i am swapping from a BD7II (DDR based) to a TH7II (RDRAM based)...
will my 1.6a overclock the same?
right now top speed is at 166mhz fsb 2664mhz with 1.68v (1.75 bios setting)
i plan on swapping out the bios on the TH for a mr natural bios that allows voltage up to 1.85. i'll probly set it at 1.8 which being an abit board should give me a real voltage of about 1.72 or so which is still pretty safe. that will give me another .04v of stability.. so maybe it will even overclock better than it is now.
i've never just swapped boards and kept the same cpu before. i always upgraded both. should it be the same with the same settings?
