drkshadow0000
Disabled
- Mar 17, 2002
- Chicago IL
Hey everyone, i was wondering what are some good cpu fans?? cuase i dont really know what brands are good..
drkshadow0000 said:im going to be running a AMD 1600 XP @ 1.4 ghz, so what would be the best cpu fan for it?? i plan to overclock it alittle, but i heard there isnt that much u can do with the 1600 xp... thanks
Gnufsh said:If you want the ultimate air-cooling solution, try the Thermalright AX-7 with a Delta 80cfm fan. I would only reccomend this to the deaf, however, because it sounds like the fires of hell are emerging from your computer to devour you.
-Dan
I would have to agree with kent. Mechatronics F8025X from plycon would a good choice over sunon. [email protected] vs [email protected]Yodums said:
Ditto that. Best heatsink currently, and bang of the buck. The bare heatsink is only 30.00, the fan are about 15.00. I would recommend you attaching it with the Delta80, or at least the Delta68. But if you really must and your not liking the sound, the Sunon Ultra High Speed 50cfm, would be the lowest I'd go.
Yodums
