I agreed with AN underlying point in that post, yes! However I took exception to your reasoning behind you shunning the Strix.
See where I said "hamstrung by the board"? That is one point I tried to explain.
See where I also took exception to the voltage being locked at 1.23v? While true, its true across ALL cards... this lending merit to the silicon lottery statement. In other words, different silicon can reach different clocks with the same voltage!
Nowhere did I disagree with the statement 'if you are not overclocking and want the fastest stock(out of the box - no overclocking) card get.........yada'. That was never the talking point to me.
If the G1 was just an example, that is another new point you just made as I do not recall you once referencing anything BUT the G1 in your links... SMH.
EDIT: Quote Originally Posted by EarthDog View Post
Cown, for your uses, ANY of the cards (aftermarket, not reference) will be fine. If you don't plan on overclocking and want the fastest one "out of the box" grab the Zotac AMP! Edition. They both have the highest factory overclock of them all starting at 1253Mhz base clock.
This. We have already said this several times along the tread. This makes my point
If your point was stock clocks out of the box, then yes. But your first post explicitly talks about its overclocking abilities and THAT is why you would choose other cards over the Strix... here is (part of) your post again....
As a Strix 980 Ti owner ill tell you right now : pick another brand. Gigabyte, EVGA, Zotac are better for gaming/overclocking, the Strix is better for day to day and "light" gaming because of its 0db implementation (it does zero noise until it reaches 60c and the fans kick in). It has locked voltage - 1.237v and unless you mod your BIOS you will never reach your full OC potential, add to that at least in my case coil noise.
Saying overclocking means overclocking. Messing with voltages is overclocking as well. Saying you will never reach your OC potential means overclocking too.. If you meant stock clocks (out of the box clocks), you didn't say so out of the gate!
