now that i cant explain. it's probably the sensors being stupid, though.ETUKE said:whats even weirder is that im running 2600 mhz right now at 1.5vcore and the cpu temp has dropped to 32 while it was 37 b4 plus core center reads it different then mbm5
which prime test were you running? did you set it to realtime priority in the task manager?ETUKE said:prime wont even go 2 secs here maybe upp the vcore some more.
EDIT: well Im not trusting prime as other stress tests run and are running as I type at lower vcore.Gona try the real world test and use it for awhile.
no I didnt...Im not too familiar with these stress testsAphex_Tom_9 said:which prime test were you running? did you set it to realtime priority in the task manager?
Aphex_Tom_9 said:oh yea, i got 31 on the SSE2 patched version of super pi, 32 sec on the standard version.
it's a version of super pi that uses the SSE2 instruction set for faster calculations. i got in on XS, look around for it.Sucka said:What's the SSE2 patch? I've only ever seen the Prescott patch (SSE3).
