suggest any timing for ram...
malon
Madrid
wel if youre over 166 mhz FSB I think your mem wont work with cas2 so try using 2.5-2-2-6 or 7, if you have problems try 2.5-2-3-7... GL ;)
F
fazz33
(CANADA) thornhill onatrio
i didnt change it to what spacifically said but its close (dont wanna risk my ram just yet) but anyways to the point, it gave me a nice 200point increase in 3dmark 2k1
Jognt
All round good guy
Netherlands
lower the timings untill it starts to make errors.. what brands are the other sticks youve got?
some brands with bh-5 chips can do 2-2-2-6 at 200mhz :)
Jognt
All round good guy
Netherlands
yes... just make sure the fourth timing (tRAS i believe) is higher than the others... CAS + tRcD + 2 =tRAS i believe.. so with 2-2-2 it should be 6, with 3-4-4 it should be about 8
