Submarine
eternalprophet
Fayetteville, NC
Has anyone used one of those blueberry submarine cases? I know it's made of all plastic but I need to know if anyone has used one personally. Would like to know how much heat it generates and if anyone has had trouble with it being ALL plastic *static electricity*. For those of you who have no clue, here's the case url:
http://shop.store.yahoo.com/xoxide/submid.html
Anyone with personal experience with this case would be appreciated. It looks nifty, but plastic......
tcl
nyc
i'm building a watercooled athlon in a submarine case and can input a little. First, if your motherboard needs (includes) a special i/o shield plate, be prepared to cut into the case to make it fit. (or cut into the shield that comes with the case to fit it to the motherboard) This wasn't a big deal for me. On that subject, i highly reccomend a dremel multipurpose spiral cut bit for any cuts you need to make in the plastic- it actually cuts (use low rpm, btw) instead of melting.
In general, would suggest you get a plastic cement (solvent based) and cement all the seams. As it comes, the case is screwed together and gluing all the seams, really makes it a much more solid case. I've also cut all sorts of holes in the top over the heater core and can't imagine how much it would flop around without being glued.
You may also be concerend with EMI/RFI - as it is a plastic case, there is no shielding. I bought a can of "super shield" a nickle-based paint and sprayed the inside of the case (before gluing it all back together) hoping to provide some shielding. I bought the case because of the nifty hinged motherboard tray (ala G4) - not because of the blueberry mac color. Anyway, if you've ever had the pleasure of working with a mac g4 case, i'll tell you now that this is not even close to as solid.
It is nice and lite which will be good if you plan on carying it around a lot but i'd imagine if you dropped it, there would be many plastic pieces everywhere. The door, when closed, is reasonably secure but definately needs to be supported on something when it is open.
So, even with the above caveats, i tenatively reccomend the case if you don't mind (or plan on ) making changes to it. The plastic is fun to cut (but messy- it looked like it had snowed when i was through). This is the only (pc) case with the fold- down door, which is why (the sole reason) i bought it. I looked around a lot before doing so.
One last warning. the psu is mounted on the bottom of the case is a strange config which (On amd spec psu's with the dual cooling fans) there's not much clearance between the side of the case and the psu for the intake fan. If you don't mind a little more dremel work, you can flip the psu to suck from the other direction. But i'm watercooling it so this isn't an issue for me.
let me know if you have and specific questions. i'm not so sure the above ramble was of much use. I payed around $55 for the case but the "super shield" spray was another $20. Also, ive noticed that nikao, who makes the case doesn't list it on their website which might mean it is not long for this world. Tom's hardware and a comple other places have reviewed the case.
E
eternalprophet
Fayetteville, NC
Thanks
Thank you. I found a few more reviews on the case, but I have decided I will go with a case from Xoxide.com. It's already got a big friggin windows and 6 fans installed, as well as a rocker switch for the two. I have a spare power supply so no biggy there. Granted, the case is an older case, but with it pre modded it looks really nice in my opinion...notto mention the manufacturers fans will be replaced with thermaltakes.....they are so pretty when shined :)
The sub case I may get in the future as a test sort of thing, but right now I'm gonna go with Xoxide as long as my next thread here about the case doesnt get bad responses.
Ugmore Baggage
Plastics transmit light (and radiation), but insulate heat.
I don't see the attraction to windows or transparent cases. Like resonating mufflers on cars, they don't make it go any faster and chicks think you're crazy -- even the dumb ones.
If you're afraid your fans might stop, an rpm alarm is more effective. How often do you really plan to gaze into your case while playing games?
PS damn pollen season ... Kaff kaff
Mike K
Chicago, Illinois
Why would his fans stop spinning if he had a plastic case? Or do you mean that he would be able to see if his fans stopped spinning? Those high performance mufflers only add 1-2 horses. you have to add a whole new exhaust system and even then its only 10-20 horses.
Ugmore Baggage
It's just that it seems when the question is asked, "Why?" The best answer seems to be "Well what if my fans stopped spinning and I didn't know it?"
I simply reject looking at the inside of a case as a fashion statement, or at all interesting for that matter.
When my computer is on, the monitor gets 99% of my attention so I don't know why a case that lights up would be of any value at all. Are the lights on when the computer is off? I still don't see the attraction, but at least I might see them in that (bad pun alert) case. My problem with clear cases is that they are only seen when the computer is off -- not that there's anything to see when it's on.
Captain Slug
Helpful Senior Member
Asteroid B-612
I'm building mine out of clear plastic because it's cheaper than black plastic. It will only weight 8 pounds total by the time I'm done with it.
I put a window on my case because I can and because it attracts attention. THe black-light inside does a fine job of night-lighting my room when I come in to go to sleep.
Besides, what else was I going to do with my free time? :rolleyes:
E
eternalprophet
Fayetteville, NC
Pretty Stuff
After long consideration, I have read tons of good reviews on the Xoxide cases, but I am going to go with the Directron case Joe reviewed here at overclockers.com. It's aluminum and comes with 6 fans, removeable mobo tray, racks, and its really spacious. What am I gonna do after I get it? WELLLLL, PUT IN A WINDOW! Why? well because I have rounded cables, and I want to show them off. Not to mention I have the volcano 7 on my cpu and I will soon have one of the crystal orbs *with the fan upgrade* on my northbridge, both highly shined....why not show off all that damn shinyness. Also, I found some nifty clear fans with two blue led's on them....for guess how much? 10.99 I think, maybe less. Wow, what a great price you might say..yes, yes it is...but I can't remember where it was, I have to go search later. Anyway, later yall. I am still gettin gthe submarine in the future as a test case.
