SiSoftware Sandra
System Chassis
Manufacturer : Uknown Chassis Manufacture
Case Type : Desktop
Can be locked : No
Version : Version 1.00
Serial Number : 123456890
Asset Tag : 0123ABC
System Mainboard
Manufacturer : OEM BIOS
MP Support : No
BIOS ID : 62-0704-009999-00101111-040201-SiS735
Memory Controller
Error Detection Method : 32-bit ECC
Error Correction Capability : 1-bit
Supported/Current Memory Interleave : 1-way / 1-way
Number of Memory Slots : 4
Maximum Installable Memory : 512MB
Maximum Module Size : 128MB
Supported STD/FPM/(B)EDO Speeds : 70ns, 60ns
Supported Memory Types : STD, FPM, EDO, Parity, ECC, SIMM
Supported Memory Voltages : 3.3V
Physical/BIOS Memory Banks
ROW-0 (RASL-6 RASL-10) : 256MB DIMM SDRAM double-bank
ROW-1 (RASL-6 RASL-10) : 256MB DIMM SDRAM double-bank
ROW-2 : Empty
ROW-3 : Empty
System Chipset
Model : Silicon Integrated Systems (SiS) SiS735 CPU to PCI Bridge
Bus(es) : ISA AGP USB SMBus/i2c
Front Side Bus Speed : 2x 133MHz (266MHz data rate)
Max FSB Speed / Max Memory Speed : 2x 133MHz / 2x 133MHz
In Order Queue Depth : 7 req(s)
Logical/Chipset Memory Banks
Bank 0 Setting : 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Bank 1 Setting : 256MB DDR-SDRAM 8-1-1-1R 6-1-1-1W 2.5-3-3CL
Multiplier : 1/1x
Refresh Rate : 15.60µs
Power Down Mode : No
Fixed Hole Present : No
AGP Bus
Version : 2.00
Current Data Transfer Rate : 4x
Side Band Enabled : No
Side Band Support : Yes
Fast-Writes Enabled : No
Aperture Size : 64MB
LPC Hub Controller 1
Model : Silicon Integrated Systems (SiS) SiS85C503/5513 PCI to ISA Bridge (LPC Bridge)
ACPI PM Enabled : Yes
Random Number Generator Enabled : No
Speed : 7MHz
USB Controller 1
Model : Silicon Integrated Systems (SiS) SiS5597/8 Universal Serial Bus Controller
Version : 1.00
OHCI Interface : Yes
Channels : 3
Legacy Emulation Enabled : No
System SMBus Controller 1
Model : SiS 5595 Internal SMBus
Expansion Slot(s)
PCI1 (1h) : PCI 32-bit 3.3V Shared PME FullLength Available (Silicon Integrated Systems (SiS) 5591/2 Virtual PCI to PCI Bridge)
PCI2 (2h) : PCI 32-bit 3.3V Shared PME FullLength Available (Silicon Integrated Systems (SiS) SiS85C503/5513 PCI to ISA Bridge (LPC Bridge))
PCI3 (3h) : PCI 32-bit 3.3V Shared PME FullLength Available
PCI4 (4h) : PCI 32-bit 3.3V Shared PME FullLength InUse
PCI5 (5h) : PCI 32-bit 3.3V Shared PME FullLength InUse
Port Connector(s)
USB - Def : SSA SCSI - Mini Centronics / DB25 pin male
