thanks again!Then on stock all hit ~1500MHz as I already said. All other mods are not provided by manufacturer and +/- 50MHz depends from chips quality.
Confirmation bias was a serious explanation for what you are seeing and saying. I believe you saw what you are saying.. but it's such a small sample and the variance so large, that it isn't worth it to stay away from ANY brand (for that reason).
Edit: silicon lottery is not another term for I have no clue, lol. Each gpu/cpuis cut from a larger wafer. Some chips are golden, some are junk. This is why at the same voltage a cpu/gpu is stable at different clocks. This is why asic values are different.![]()
Now i have no explanation as to why they statistically OC lower since its (supposedly) better built then the other brands. Explain to me in certain terms why (and pls don't tell me "silicon lottery", that is just slang for "i have no idea") and i will happily recant.
And i always spoke from the AVERAGE point of view, or statistically as i later found out was the word i meant. So statistically the majority of the G1 and EVGA chips are from better cut then the Strix
Just for reference, repeating the same thing over and over when we know otherwise, doesn't make it true.If you really believed what i wrote you wouldn't be arguing and asking for confirmation. And i always spoke from the AVERAGE point of view, or statistically as i later found out was the word i meant. So statistically the majority of the G1 and EVGA chips are from better cut then the Strix, that is the only logical explanation correct ? Still strange that the other components are so good and the chip is of worse quality.
I would assume then if that is the case that is a very good reason to still pick the G1 or EVGA over the Strix UNLESS you are going to use LN2 ? offer me a better explanation and like i said i will recant and offer apologies for this monumental loss of time.
There may be reason to pick the other cards over the strix, but average overclocks sure as hell isn't one of them.![]()
I don't typically... I have frequently said it doesn't matter. But it's situation dependent.Then why do we reply get this one or that one ? One is better then the other right ?
