- Jul 28, 2001
I've been reading some of the posts here regarding water cooling, and I have decided to make a system myself.
This is what I've considered buying:
Pump: Eheim 1048 (158 GPH)
Water block: Home made x-drilled 2"x2"x1" Copper
Cooler: Car heater, does anyone know of a european car that has got a good heater for this pupose? Pref. no bigger than 6"x6"
Cooler Fan: Pabst 120 mm Low Noise (55.3 CFM)
Reservoir: Do I need one? If so how big?
Tubing: PVC or silicone or something else?
Fittings: Brass 3/8"
Cooling agent: Distilled water with added algaekiller (the stuff used in aquariae)
All in all this will cost me just under $100 here in Denmark.
Does this system sound ok for a beginners setup? I know that the x-drilled water block isn't the best solution, but it costs next to nothing and must be easy to make ....
MW
MW
