- Dec 27, 2008
With only one video card a quality name brand PSU of 550W is more than enough. Your existing PSU should fit that bill. Having said that, if it has been in heavy use (5+ years) you probably should look at replacing it soon. With the components you have chosen the total power draw of the system will be no more than about 325 watts max under load, even if your CPU was overclocked.
Your case comes with only one fan in the rear. There is mounting space for 2x120mm fans in the front. I would certain pick up a couple of fans for the front to ensure good air flow through the case from front to back. This will make the system run cooler.
