`KeyPath` = `File`.`File`) AND (`Action` = 1 OR `Action` = 2)
Action start 3:00:32: InstallServices.
MSI (s) (F0:00) [03:00:32:875]: Doing action: StartServices
Action ended 3:00:32: InstallServices. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2205 2: 3: ServiceControl
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2228 2: 3: ServiceControl 4: SELECT `Name`,`Wait`,`Arguments`,`Event`, `Action` FROM `ServiceControl`, `Component` WHERE `Component_` = `Component` AND (`Action` = 0 OR `Action` = 1 OR `Action` = 2)
Action start 3:00:32: StartServices.
MSI (s) (F0:00) [03:00:32:875]: Doing action: RegisterUser
Action ended 3:00:32: StartServices. Return value 1.
Action start 3:00:32: RegisterUser.
MSI (s) (F0:00) [03:00:32:875]: Doing action: RegisterProduct
Action ended 3:00:32: RegisterUser. Return value 1.
Action start 3:00:32: RegisterProduct.
MSI (s) (F0:00) [03:00:32:875]: PROPERTY CHANGE: Adding ProductToBeRegistered property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:875]: Doing action: PublishComponents
Action ended 3:00:32: RegisterProduct. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Note: 1: 2262 2: PublishComponent 3: -2147287038
Action start 3:00:32: PublishComponents.
MSI (s) (F0:00) [03:00:32:875]: Doing action: MsiPublishAssemblies
Action ended 3:00:32: PublishComponents. Return value 1.
Action start 3:00:32: MsiPublishAssemblies.
MSI (s) (F0:00) [03:00:32:875]: Doing action: PublishFeatures
Action ended 3:00:32: MsiPublishAssemblies. Return value 1.
Action start 3:00:32: PublishFeatures.
MSI (s) (F0:00) [03:00:32:875]: Doing action: PublishProduct
Action ended 3:00:32: PublishFeatures. Return value 1.
Action start 3:00:32: PublishProduct.
MSI (s) (F0:00) [03:00:32:875]: Doing action: InstallFinalize
Action ended 3:00:32: PublishProduct. Return value 1.
MSI (s) (F0:00) [03:00:32:875]: Running Script: C:\WINDOWS\Installer\MSI43.tmp
MSI (s) (F0:00) [03:00:32:875]: PROPERTY CHANGE: Adding UpdateStarted property. Its value is '1'.
MSI (s) (F0:00) [03:00:32:875]: Machine policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:32:890]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\Rollback\Scripts 3: 2
MSI (s) (F0:00) [03:00:32:890]: Executing op: Header(Signature=1397708873,Version=301,Timestamp=908859409,LangId=1033,Platform=0,ScriptType=1,ScriptMajorVersion=21,ScriptMinorVersion=4,ScriptAttributes=1)
Action start 3:00:32: InstallFinalize.
MSI (s) (F0:00) [03:00:32:890]: Executing op: ProductInfo(ProductKey={37477865-A3F1-4772-AD43-AAFC6BCFF99F},ProductName=MSXML 4.0 SP2 (KB927978),PackageName=msxml.msi,Language=1033,Version=68429425,Assignment=1,ObsoleteArg=0,,,PackageCode={2B27DCD9-53FA-4885-B6CD-698623819F4C},,,InstanceType=0,LUASetting=0,RemoteURTInstalls=0)
MSI (s) (F0:00) [03:00:32:890]: Executing op: DialogInfo(Type=0,Argument=1033)
MSI (s) (F0:00) [03:00:32:890]: Executing op: DialogInfo(Type=1,Argument=MSXML 4.0 SP2 (KB927978))
MSI (s) (F0:00) [03:00:32:890]: Executing op: RollbackInfo(,RollbackAction=Rollback,RollbackDescription=Rolling back action:,RollbackTemplate=[1],CleanupAction=RollbackCleanup,CleanupDescription=Removing backup files,CleanupTemplate=File: [1])
MSI (s) (F0:00) [03:00:32:890]: Executing op: SetBaseline(Baseline=0,)
MSI (s) (F0:00) [03:00:32:890]: Executing op: SetBaseline(Baseline=1,)
MSI (s) (F0:00) [03:00:32:890]: Executing op: ActionStart(Name=ProcessComponents,Description=Updating component registration,)
MSI (s) (F0:00) [03:00:32:890]: Executing op: ProgressTotal(Total=5,Type=1,ByteEquivalent=24000)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={E9BC82F6-AC0E-407C-8666-619D6D60DF2B},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\6F28CB9EE0CAC704686616D9D606FDB2 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={81754FFD-DA2B-49C6-9447-E1C1E1733BB6},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\DFF45718B2AD6C9449741E1C1E37B36B 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={5E6714E1-EA46-4B0F-B479-06D87058DC74},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\1E4176E564AEF0B44B97608D0785CD47 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={57E0F99D-E884-4BD0-B8CB-803CF9EA2066},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\D99F0E75488E0DB48BBC08C39FAE0266 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentUnregister(ComponentId={C763CD13-6E1E-4166-8C78-D274B266E9B6},,BinaryType=0,PreviouslyPinned=1)
MSI (s) (F0:00) [03:00:32:906]: Note: 1: 1402 2: UNKNOWN\Components\31DC367CE1E66614C8872D472B669E6B 3: 2
MSI (s) (F0:00) [03:00:32:906]: Executing op: ProgressTotal(Total=14,Type=1,ByteEquivalent=24000)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={4075CDF6-D88F-4F57-AF1A-29A124755695},KeyPath=C:\Program Files\MSXML 4.0\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={D21D9CCD-C3FA-4D72-982F-C29A2DE361EC},KeyPath=02:\Software\Microsoft\Updates\MSXML4SP2\Q927978\Description,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={4B1F71A7-50C6-44B7-A3AD-B6C3574BB896},KeyPath=C:\WINDOWS\system32\msxml4.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={62846705-2671-4547-AB45-854DCC93B3C7},KeyPath=C:\WINDOWS\system32\msxml4r.dll,State=3,,Disk=1,SharedDllRefCount=3,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={3AAE95CD-F592-46E7-89A1-9B56717C4413},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={CCF8B6EF-5FB9-4DE1-A276-683008BA3485},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={7B2FCEFF-0F22-B7E1-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_manifest\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_payload\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={DA6654F6-456F-3658-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={DA6654F6-456F-3658-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_manifest\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={DA6654F6-456F-3658-B06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_payload\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={0E9F98FC-A692-A6DF-A06B-D6B9ABF34537},,State=-7,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ComponentRegister(ComponentId={0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},KeyPath=02:\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\downlevel_manifest\,State=3,,Disk=1,SharedDllRefCount=0,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ProgressTotal(Total=1,Type=1,ByteEquivalent=13200)
MSI (s) (F0:00) [03:00:32:906]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SharedDLLs,,BinaryType=0)
MSI (s) (F0:00) [03:00:32:906]: Executing op: ProgressTick()
MSI (s) (F0:00) [03:00:32:906]: Executing op: ActionStart(Name=RemoveODBC,Description=Removing ODBC components,)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ODBCDriverManager(,BinaryType=0)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ODBCDriverManager(,BinaryType=1)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ActionStart(Name=CreateFolders,Description=Creating folders,Template=Folder: [1])
MSI (s) (F0:00) [03:00:32:921]: Executing op: FolderCreate(Folder=C:\Program Files\MSXML 4.0\,Foreign=0,)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ActionStart(Name=InstallFiles,Description=Copying new files,Template=File: [1], Directory: [9], Size: [6])
MSI (s) (F0:00) [03:00:32:921]: Executing op: ProgressTotal(Total=2604004,Type=0,ByteEquivalent=1)
MSI (s) (F0:00) [03:00:32:921]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\system32\)
MSI (s) (F0:00) [03:00:32:921]: Executing op: SetSourceFolder(Folder=1\System\)
MSI (s) (F0:00) [03:00:32:921]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_Core.cab,BytesPerTick=32768,CopierType=2,ModuleFileName=C:\WINDOWS\Installer\4055dd2.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (F0:00) [03:00:32:921]: Executing op: FileCopy(SourceName=msxml4.dll,SourceCabKey=msxml4.dll.246EB7AD_459A_4FA8_83D1_41A46D7634B7,DestName=msxml4.dll,Attributes=512,FileSize=1245696,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=4.20.9841.0,Language=0,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:32:953]: File: C:\WINDOWS\system32\msxml4.dll; Overwrite; Won't patch; Existing file is a lower version
MSI (s) (F0:00) [03:00:32:953]: Source for file 'msxml4.dll.246EB7AD_459A_4FA8_83D1_41A46D7634B7' is compressed
MSI (s) (F0:00) [03:00:32:953]: Re-applying security from existing file.
MSI (s) (F0:00) [03:00:32:953]: Verifying accessibility of file: msxml4.dll
MSI (s) (F0:00) [03:00:32:953]: SOFTWARE RESTRICTION POLICY: Verifying object --> 'C:\WINDOWS\Installer\4055dd2.msi' against software restriction policy
MSI (s) (F0:00) [03:00:32:953]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\4055dd2.msi has a digital signature
MSI (s) (F0:00) [03:00:33:000]: SOFTWARE RESTRICTION POLICY: C:\WINDOWS\Installer\4055dd2.msi is permitted to run at the 'unrestricted' authorization level.
MSI (s) (F0:00) [03:00:33:000]: Note: 1: 2318 2: C:\WINDOWS\system32\msxml4.dll
MSI (s) (F0:00) [03:00:33:015]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:031]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:062]: Executing op: FileCopy(SourceName=msxml4r.dll,SourceCabKey=msxml4r.dll.246EB7AD_459A_4FA8_83D1_41A46D7634B7,DestName=msxml4r.dll,Attributes=512,FileSize=82432,PerTick=32768,,VerifyMedia=1,,,,,CheckCRC=0,Version=4.10.9404.0,Language=1033,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\system32\msxml4r.dll; Won't Overwrite; Won't patch; Existing file is of an equal version
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\manifest\|Windows\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: FileCopy(SourceName=xl34x2va.rt8|x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest,SourceCabKey=manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest,,FileSize=3973,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-85909274,HashPart2=-393638470,HashPart3=495071453,HashPart4=945762879,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:078]: Source for file 'manifest.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:078]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest
MSI (s) (F0:00) [03:00:33:078]: Executing op: FileCopy(SourceName=yl34x2va.rt8|x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat,SourceCabKey=catalog.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat,,FileSize=8347,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-1679697816,HashPart2=1808584787,HashPart3=1425912084,HashPart4=629236904,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:078]: Source for file 'catalog.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:078]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\tl34x2va.rt8\)
MSI (s) (F0:00) [03:00:33:078]: Executing op: FileCopy(SourceName=1m34x2va.rt8|msxml4.dll,SourceCabKey=msxml4.dll.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537,DestName=msxml4.dll,,FileSize=1245696,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,Version=4.20.9841.0,Language=0,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:33:078]: File: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\msxml4.dll; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:078]: Source for file 'msxml4.dll.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:093]: Note: 1: 2318 2: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\msxml4.dll
MSI (s) (F0:00) [03:00:33:093]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:109]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:125]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:156]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:156]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\manifest\|Windows\winsxs\Manifests\)
MSI (s) (F0:00) [03:00:33:156]: Executing op: FileCopy(SourceName=9n0mtfut.k85|x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest,SourceCabKey=manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest,,FileSize=500,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-707213148,HashPart2=1938794768,HashPart3=-933075776,HashPart4=-843550219,,)
MSI (s) (F0:00) [03:00:33:156]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:156]: Source for file 'manifest.DA6654F6_456F_3658_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:156]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest
MSI (s) (F0:00) [03:00:33:171]: Executing op: FileCopy(SourceName=an0mtfut.k85|x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat,SourceCabKey=catalog.DA6654F6_456F_3658_FF6B_D6B9ABF34537,DestName=x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat,,FileSize=8349,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-1336197992,HashPart2=-627824155,HashPart3=82633343,HashPart4=1105156543,,)
MSI (s) (F0:00) [03:00:33:171]: File: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:171]: Source for file 'catalog.DA6654F6_456F_3658_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:171]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Manifests\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\5n0mtfut.k85\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: FileCopy(SourceName=dn0mtfut.k85|msxml4r.dll,SourceCabKey=msxml4r.dll.DA6654F6_456F_3658_FF6B_D6B9ABF34537,DestName=msxml4r.dll,,FileSize=82432,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,Version=4.10.9404.0,Language=1033,InstallMode=58982400,,,,,,,)
MSI (s) (F0:00) [03:00:33:187]: File: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\msxml4r.dll; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:187]: Source for file 'msxml4r.dll.DA6654F6_456F_3658_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:187]: Note: 1: 2318 2: C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\msxml4r.dll
MSI (s) (F0:00) [03:00:33:187]: Note: 1: 2360
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetTargetFolder(Folder=C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: SetSourceFolder(Folder=1\Windows\winsxs\Policies\i0r1wg7y.dqe\)
MSI (s) (F0:00) [03:00:33:187]: Executing op: FileCopy(SourceName=l0r1wg7y.dqe|4.20.9841.0.policy,SourceCabKey=manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537,DestName=4.20.9841.0.policy,,FileSize=652,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=49613189,HashPart2=1139053242,HashPart3=-1699064514,HashPart4=-854272932,,)
MSI (s) (F0:00) [03:00:33:187]: File: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.policy; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:187]: Source for file 'manifest.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:187]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.policy
MSI (s) (F0:00) [03:00:33:203]: Executing op: FileCopy(SourceName=m0r1wg7y.dqe|4.20.9841.0.cat,SourceCabKey=catalog.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537,DestName=4.20.9841.0.cat,,FileSize=8359,PerTick=32768,,VerifyMedia=1,ElevateFlags=4,,,,CheckCRC=0,,,InstallMode=58982400,HashOptions=0,HashPart1=-861819424,HashPart2=1423527147,HashPart3=-1146259424,HashPart4=2040409349,,)
MSI (s) (F0:00) [03:00:33:203]: File: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.cat; To be installed; Won't patch; No existing file
MSI (s) (F0:00) [03:00:33:203]: Source for file 'catalog.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537' is compressed
MSI (s) (F0:00) [03:00:33:203]: Note: 1: 2318 2: C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\4.20.9841.0.cat
MSI (s) (F0:00) [03:00:33:203]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_SDK.cab,BytesPerTick=32768,CopierType=2,ModuleFileName=C:\WINDOWS\Installer\4055dd2.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (F0:00) [03:00:33:203]: Executing op: CacheSizeFlush(,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: InstallProtectedFiles(AllowUI=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: ActionStart(Name=WriteRegistryValues,Description=Writing system registry values,Template=Key: [1], Name: [2], Value: [3])
MSI (s) (F0:00) [03:00:33:203]: Executing op: ProgressTotal(Total=112,Type=1,ByteEquivalent=13200)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=XML DOM Document 4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=Msxml2.DOMDocument.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=Msxml2.DOMDocument.4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C0-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value={F5078F18-C551-11D3-89B9-0000F81FE221},)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=Msxml2.DOMDocument.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value={88D969C0-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=Free Threaded XML DOM Document 4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=Msxml2.FreeThreadedDOMDocument.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegAddValue(,Value=Msxml2.FreeThreadedDOMDocument.4.0,)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:203]: Executing op: RegOpenKey(,Key=CLSID\{88D969C1-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.FreeThreadedDOMDocument.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={88D969C1-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=XML Data Source Object 4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(Name=ThreadingModel,Value=Apartment,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.DSOControl.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.DSOControl.4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C4-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={F5078F18-C551-11D3-89B9-0000F81FE221},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.DSOControl.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={88D969C4-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=XML HTTP 4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.XMLHTTP.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.XMLHTTP.4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C5-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.XMLHTTP.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value={88D969C5-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Server XML HTTP 4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=Msxml2.ServerXMLHTTP.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegAddValue(,Value=Msxml2.ServerXMLHTTP.4.0,)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:218]: Executing op: RegOpenKey(,Key=CLSID\{88D969C6-F192-11D4-A65F-0040963251E5}\TypeLib,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.ServerXMLHTTP.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={88D969C6-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=XML Schema Cache 4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XMLSchemaCache.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=Msxml2.XMLSchemaCache.4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C2-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XMLSchemaCache.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={88D969C2-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=XSL Template 4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XSLTemplate.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=Msxml2.XSLTemplate.4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{88D969C3-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.XSLTemplate.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={88D969C3-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=SAX XML Reader 4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.SAXXMLReader.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=Msxml2.SAXXMLReader.4.0,)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=Msxml2.SAXXMLReader.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value={7C6E29BC-8B8B-4C3D-859E-AF6CD158BE0F},)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegOpenKey(,Key=CLSID\{00B7E0AB-817A-44AD-A04B-D1148D524136},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:234]: Executing op: RegAddValue(,Value=MX XML Reader 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{00B7E0AB-817A-44AD-A04B-D1148D524136}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=MXXMLWriter 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXXMLWriter.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=Msxml2.MXXMLWriter.4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C8-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXXMLWriter.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value={88D969C8-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=MXHTMLWriter 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXHTMLWriter.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=Msxml2.MXHTMLWriter.4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969C9-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.MXHTMLWriter.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value={88D969C9-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=SAXAttributes 4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.SAXAttributes.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=Msxml2.SAXAttributes.4.0,)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969CA-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=Msxml2.SAXAttributes.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value={88D969CA-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5},,BinaryType=0)
MSI (s) (F0:00) [03:00:33:250]: Executing op: RegAddValue(,Value=MXNamespaceManager 4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\InProcServer32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=C:\WINDOWS\system32\msxml4.dll,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=ThreadingModel,Value=Both,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=Msxml2.MXNamespaceManager.4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=MXNamespaceManager 4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\ProgID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=Msxml2.MXNamespaceManager.4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=CLSID\{88D969D6-F192-11D4-A65F-0040963251E5}\Version,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(,Key=Msxml2.MXNamespaceManager.4.0\CLSID,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value={88D969D6-F192-11D4-A65F-0040963251E5},)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Updates\MSXML4SP2\Q927978,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=Description,Value=FIX: ASP stops responding when calling Response.Redirect to another server using msxml4 sp2,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=InstalledDate,Value=1/12/2007,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=InstalledBy,Value=ArchangelGabe,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=IsInstalled,Value=#1,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name=ServicePack,Value=#1,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=Microsoft XML, v4.0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\0,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\0\win32,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\FLAGS,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(,Value=0,)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Classes\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\4.0\HELPDIR,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_payload,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\downlevel_manifest,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_payload,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\downlevel_manifest,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Installations\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\downlevel_manifest,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegOpenKey(Root=-2147483646,Key=Software\Microsoft\Windows\CurrentVersion\SideBySide\PatchedComponents,,BinaryType=0)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name={7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.manifest[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213.cat[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\[~]{7B2FCEFF-0F22-B7E1-C06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name={7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\\msxml4.dll[~]{7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\[~]{7B2FCEFF-0F22-B7E1-B06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:265]: Executing op: RegAddValue(Name={DA6654F6-456F-3658-C06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.manifest[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a.cat[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Manifests\[~]{DA6654F6-456F-3658-C06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:281]: Executing op: RegAddValue(Name={DA6654F6-456F-3658-B06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\\msxml4r.dll[~]{DA6654F6-456F-3658-B06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\[~]{DA6654F6-456F-3658-B06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:281]: Executing op: RegAddValue(Name={0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},Value=C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\\4.20.9841.0.policy[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\\4.20.9841.0.cat[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537}[~]C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\[~]{0E9F98FC-A692-A6DF-C06B-D6B9ABF34537},)
MSI (s) (F0:00) [03:00:33:281]: Executing op: ActionStart(Name=RegisterTypeLibraries,Description=Registering type libraries,Template=LibID: [1])
MSI (s) (F0:00) [03:00:33:281]: Executing op: TypeLibraryRegister(,,FilePath=C:\WINDOWS\system32\msxml4.dll,LibID={F5078F18-C551-11D3-89B9-0000F81FE221},Version=1024,,Language=0,,BinaryType=0,IgnoreRegistrationFailure=0)
MSI (s) (F0:00) [03:00:33:281]: QueryPathOfRegTypeLib returned 0 in local context. Path is 'C:\WINDOWS\system32\msxml4.dll'
MSI (s) (F0:00) [03:00:33:281]: Note: 1: 1402 2: UNKNOWN\TypeLib\{F5078F18-C551-11D3-89B9-0000F81FE221}\400.0\0\win32 3: 2
MSI (s) (F0:00) [03:00:33:281]: CMsiServices:
MSI (s) (F0:00) [03:00:33:343]: ProcessTypeLibraryCore returns: 0. (0 means OK)
MSI (s) (F0:00) [03:00:33:343]: CMsiServices:
MSI (s) (F0:00) [03:00:33:343]: Executing op: ActionStart(Name=RegisterUser,Description=Registering user,Template=[1])
MSI (s) (F0:00) [03:00:33:343]: Executing op: UserRegister(Owner=ArchangelGabe,Company=Section 13,ProductId=none)
MSI (s) (F0:00) [03:00:33:343]: Executing op: ActionStart(Name=RegisterProduct,Description=Registering product,Template=[1])
MSI (s) (F0:00) [03:00:33:343]: Executing op: ChangeMedia(,MediaPrompt=Please insert the disk: ,MediaCabinet=XML_Core.cab,BytesPerTick=0,CopierType=2,ModuleFileName=C:\WINDOWS\Installer\4055dd2.msi,,,,,IsFirstPhysicalMedia=1)
MSI (s) (F0:00) [03:00:33:343]: Executing op: DatabaseCopy(DatabasePath=C:\WINDOWS\Installer\4055dd2.msi,ProductCode={37477865-A3F1-4772-AD43-AAFC6BCFF99F},CabinetStreams=XML_Core.cab;XML_SDK.cab,,)
MSI (s) (F0:00) [03:00:33:375]: Executing op: ProductRegister(UpgradeCode={7CE723E3-E56B-432C-9F24-78C0606045A5},VersionString=4.20.9841.0,HelpLink=http://support.microsoft.com/kb/927...6b5965e623973149ce6c6a86\,Publisher=Microsoft Corporation,,,,,,,,,,,,EstimatedSize=2625)
MSI (s) (F0:00) [03:00:33:375]: Executing op: ProductCPDisplayInfoRegister()
MSI (s) (F0:00) [03:00:33:375]: Executing op: ActionStart(Name=PublishFeatures,Description=Publishing Product Features,Template=Feature: [1])
MSI (s) (F0:00) [03:00:33:375]: Executing op: FeaturePublish(Feature=MSXML,,Absent=2,Component=MF}e835XRAhvfl[X%h~W(s-UlQ2mt@MgogY-xd{t)
MSI (s) (F0:00) [03:00:33:375]: Executing op: FeaturePublish(Feature=MSXMLSYS,Parent=MSXML,Absent=2,Component=V2?0@7$9*=IdbugpYRMX}GHaGLdZ==A&kv@Y~]3iui-r60O)l=Em%pCn7G4))
MSI (s) (F0:00) [03:00:33:390]: Executing op: FeaturePublish(Feature=MSXMLSUPP2,Parent=MSXML,Absent=2,Component=?`ZsjqO[%A*`NW3OG&nR)
MSI (s) (F0:00) [03:00:33:390]: Executing op: FeaturePublish(Feature=MSXMLSXS,Parent=MSXML,Absent=2,Component=LdCZOHqG+dpWsfdDE!j5LdCZOHqG+d6XsfdDE!j5LdCZOHqG+d%XsfdDE!j5`DM4olJ_O5pWsfdDE!j5`DM4olJ_O56XsfdDE!j5`DM4olJ_O5%XsfdDE!j5l0Rd'9?m^^pWsfdDE!j5l0Rd'9?m^^6XsfdDE!j5)
MSI (s) (F0:00) [03:00:33:390]: Executing op: FeaturePublish(Feature=XMLSDK,,Absent=3,Component=mk`[Q=PRe?RvYBgpXHXc5~{DF_B]-@1_XLnB~RWMMvh8D]u5G@j^sM7=J&oH0G,*i]!a$9uKNVM3Kykc)
MSI (s) (F0:00) [03:00:33:390]: Executing op: ActionStart(Name=PublishProduct,Description=Publishing product information,)
MSI (s) (F0:00) [03:00:33:390]: Executing op: IconCreate(Icon=icon.exe,Data=BinaryData)
MSI (s) (F0:00) [03:00:33:406]: Executing op: CleanupConfigData()
MSI (s) (F0:00) [03:00:33:406]: Note: 1: 1402 2: HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\568774731F3A2774DA34AACFB6FC9FF9\Patches 3: 2
MSI (s) (F0:00) [03:00:33:406]: Executing op: RegisterPatchOrder(Continue=0,SequenceType=1,Remove=0)
MSI (s) (F0:00) [03:00:33:406]: Note: 1: 1402 2: UNKNOWN\Products\568774731F3A2774DA34AACFB6FC9FF9\Patches 3: 2
MSI (s) (F0:00) [03:00:33:406]: Executing op: ProductPublish(PackageKey={2B27DCD9-53FA-4885-B6CD-698623819F4C})
MSI (s) (F0:00) [03:00:33:406]: Note: 1: 1402 2: UNKNOWN\Installer\Products\568774731F3A2774DA34AACFB6FC9FF9 3: 2
MSI (s) (F0:00) [03:00:33:421]: Note: 1: 1402 2: UNKNOWN\Installer\Products\568774731F3A2774DA34AACFB6FC9FF9 3: 2
MSI (s) (F0:00) [03:00:33:421]: Executing op: UpgradeCodePublish(UpgradeCode={7CE723E3-E56B-432C-9F24-78C0606045A5})
MSI (s) (F0:00) [03:00:33:421]: Executing op: SourceListPublish(,,,,NumberOfDisks=2)
MSI (s) (F0:00) [03:00:33:421]: Note: 1: 1402 2: UNKNOWN\Installer\Products\568774731F3A2774DA34AACFB6FC9FF9\SourceList 3: 2
MSI (s) (F0:00) [03:00:33:421]: Executing op: ProductPublishClient(,,)
MSI (s) (F0:00) [03:00:33:421]: Executing op: SourceListRegisterLastUsed(SourceProduct={37477865-A3F1-4772-AD43-AAFC6BCFF99F},LastUsedSource=e:\6b5965e623973149ce6c6a86\)
MSI (s) (F0:00) [03:00:33:421]: Entering CMsiConfigurationManager::SetLastUsedSource.
MSI (s) (F0:00) [03:00:33:421]: Specifed source is already in a list.
MSI (s) (F0:00) [03:00:33:421]: User policy value 'SearchOrder' is 'nmu'
MSI (s) (F0:00) [03:00:33:421]: Machine policy value 'DisableBrowse' is 0
MSI (s) (F0:00) [03:00:33:421]: Machine policy value 'AllowLockdownBrowse' is 0
MSI (s) (F0:00) [03:00:33:421]: Adding new sources is allowed.
MSI (s) (F0:00) [03:00:33:421]: Set LastUsedSource to: e:\6b5965e623973149ce6c6a86\.
MSI (s) (F0:00) [03:00:33:421]: Set LastUsedType to: n.
MSI (s) (F0:00) [03:00:33:421]: Set LastUsedIndex to: 1.
MSI (s) (F0:00) [03:00:33:421]: Executing op: End(Checksum=0,ProgressTotalHDWord=0,ProgressTotalLDWord=4564804)
MSI (s) (F0:00) [03:00:33:421]: User policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:33:421]: Machine policy value 'DisableRollback' is 0
MSI (s) (F0:00) [03:00:33:437]: No System Restore sequence number for this installation.
MSI (s) (F0:00) [03:00:33:437]: Unlocking Server
MSI (s) (F0:00) [03:00:33:437]: PROPERTY CHANGE: Deleting UpdateStarted property. Its current value is '1'.
MSI (s) (F0:00) [03:00:33:437]: Skipping action: SxsUninstallCA (condition is false)
MSI (s) (F0:00) [03:00:33:437]: Doing action: RemoveExistingProducts
Action ended 3:00:33: InstallFinalize. Return value 1.
Action start 3:00:33: RemoveExistingProducts.
Action ended 3:00:33: RemoveExistingProducts. Return value 1.
Action ended 3:00:33: INSTALL. Return value 1.
Property(S): ProductName = MSXML 4.0 SP2 (KB927978)
Property(S): ProductCode = {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Property(S): Manufacturer = Microsoft Corporation
Property(S): ProductVersion = 4.20.9841.0
Property(S): ProductLanguage = 1033
Property(S): BannerBitmap = bannrbmp
Property(S): IAgree = No
Property(S): ProductID = none
Property(S): ARPHELPLINK = http://support.microsoft.com/kb/927978
Property(S): ButtonText_Back = < &Back
Property(S): ButtonText_Browse = Br&owse
Property(S): ButtonText_Cancel = Cancel
Property(S): ButtonText_Exit = &Exit
Property(S): ButtonText_Finish = &Finish
Property(S): ButtonText_Ignore = &Ignore
Property(S): ButtonText_Install = &Install
Property(S): ButtonText_InstallNow = &Install Now
Property(S): ButtonText_Next = &Next >
Property(S): ButtonText_No = &No
Property(S): ButtonText_OK = OK
Property(S): ButtonText_Remove = &Remove
Property(S): ButtonText_Reset = &Reset
Property(S): ButtonText_Resume = &Resume
Property(S): ButtonText_Retry = &Retry
Property(S): ButtonText_Return = &Return
Property(S): ButtonText_Yes = &Yes
Property(S): CompleteSetupIcon = completi
Property(S): CustomSetupIcon = custicon
Property(S): DialogBitmap = dlgbmp
Property(S): DlgTitleFont = {&DlgFontBold8}
Property(S): ExclamationIcon = exclamic
Property(S): InfoIcon = info
Property(S): InstallerIcon = insticon
Property(S): INSTALLLEVEL = 3
Property(S): InstallModeTxt_1 = Custom
Property(S): InstallModeVal = InstallModeTxt_1
Property(S): InstallModeTxt_2 = Complete
Property(S): InstallModeTxt_3 = Server Image
Property(S): InstallModeTxt_4 = Change
Property(S): InstallModeTxt_5 = Repair
Property(S): InstallModeTxt_6 = Remove
Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
Property(S): Progress1Txt_1 = Installing
Property(S): Progress1 = Progress1Txt_1
Property(S): Progress2Txt_1 = installs
Property(S): Progress2 = Progress2Txt_1
Property(S): Progress1Txt_2 = Changing
Property(S): Progress2Txt_2 = changes
Property(S): Progress1Txt_3 = Repairing
Property(S): Progress2Txt_3 = repairs
Property(S): Progress1Txt_4 = Removing
Property(S): Progress2Txt_4 = removes
Property(S): PROMPTROLLBACKCOST = P
Property(S): RemoveIcon = removico
Property(S): RepairIcon = repairic
Property(S): Setup = Setup
Property(S): Wizard = Setup Wizard
Property(S): DefaultUIFont = DlgFont8
Property(S): ErrorDialog = ErrorDlg
Property(S): TARGETDIR = e:\
Property(S): COMPANYNAME = Section 13
Property(S): USERNAME = ArchangelGabe
Property(S): APPS_TEST = 1
Property(S): VersionNT = 501
Property(S): SecureCustomProperties = MSXML4SP2
Property(S): UpgradeCode = {7CE723E3-E56B-432C-9F24-78C0606045A5}
Property(S): ALLUSERS = 1
Property(S): WINHTTP_51 = WinHttpRequest Component version 5.1
Property(S): MSXML = C:\Program Files\MSXML 4.0\
Property(S): SourceDir = e:\6b5965e623973149ce6c6a86\
Property(S): DesktopFolder = C:\Documents and Settings\All Users\Desktop\
Property(S): ProgramFilesFolder = C:\Program Files\
Property(S): ProductState = -1
Property(S): PackageCode = {2B27DCD9-53FA-4885-B6CD-698623819F4C}
Property(S): SystemFolder.246EB7AD_459A_4FA8_83D1_41A46D7634B7 = C:\WINDOWS\system32\
Property(S): SystemFolder.781A0624_31FF_4712_BFFD_31C829FFDBF1 = C:\WINDOWS\system32\
Property(S): SystemFolder.FA0F135B_0C6B_485B_9A27_5A4A5044D5AB = C:\WINDOWS\system32\
Property(S): WinSxsDirectory.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\
Property(S): payload_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_b7e10f227b2fceff\
Property(S): payload.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
Property(S): WinSxsManifests.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Manifests\
Property(S): WindowsFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\
Property(S): SystemFolder.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\system32\
Property(S): WinSxsPolicies.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\
Property(S): policydir.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2_6bd6b9abf345378f_x-ww_b261cf09\
Property(S): policydir_ul.7B2FCEFF_0F22_B7E1_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_18171213\
Property(S): WinSxsDirectory.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\
Property(S): payload_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_microsoft.msxml2r_6bd6b9abf345378f_4.1.0.0_none_3658456fda6654f6\
Property(S): payload.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
Property(S): WinSxsManifests.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Manifests\
Property(S): WindowsFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\
Property(S): SystemFolder.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\system32\
Property(S): WinSxsPolicies.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\
Property(S): policydir.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\x86_Microsoft.MSXML2R_6bd6b9abf345378f_x-ww_f529d679\
Property(S): policydir_ul.DA6654F6_456F_3658_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_Microsoft.MSXML2R_6bd6b9abf345378f_4.1.0.0_x-ww_29c3ad6a\
Property(S): WinSxsDirectory.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\
Property(S): payload_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_policy.4.20.microsoft.msxml2_6bd6b9abf345378f_4.20.9841.0_none_a6dfa6920e9f98fc\
Property(S): WinSxsPolicies.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\
Property(S): policydir.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Policies\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_x-ww_88e8eab8\
Property(S): WindowsFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\
Property(S): SystemFolder.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\system32\
Property(S): WinSxsManifests.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\Manifests\
Property(S): payload.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
Property(S): policydir_ul.0E9F98FC_A692_A6DF_FF6B_D6B9ABF34537 = C:\WINDOWS\winsxs\x86_policy.4.20.Microsoft.MSXML2_6bd6b9abf345378f_4.20.9841.0_x-ww_ff05e224\
Property(S): DesktopFolder.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Documents and Settings\All Users\Desktop\
Property(S): ProgramMenuFolder.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): MenuMSXML.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Documents and Settings\All Users\Start Menu\Programs\MSXML 4.0\
Property(S): DOC.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Program Files\MSXML 4.0\doc\
Property(S): LIB.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Program Files\MSXML 4.0\lib\
Property(S): INC.4576A2F1_959E_4BCA_94A9_596523761901 = C:\Program Files\MSXML 4.0\inc\
Property(S): CommonFilesFolder = C:\Program Files\Common Files\
Property(S): MicrosoftShared.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 = C:\Program Files\Common Files\Microsoft Shared\
Property(S): MSDN.3FB7DAB3_19E7_40A0_8730_4482CE77AC59 = C:\Program Files\Common Files\Microsoft Shared\MSDN\
Property(S): Date = 1/12/2007
Property(S): PackagecodeChanging = 1
Property(S): REBOOT = ReallySuppress
Property(S): CURRENTDIRECTORY = e:\6b5965e623973149ce6c6a86
Property(S): CLIENTUILEVEL = 3
Property(S): CLIENTPROCESSID = 1596
Property(S): VersionDatabase = 200
Property(S): VersionMsi = 3.01
Property(S): WindowsBuild = 2600
Property(S): ServicePackLevel = 2
Property(S): ServicePackLevelMinor = 0
Property(S): MsiNTProductType = 1
Property(S): WindowsFolder = C:\WINDOWS\
Property(S): WindowsVolume = C:\
Property(S): SystemFolder = C:\WINDOWS\system32\
Property(S): System16Folder = C:\WINDOWS\system\
Property(S): RemoteAdminTS = 1
Property(S): TempFolder = C:\WINDOWS\TEMP\
Property(S): AppDataFolder = C:\WINDOWS\system32\config\systemprofile\Application Data\
Property(S): FavoritesFolder = C:\WINDOWS\system32\config\systemprofile\Favorites\
Property(S): NetHoodFolder = C:\WINDOWS\system32\config\systemprofile\NetHood\
Property(S): PersonalFolder = C:\WINDOWS\system32\config\systemprofile\My Documents\
Property(S): PrintHoodFolder = C:\WINDOWS\system32\config\systemprofile\PrintHood\
Property(S): RecentFolder = C:\WINDOWS\system32\config\systemprofile\Recent\
Property(S): SendToFolder = C:\WINDOWS\system32\config\systemprofile\SendTo\
Property(S): TemplateFolder = C:\Documents and Settings\All Users\Templates\
Property(S): CommonAppDataFolder = C:\Documents and Settings\All Users\Application Data\
Property(S): LocalAppDataFolder = C:\WINDOWS\system32\config\systemprofile\Local Settings\Application Data\
Property(S): MyPicturesFolder = C:\WINDOWS\system32\config\systemprofile\My Documents\My Pictures\
Property(S): AdminToolsFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Administrative Tools\
Property(S): StartupFolder = C:\Documents and Settings\All Users\Start Menu\Programs\Startup\
Property(S): ProgramMenuFolder = C:\Documents and Settings\All Users\Start Menu\Programs\
Property(S): StartMenuFolder = C:\Documents and Settings\All Users\Start Menu\
Property(S): FontsFolder = C:\WINDOWS\Fonts\
Property(S): GPTSupport = 1
Property(S): OLEAdvtSupport = 1
Property(S): ShellAdvtSupport = 1
Property(S): Intel = 15
Property(S): PhysicalMemory = 2047
Property(S): VirtualMemory = 3431
Property(S): AdminUser = 1
Property(S): LogonUser = SYSTEM
Property(S): UserSID = S-1-5-18
Property(S): UserLanguageID = 1033
Property(S): ComputerName = TASSADAR
Property(S): SystemLanguageID = 1033
Property(S): ScreenX = 1280
Property(S): ScreenY = 1024
Property(S): CaptionHeight = 26
Property(S): BorderTop = 1
Property(S): BorderSide = 1
Property(S): TextHeight = 16
Property(S): ColorBits = 32
Property(S): TTCSupport = 1
Property(S): Time = 3:00:33
Property(S): MsiWin32AssemblySupport = 5.1.2600.3019
Property(S): RedirectedDllSupport = 2
Property(S): Privileged = 1
Property(S): DATABASE = C:\WINDOWS\Installer\4055dd2.msi
Property(S): OriginalDatabase = e:\6b5965e623973149ce6c6a86\msxml.msi
Property(S): UILevel = 2
Property(S): ACTION = INSTALL
Property(S): ROOTDRIVE = e:\
Property(S): CostingComplete = 1
Property(S): OutOfDiskSpace = 0
Property(S): OutOfNoRbDiskSpace = 0
Property(S): PrimaryVolumeSpaceAvailable = 0
Property(S): PrimaryVolumeSpaceRequired = 0
Property(S): PrimaryVolumeSpaceRemaining = 0
Property(S): SOURCEDIR = e:\6b5965e623973149ce6c6a86\
Property(S): SourcedirProduct = {37477865-A3F1-4772-AD43-AAFC6BCFF99F}
Property(S): ProductToBeRegistered = 1
MSI (s) (F0:00) [03:00:33:468]: Note: 1: 1707
MSI (s) (F0:00) [03:00:33:468]: Product: MSXML 4.0 SP2 (KB927978) -- Installation completed successfully.
MSI (s) (F0:00) [03:00:33:468]: Cleaning up uninstalled install packages, if any exist
MSI (s) (F0:00) [03:00:33:468]: MainEngineThread is returning 0
MSI (s) (F0:98) [03:00:33:578]: Destroying RemoteAPI object.
MSI (s) (F0:E0) [03:00:33:578]: Custom Action Manager thread ending.
=== Logging stopped: 1/12/2007 3:00:33 ===
MSI (c) (3C:B4) [03:00:33:578]: Decrementing counter to disable shutdown. If counter >= 0, shutdown will be denied. Counter after decrement: -1
MSI (c) (3C:B4) [03:00:33:578]: MainEngineThread is returning 0
=== Verbose logging stopped: 1/12/2007 3:00:33 ===
