- Jun 15, 2002
hey guy's,
i just puchased the kx7-333 mobo because i wanted the soft menu three bios for better o\c. i used to have the ga-7vrxp mobo but i didn't like it to much. i'm a very inexperianced o.c but trying to learn, i have my kx7 up to 10.5-169frb with my 1800 agoga xp.
evertime i try to increase 170 or higher, my pc fails to boot. is there anyone who can help me break this barier? i have heard alot about bios tweaking and voltage increasments, but i am not sure how to set my bios for max results. here is a list of the settings i have know.
dram clock- 166
dram timing- manual
cas- 2
bank interleave- 4
precharge to active- 2
active to precharge- 5
active to cmp- 2
ddr\dqs inputt delay- auto
ddr\dqs outputt delay- auto
md strength high
dimm 1\2 strength high
dimm 3\4 strength high
dram performance enabled
dram access 2
dram gueue 2
dram command 1
dclk feedback 0ps
if anyone could help me i would really appreciate it
thanks, wiz.
dram clock- 166
dram timing- manual
cas- 2
bank interleave- 4
active to cmp- 2
md strength high
dram access 2
dram gueue 2
dram command 1
dclk feedback 0ps
thanks, wiz.
