So the Monsta is alive!!!!!!!!!!!!!
Sorry for the ****ty video
Also missing few fittings here and there... Will buy them tonight... Stupid math always wrong
On the previous videos all rads are installed, all tubing done... Running all rads with all 4 pumps, with out any waterblock (ie CPU, GPU)
Results without any blocks/heat sources
Flow : ~500L/h
Room Temperature: 21.85 C
Loop Temperature 22.7 C without fans
Loop Temperature 21.88 C with fans
Running all 80 fans at (6V ~700RPM + 4 Pumps) + Aquaro 6 = 140W using kill-a-watt
On the video the system was loud because the amount of bubbles it had inside, but now that it has less it is near silent... every few minutes i would hear bubble noise, but not ofter... The only thing i can hear if i get very close to the system is the impeller inside my flow meter... But im sure once i add my blocks it will be gone since flow rate will decrease.
