- Jul 14, 2003
So im putting together a low cost system to give as a gift like a starter PC to my fiance's little brother is very much into tech and videogames but never had a gaming PC. Gonna have him build it too, i think it'll be cool. Anyways, i had an EVGA X58 SLI LE board i came across and thats what i decided to go with for this build, and everything i've read about the x5650 was very promising. I only had 4 sticks of ram to spare for a total of 8gb (Super Talent DDR3 1600 1.65v) and its configured to run in dual channel. Spent maybe 3-4 hours last night trying to get an overclock and i couldn't get anything stable worth the life of me, though admittedly im a bit new to BCLK overclocking, especially on x58. Figured out part of my issue was clocking the ram way too high and eventually got it to boot again, but even with vcore at 1.4v, any bclk over 190 wouldn't boot even if the ram was way low at 2:6 (final mhz of 1112 on the ram at that setting). Got it to boot at 185 bclk though but prime fails after a little while, though temps are in check even with a short 10 minute blast of p95 Small FFT. CPU has a 240mm AIO on it. Trying to up the memory frequency closer to 1600mhz ends up causing boot issues of course, so im just not sure what im doing wrong or how to proceed. Or if i lost the silicon lottery big time. Also running into an issue where if the memory is too low, it only recognizes as single channel and windows tells me it has 8gb but only 3.99gb usable (the appears to be hardware reserved). Getting it to boot one setting higher does bring dual channel back, but still says 8gb total but only 3.99gb usable. Its win10 64bit still.
Here is a link to the album of my BIOS progression sorta. The pics from top to bottom go from basically stock default bios settings to what i got to get it to boot.
Any help would be much appreciated. Originally wanted something crazy like 4.4ghz but at this point i'd settle for something modest like 3.8-4.0. I read the guide and plan on attacking this again soon but currently not near my test bench to work on anything and wont be for a while, so i figured i'd put my feelers out there to gather as much info as possible so when i try it again later, i'll be better informed. Crossing fingers.
update: So decided to load defaults and try stress testing (p95 blend) to see if there was any instability i didnt catch at first, and the only change in BIOS i did was set the memory to 2:8, which BIOS said the target frequency would be 1600mhz. CPUID in windows says its ~667 which is 1333, which i guess is fine for the purpose of this testing at the moment but i notice that the CPU VTT is pretty high in just stock, according to HWmonitor...also manually set the DRAM voltage to 1.650 (the rating of the RAM) and its also reading a tad higher. CPU isnt really breaking 50c in this state, so thats nice.
edit/update 2: Currently working on isolating the max BCLK and getting WHEA_UNCORRECTABLE_ERROR bsods like crazy at 190 bclk or higher. These are the voltages i was using. HWmonitor reported the CPU VTT at 1.34 with that setting i have it at, and lowering the dimm voltage to 1.5 or even Auto made no difference as well. Eventually it wouldnt post and i had to reset the CMOS, set the voltages, and start at 185 again and am currently inching it back up.
blah, 187 bclk still got the error. Gonna retest 185 and possibly settle there.
edit/update 2:
Noticed the BIOS wasn't the most up to date (initially figured since the BIOS recognized the CPU just fine, i didnt need to update), so i decided why not and updated it to the newest. Gave it basically the same settings which was CPU vcore to 1.365 with vdroop, VTT at ~1.35, Dimm voltage at 1.62 with 2:8 divider, IOH vcore at 1.3v, and ICH vcore at 1.2v. Multiplier in BIOS at 20 with Turbo on, and bclk at 183.
CPU-Z says the CPU is at about 4015ghz, RAM is at 1466mhz, but the timings are kinda loose at CL11-tRCD11-tRP11-tRAS29. Yeah, i may need to go in manually since its supposed to be 9-9-9-28 and i think i'll do just that. Yep went in and set it to 9-9-9-28 and 1T.
Im running thru p95 blend now way longer than i previously was though, so definitely happy about that. Time for bed and to leave this running all night.
edit/update 2:
