T
Tom
Guest
The thing about the SuperOrb is that because the cyclinder is soo tall, it's very tempting to grab it with one hand while using the other on the clip.
Don't do that!
Instead, just press down with both hands on the clip handle, and then push the handle towards the heatsink, so that the clip moves down and towards you. This will release the clip from the socket lug. The trick is to do this only by touching the clip handle, not the heatsink!
I hope this helps.
Tom
Don't do that!
I hope this helps.
Tom
