Sunbeam or Nexus
stan03
Which one would you choose to be your rheobus, if there is another one please say
Zoilo
Once Bitten, Twice Shy
L.A.
I'd get the Nexus, but I'd make sure that the trace under the screw is either properly insulated or re-routed. Another choice you'd have is a Zalman.
stan03
stan03
why do so few people like the sunbeam... even though the leds are adjustable and the fans can actually be turned completely off?
gtsimmo
Los Angeles, CA
The nexus work fine for me. I just got it mainly because it supports alot of wattage plus it was black and it matched my case :D
kinglouiex
New Mexico
I got the Sunbeam for like 26bucks I got it running 3 80mm fans now but I had it running 3 80's and a 120mm and a neon tube was hooked up to the same connection as the 120mm and it ran fine plus the color, just about matches my Lian Li case
Toysrme
Well I like my new (to m) Lexus even tho it is technically a '93, but they didn't change them till 98 so...
I pick the Lexus.
