- Apr 25, 2005
- Berkeley, California
SVC.com - clearance section.
here are the highlights i got in an email
Global Win YCC-8870 Silver Aluminum Mid Tower ATX Case
Are you looking for an aluminum case? Aluminum cases weigh less, dissipates heat faster, and costs more than steel, but not in this case! Take advantage of our budget friendly aluminum case. This case is made of 0.8mm aluminum and uses an ABS plastic front panel. A cross support rail is used to increase structural integrity of the case.
Sale Price: $14.99
Wiremate Black Wire Organizer
WireMate is an enclosed device that provides for the orderly realignment and consolidation of tangling wires of varying thickness which exist with most electronic equipment setups. This ranges from power cords, telephone lines, speaker cables to DSL lines. It only has only two parts, a base and cover, and a very unique and inclusive design setting it apart from all other partial solutions.
Sale Price: $19.99
Thermalright XP-90 Aluminum Heatpipe Heatsink CPU Cooler for AMD K8 and Intel 478
The little brother of the XP-120, the XP-90 from Thermalright is designed and optimized for 90/92mm fans. 4 aluminum heatpipes bring the heat straight from the base of the heatsink to the large aluminum fins. The heatpipes are soldered onto the base for maximum heat transfer. Compatible with Sockets: 478, 754, 939, 940. No fan included.
Regular Price: $27.99
Sale Price: $25.00
W/ Cupon Code: XP90425
Cooler Master VHC-L61 CoolViva VGA Cooler
The Mitsumi Black 13 in 1 Card Reader Features 4 ports, and one USB 2.0 access from the front panel. Fits 3.5" Bays, With 13 cards supported, there is no need to worry about card reading compatibility. Available in different colors to match your computers appearance.
Regular price: $19.99
Sale Price: $9.99
Logisys Black KB508BK Compact Illuminated PS/2 Keyboard
A another great Logisys keyboard, this compact version of their popular illuminated keyboard takes up less space on your desk. Compact design and blue back lighting make this keyboard great for small desks or going out to lan parties.
Regular Price: $19.99
Sale Price: $15.99
Swiftech MCW60-B Extreme Duty VGA Water Block
The MCW60™ VGA waterblock is a next generation liquid cooling solution for high-end graphics processors. It evolves from the award winning MCW55 by receiving the same base plate technology as the Apogee water-block for enhanced heat dissipation, and a redesigned injection molded housing for universal compatibility with all liquid cooling systems.
Sale Price: $44.95
Nexus Damptek Noise Abosorption Material
Nexus DampTek® is the latest development in noise absorption material. Our engineers searched the market for the most recent developments in noise absorption and isolation. The materials we found the most effective, to isolate and absorb frequencies coming from your pc components, were combined to
create Nexus DampTek®. Nexus DampTek® consist of a 1.5 mm barrier mass to isolate the noise and a 6 mm foam layer to absorb the multiple frequencies.
Regular price: $49.99
Sale price: $44.95
Arctic Cooling NV Silencer 5 Rev. 3 VGA Cooler
After the release of the VGA Silencer, Arctic Cooling has now fine tuned a new VGA cooler for various video cards. There are no universal mounts or sizing. Nothing is compromised with the new line of Silencers. Each one is designed specifically to provide maximum cooling and compatibility with a specific card. *NOTE, Please check with the manufacturer to see if this cooler will physically fit on your motherboard*
Application:
AGP: NVIDIA Geforce 6800 (GT, Ultra)
PCIe: NVIDIA Geforce 6800 GT, Ultra
NVIDIA's 7800 series VGA Boards. (new for revision 3)
Sale Price: $29.95
Arctic Silver ArctiClean 60ml Kit - Thermal Material
ArctiClean 1 Thermal Material Remover quickly emulsifies and dissolves the existing thermal grease or pad from the CPU and/or heatsink so that it can easily be removed with a clean cloth or paper towel. A few drops of ArctiClean 2 Thermal Surface Purifier and some gentle wiping then removes the remaining residue and inhibits flash corrosion on copper or aluminum.
Sale Price: $5.95
Cooler Master eXtreme Power RS-500-PCAR 600W ATX 12V V2.01
Power Supply is a key component to supply all power requirements in supporting PC operation to maintain continuous stability and reliability of a computer system. Cooler Master power supply lets your PC operate better and more efficient, with the best power source as it comes into your PC. It also enhances system reliability by preventing mains abnormal supply from spikes and surges. In addition, the power supply provides your system with perfect protection.
Sale Price: $89.99
Clearance Items:
30% off Swiftech MCW55 Extreme Duty VGA Waterblock $34.95
57% off Panaflo FBA08A12M 80x25mm Hydro Wave Bearing Fan 32.1CFM 28dBA $2.99
50% off CaseArts LED-IDE to SATA Power Cable - Blue $1.50
50% off CaseArts LED-IDE to SATA Power Cable - Green $1.50
50% off CaseArts LED-IDE to SATA Power Cable - Red $1.50
50% off CaseArts 4-Pin Molex Y-Adapter w/LED -Red $1.75
50% off CaseArts 4-Pin Molex Y-Adapter w/LED -Green $1.75
79% off Green EL 24" ATA133/100 Dual Device Round Cable $2.99
75% off Cooler Master TEC-A24-EG 24" EL IDE Cable - Green $3.49
14% off Ione Libra-P5 RF 2.4GHz Presenter Mouse $29.99
25% off Logisys MS700JD Jade 4 Direction USB Gaming Mouse $11.99
25% off Logisys MS700JD Blue 4 Direction USB Gaming Mouse $11.99
25% off Logisys MS700JD Orange 4 Direction USB Gaming Mouse $11.99
33% off Computer Sleeving Kit - Clear $9.99
40% off CaseArts UV PSU Sleeving Kit (w/Molex Tool) - Green $5.99
40% off CaseArts UV PSU Sleeving Kit (w/Molex Tool) - Red $5.99
44% off Bytecc 4 Port USB 2.0 PCMCIA Card Bus $9.99
41% off Logisys Pearl White 2.1 Gaming Speakers w/ Control Center $34.99
53% off OCZ Gold Edition PC4000 CL2.5 Memory - 512MB $45.99
43% off OCZ Value Series DDR PC2700 CL2.5 Memory - 1GB $64.99
-All PC Toys Floppy Cables -
PC Toys 18" Single Device Round Floppy Cable - Black $0.79
PC Toys 18" Dual Device Round Floppy Cable - Black $0.69
PC Toys 24" Single Device Round Floppy Cable - Black $0.79
PC Toys 24" Dual Device Round Floppy Cable - Black $0.69
PC Toys 12" Single Device Round Floppy Cable - Blue $0.79
PC Toys 18" Dual Device Round Floppy Cable - Blue $0.69
PC Toys 24" Single Device Round Floppy Cable - Blue $0.79
PC Toys 24" Dual Device Round Floppy Cable - Blue $0.69
PC Toys 12" Single Device Round Floppy Cable - Copper $0.79
PC Toys 18" Single Device Round Floppy Cable - Copper $0.79
PC Toys 18" Single Device Round Floppy Cable - Red $0.79
PC Toys 18" Dual Device Round Floppy Cable - Red $0.69
PC Toys 24" Single Device Round Floppy Cable - Red $0.79
PC Toys 24" Dual Device Round Floppy Cable - Red $0.29
PC Toys 12" Single Device Round Floppy Cable - Silver $0.79
PC Toys 18" Single Device Round Floppy Cable - Silver $0.79
PC Toys 24" Single Device Round Floppy Cable - Yellow $0.79
PC Toys 24" Dual Device Round Floppy Cable - Yellow $0.49 $0.29-$0.79
50% off Optical Mouse Extreme 800DPI PS/2 Mouse - Silver Black $3.99
50% off Optical Mouse Extreme 800DPI PS/2 Mouse - Black Silver $3.99
50% off Eagle Touch MCK-8800 Wireless Multimedia Pro XP Keyboard And Mouse $14.99
50% off Wireless Power Office Keyboard and Mouse PS/2 Combination for XP - Black $17.50
50% off Thermaltake A2210 Silver Xaser RF Series Wireless Gaming Keyboard and Mouse $26.50
50% off Power Office Keyboard for XP - White $9.99
Sale Price: $14.99
Sale Price: $19.99
Sale Price: $25.00
Sale Price: $9.99
Sale Price: $15.99
Sale Price: $44.95
Sale price: $44.95
Application:
Sale Price: $29.95
Sale Price: $5.95
Sale Price: $89.99
Clearance Items:
