Hmm... i can't seem to figure out which way the maze 3 fits on the socket... either way you turn it, it seems to fit? Can anyone gimme some help? Thanks.
It will only fit right one way. Look at the block, look at the mounting holes, the block is wider on one side, that is it extends out further on one side beyond the mounting holes. You want the NARROWER side closest to the LIP on the ziff socket
