which is better, which would you pay 400 dollars for?
evga nForce 680i SLI 775 Black Pearl:
Key Features
NVIDIA® SLI™ Technology
Dramatically scales performance by allowing two graphics cards to be run in parallel. Only available on select PCI-Express models.
NVIDIA Native Gigabit Ethernet
The industry’s fastest Gigabit Ethernet performance, eliminates network bottlenecks and improves overall system efficiency and performance.
Third PCI-Express Expansion Slot
Provides future support for 3 GPU applications
Other Features
NVIDIA RAID
NVIDIA RAID technology implements standard RAID 0, RAID 1, and RAID 0+1 techniques to maximize storage assets. NVIDIA RAID technology additionally introduces many innovations that simplify and optimize the management of RAID features and disk resources.
NVIDIA StreamThru Data Transport System
NVIDIA’s patent-pending isochronous data transport system, providing uninterrupted data streaming for superior networking and broadband communications. StreamThru assists in making streaming video and audio smoother and jitter-free.
Unified Driver Architecture (UDA)
Part of the NVIDIA Forceware unified software environment (USE). The NVIDIA UDA guarantees forward and backward compatibility with software drivers. Simplifies upgrading to a new NVIDIA product because all NVIDIA products work with the same driver software.
NVIDIA nTune Performance Application
Enables the easiest, safest, and highest performing overclocking available for NVIDIA nForce-based PCs. Performance wizards allow automatic tuning for the best performance or the quietest operation. Previously known as the NVIDIA System Utility.
USB 2.0
A standard plug and play interface providing easy-to-use connectivity for USB devices.
NVIDIA Firewall Technology
A high-performance, hardware-optimized firewall, NVIDIA Firewall protects your PC from intruders by filtering unauthorized traffic. Integrated into NVIDIA nForce3 and nForce2 MCPs with NVIDIA Gigabit Ethernet, it provides professional-grade traffic inspection capabilities, advanced management features--remote access, configuration, and monitoring--and is easy to use and setup via a user-friendly wizard.
NVIDIA nForce Networking
NVIDIA networking delivers the highest throughput for network transfers and lower CPU utilization. The manageable and stable NVIDIA networking solution results in better networking performance and a lower total cost of ownership.
NVIDIA ForceWare Unified Software Environment (USE)
Ensures the best out-of-box experience for every user by delivering industry-leading features for graphics, audio, video, communications, storage, and security; one driver for all products; and continual performance and feature updates over the life of the product.
Serial ATA
Performance
Based on NVIDIA nForce 680i SLI Chipset chipset
Supports Intel Core 2 Extreme, Intel Core 2 Quad, Intel Core 2 Duo, Pentium EE, and Pentium processors
1066/1333 Mhz Front Side Bus
Memory
4 x 240-pin DIMM sockets
Dual Channel DDR2
Maximum of 8GB of DDR2 533/667/800/1200MHz SLI-Ready memory
Expansion Slot
2 x PCIe x16, 1 x PCIe Graphics expansion slot, 2 x PCIe x1, 2 x PCI
2 x 32-bit PCI, support for PCI 2.1
Storage I/O
1 x UltraDMA133
6 x Serial ATA 300MB/sec with support for RAID 0, RAID1, RAID 0+1
1 x Floppy disk drive connector
Integrated Peripherals
7.1 Channel, Azalia (HDA)
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
1 x PS2 Mouse
1 x Serial Ports
10 x USB2.0 ports (6 external + 4 internal headers)
Audio connector (Line-in, Line-out, MIC)
Form Factor
ATX Form Factor
Length: 12.0in - 304.8mm
Width: 9.6in - 243.6mm
asus striker extreme
Specifications
CPU
LGA775 socket for Intel® Core™2 Extreme / Core™2 Duo / Pentium® Extreme / Pentium® D / Pentium® 4 / Celeron® D Processors
Intel® Quad-core CPU Ready
Compatible with Intel® 06/05B/05A processors
* Refer to www.asus.com for Intel CPU support list
** Please update the latest BIOS to support Intel 45nm CPU
Chipset
NVIDIA nForce® 680i SLI™
- Support SLI-Ready Memory Technlogy
Front Side Bus
1333** / 1066 / 800 / 533 MHz
** available when CPU's supporting 1333MHz FSB
Memory
Dual channel memory architecture
4 x DIMM, max. 8GB, DDR2-800/667/533, non-ECC and un-buffered memory
* Refer to www.asus.com or user manual for Memory QVL (Qualify Vendor List)
SLI-Ready Memory
1200MHz
Expansion Slots
2 x PCI Express x16 slot, support NVIDIA® SLI™ technology, at full x16, x16 speed(blue)
1 x PCI Express x16, at x8 speed(middle)
1 x PCI Express x1
2 x PCI 2.2
SLI
Support two identical NVIDIA SLI-Ready graphics cards (both at x16 mode)
ASUS PEG Link
Storage
South bridge supports:
- 1 x Ultra DMA 133 / 100 / 66 / 33
- 6 x Serial ATA 3.0Gb/s
- NVIDIA MediaShield™ RAID supports RAID 0, 1, 0+1, 5 and JBOD span cross Serial ATA drives
Silicon Image® 3132 SATA controller supports
- 2 x External Serial ATA 3.0Gb/s port on back I/O (SATA On-the-Go)
LAN
NVIDIA nForce® 680i SLI™ built-in dual Gigabit MAC with external Marvell PHY
Support NVIDIA DualNet® technology
High Definition Audio
SupremeFX Audio Card
- ADI 1988B 8-channel High Definition Audio CODEC
- Support Jack-Sensing, Enumeration, Multi-streaming and Jack-Retasking
- Noise Filter
Coaxial, Optical S/PDIF out
DTS® Connect
ASUS Array Mic
IEEE 1394a
VIA6308P controller supports 2 x 1394a ports
USB
max. 10 USB2.0/1.1 ports(6 ports at mid-board, 4 ports at back panel)
Overclocking Features
Extreme Tweaker
Intelligent overclocking tools:
- AI NOS™ (Non-delay Overclocking System)
- AI Overclocking (intelligent CPU frequency tuner)
- ASUS AI Booster Utility
- O.C Profile
Overclocking Protection:
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
LCD Poster
EL I/O
Onboard LED
Onboard Switches: Power / Reset / Clr CMOS
Q-Connector
Q-Fan Plus
ASUS EZ Flash2
ASUS Music Alarm
ASUS MyLogo3
Back Panel I/O Ports
1 x LCD Poster
1 x PS/2 Keyboard port(purple)
1 x PS/2 Mouse port(green)
1 x Optical + 1 x Coaxial S/PDIF Output
2 x External SATA
2 x LAN (RJ45) port
4 x USB 2.0/1.1 ports
1 x IEEE1394a port
1 x onboard LED switch
Internal I/O Connectors
3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
1 x IDE connector for two devices
6 x SATA connectors
8 x Fan connector: 1 x CPU / 1 x SPS / 3 x Chassis / 3 x Optional
3 x thermal sensor connector
1 x IEEE1394a connector
1 x S/PDIF output connector
1 x Chassis Intrusion connector
24-pin ATX Power connector
8-pin ATX 12V Power connector
1 x EL I/O Shield Connector
System panel connector
BIOS
8Mb Award BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.3, Multi-Language BIOS
Manageability
WOL by PME, WOR by PME, Chasis Intrusion, PXE
Accessories
SLI bridge
ASUS Array Mic
ASUS Optional Fan
3 in 1 ASUS Q-Connector Kit
UltraDMA 133/100/66 cable
Floppy disk drive cable
SATA cables
SATA power cables
2-port USB2.0 module
IEEE1394a module
EL I/O Shield
Thermal sensor cables
Cable Ties
ROG key ring
User's manual
Software
The hottest 3D Game: Ghost Recon
Striker Extreme Support DVD:
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Booster
Futuremark ® 3DMark® 06 Advanced Edition
Kaspersky® Anti-Virus
Form Factor
ATX Form Factor, 12"x 9.6" (30.5cm x 24.5cm)
Key Features
Other Features
NVIDIA RAID
USB 2.0
Serial ATA
Performance
Memory
Dual Channel DDR2
Expansion Slot
Storage I/O
1 x UltraDMA133
2 x 10/100/1000
Multi I/O
1 x PS2 Keyboard
1 x PS2 Mouse
1 x Serial Ports
Form Factor
ATX Form Factor
Specifications
CPU
Chipset
Front Side Bus
Memory
SLI-Ready Memory
1200MHz
Expansion Slots
1 x PCI Express x1
2 x PCI 2.2
SLI
ASUS PEG Link
Storage
LAN
- Noise Filter
DTS® Connect
ASUS Array Mic
IEEE 1394a
USB
Extreme Tweaker
- O.C Profile
Special Features
LCD Poster
EL I/O
Onboard LED
Q-Connector
Q-Fan Plus
ASUS EZ Flash2
ASUS Music Alarm
ASUS MyLogo3
1 x LCD Poster
2 x External SATA
2 x LAN (RJ45) port
1 x IEEE1394a port
6 x SATA connectors
BIOS
Manageability
Accessories
SLI bridge
ASUS Array Mic
ASUS Optional Fan
SATA cables
SATA power cables
IEEE1394a module
EL I/O Shield
Cable Ties
ROG key ring
User's manual
Software
Drivers
ASUS PC Probe II
ASUS Update
ASUS AI Booster
Form Factor
