stretching tube over mag3 input
zip22
i was having some trouble with the barb on my mag3 input. it was leaking just a little. i had used teflon tape and sealed it with silicone sealant. i thought about it for a little bit and then i was like, why not just stretch the tube over the whole thing. i took off the barb and have been trying to get it on, but no luck. i have the 1/8" wall tygon and i have blisters from trying to get it on. i read the stretching thread, but i was wondering if anyone has ever succesfuly done this. tomorrow i think im going to try lubing up the plastic with some vaseline and really really heating up the tube, almost to melting. i tried that stretching thing with the needlenose pliers and actually got it all the way around, with the pliers still inside. i was soooooooo excited, but then i couldn't slide the pliers out without the tube coming off :( so close, yet so far away
you should just go pick up a length of larger tubing :)
i would be quite weary about the fact that the inlet is tapered downwards. A lubricant on there would only prommote it sliding off. I say try it with silicon sealant, with a metal hose clamp(careful not to overtighter, you might crush the inlet) with 5/8"ID tubing. It would indeed give the least restriction to the pump, but I wonder if the exposed threads will have any effect of the water flow.
make sure you excessively test for leaks first!
I'm doing the same thing...except I just bought a section of 1" ID Clearflex. Nice, snug, easy fit. :D BTW - boiling it to the point of melting is a bad idea. You'll weaken the tubing and it could split...perhaps later when you're not expecting it. Just get some bigger tubing.
