studio upgrade needed
studioZZ
The studio needs an upgrade, I need help of this one.This is going to be a rebuild. Need advice on 3 cool mobo and cpu's that oc'able
would like to use p4 amd best spec.
Depends on what kind of studio... I'd aim towards the P4 though... Maybe a Xeon...
For a single p4 system I'd look into the I875 chipset, on a board like the P4C800, or the IC7.
Depends on what your doing, I need more information, but a Dual Xeon might be the better route...
its a recording studio. i would like to get a great mobo with the best cpu thats oc'able. i also will be running video editing thru it. is the xeon really good for this type of setup.....
would also like to get the best amd setup
Dual Xeons are great multitaskers, but overclocking mobos are limited and dang they are expensive. I think a regular P-4 system will work just fine and allow more of your budget to be spent on the audio stuff you'll need. I'll only cover the P-4 stuff since you are in the Intel CPU section, but if you are considering an AMD, then you will need to get the A64 3200+ or similar in order match the P-4. Price is close to the same. The P-4 is a little better at multitasking, encoding, and vid editing. The A64 is a tad better at some gaming benchmarks.
Choice of motherboard boils down to how many SATA harddrive channels you will need. If you can get by with 2 SATA channels and want to save some cash, then the Abit AI7 is a good feature rich overclocker. If you want the top of the line, then look at the Abit IC7 Max3. Asus has a similar mobo called the P4C800 Deluxe too. I'd recommend the 3.0C CPU since they are priced good and are great overclockers. They average 3.6 to 3.8 gig with good cooling. If you want good cooling that isn't noisy, check out the Zalman 7000A heatsink.
For the other stuff: You have two options with RAM, PC3200 which will work good at the 5:4 memory ratio or PC4000 at the 1:1 ratio if you want the most memory bandwidth. Get a couple large capacity SATA harddrives like Maxtor, Hitachi, or Western Digital. For the vid card I need more info. Will this computer ever be used to play 3D games? That will influence what vid card to choose. For sound card you will need a professional card and I don't have that experience. You better check out the sound system section for recommendations in that department.
