- Apr 28, 2003
- Pittsburgh
Hi all. I have an Abit BH7 and I just installed an Aquarius II watercooling setup. CPU temps have dropped at least 15 degrees C under load. The BH7 mobo is notorious for having wildly swinging temps but I think part of my system is truly overheating. Within Winbond Hardware Doctor the temp reading marked as "Other" gets higher than the CPU. In fact, while running Sandra it has approached 65C. Once the temp gets that high the system usually shuts down. This never happened with air cooling.
What could this possibly be? Did I forget to hook something back up? What on earth is this sensor reading?
As I write this my CPU temp is 44 @ 1.74v and "Other" is 42 degrees celsius.
