Posts snipped from another thread. This is in regards to the Strix vs the Giga G1 as far as overclocking potential...
Hamstrung by the board? This thing was made for overclocking!
1500 mhz is about where most crap out. There is voltage control etc.. Take a look at our review or others to see.
http://www.overclockers.com/asus-strix-gtx-980-ti-graphics-card-review/
As a Strix 980 Ti owner ill tell you right now : pick another brand. Gigabyte, EVGA, Zotac are better for gaming/overclocking, the Strix is better for day to day and "light" gaming because of its 0db implementation (it does zero noise until it reaches 60c and the fans kick in). It has locked voltage - 1.237v and unless you mod your BIOS you will never reach your full OC potential, add to that at least in my case coil noise.
Do not mistake what i am saying, it is still one of the best in the market and well worth its price tag BUT we are "hamstrung by the board" from the start.
As to the model number there are 3 Strix, STRIX-GTX980TI-DC3OC-6GD5-GAMING, STRIX-GTX980TI-DC3-6GD5-GAMING and POSEIDON-GTX980TI-P-6GD5, might be the denomination of the 1st 2, the only difference being clock rates and water cooling compatibility for the Poseidon.
Overclocking was pretty easy to accomplish using the GPU Tweak III utility. I ended up at the same 24/7 stable overclock as with the EVGA GTX 980 Ti Classified, but with a couple minor differences. First, it took about 10mv more on the STRIX to stabilize the same overclock settings. The good news is that the STRIX allowed up to +87mv of voltage increase, whereas the Classified topped out at +50mv. One other difference was the power target limit, which was limited to 110% on the STRIX versus the 115% that was available on the Classified. Give a little, take a little it seems! In the end, we got the GPU core set to 1300 MHz base/1401 MHz boost, but the actual boost clock held pretty steady at 1527 MHz… Impressive stuff there!
